1 - 1 of 1 Posts
While cutting today I suddenly began losing my forward propulsion. I looked down to see hydro fluid everywhere. It was spraying, so it had some pressure behind it. During an inspection I could see that a number of the bolts that connect the rear end to the frame were missing. Because of this the rear end transaxle has some movement. I could not see the source of the leak. Is it likely that this unwanted movement broke a hydro line? I have had a lot of bolts fall off this thing over the years. Any one see this problem before? Thanks
1 - 1 of 1 Posts
