Hey everyone,
One of my very good friends co-workers is bringing me his 029 on Monday for me to have a look at it. He said it does not seem to be oiling at all, will burn a bar and chain within 15 minutes, and seems to be really down on power. Having not looked at the saw yet I do not know for sure what is wrong but my suspicions on the lack of power is a scorched piston and cylinder. I was reading on line that you can swap the piston and cylinder from an 039/MS390 onto the 029/MS290 because the bases were the same. However, I called a friend of mine that is VERY knowledgeable on Stihl's and he said it wouldn't work because the intake tracks are set up different. I am inclined to believe him because he has been doing it for the better part of 20 years but there are several articles on arborists sites saying it can be done, so I am a little confused here. Is this a feasible swap if the cylinder kit can be located cheaply enough, or will it be more trouble than it is worth? Also, on the oiler, can I swap an oiler from a 390 and drill the hole out in the body to get a better supply of oil (guy is running a 20" bar, really a little too much for a 029/MS290) or is the oiler the same as an 029 and there is no advantage to doing this. The saw is very sentimental to the owner, hid grandfather bought it new and used it for several years then gave it too him and he used it to build his house, so he will probably want it fixed even if it costs more than a new saw. I priced all the parts OEM through the Stihl dealer I work at and after taxes the cost of the parts is $306.95 for a 029 cylinder kit, oil pump, oil line, pickup, and transfer collar. I can buy all the parts aftermarket for about half price, (Good quality from Germany aftermarket, cylinder kit actually made by MAHLE not that cheap Chinese crap), but I figured if I had to do a total re-build anyways I would see if I couldn't get him as much power as possible, port the muffler etc...
Thanks,
Joe
Thanks,
Joe
