1 - 8 of 8 Posts
The rockshaft stop on my 1025R us junk. It worked for a very short time. It is loose and it appears that they installed a small washer that is supposed to hold under the plastic channel the rockshaft moves thru. Repair or replace ideas?
You need to move this post to the SCUT forum as a 1025r is not a garden tractor but is a SCUT tractor. You will get more correct answers there. Roger
I'm referring to the rockshaft stop that is built into the guide that the rockshaft moves that controls both the 3ph and mower deck.
maybe a picture would help?.......
there is a rockshaft that actuates the 3ph hitch arms (at the back), and there is a rockshaft under the tractor that connects to the mowing-deck lift arms.
I guess you're talking about the 3ph one at the back.... if you could post a pic - there are different configurations of the 1025R depending on serial number, so a pic would be very helpful.....
I had the same problem. I unscrewed the stop and took it out. I then put two large flat washers(one in top one on bottom) of the slide opening. It works fine now.
1 - 8 of 8 Posts
