Hello,
New to MTF and found it by searching for a solution to my problem which is the engine almost dies after first time starting when cold and runs very rough after restarting after a breif shutdown of a few minutes. This has been getting gradually worse over the last 2 years to the point where it runs at full throttle but idling down the governor is just up and down and can even backfire.
The only way I can improve the performance is to clean the air cleaner but this helps just slightly. I run regular gas, not ethanol, I keep the radiator clean with a blowgun removing the screen etc. I have replaced the FF,AF and plugs with no change. I wait until the fuel pump stops running before starting. The only thing I haven't done is to check fuel pressure or changed any of the sensors which I don't know how to check. Have also checked fuel cap to ensure vent is open. I'm wanting to guess it's the oxygen sensor or something like that which controls the FI system.
The temp runs around the mid section range.
Any ideas???
Thanks in advance, Paul
Any ideas???
