Building A House - Page 10 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
My Place Pics and stories about your home and property
post #136 of 282 Old 02-16-2019, 09:01 PM
HerbsGT's Avatar
Re: Building A House
Jere, I have been following this build from the beginning and really enjoying the build. This looks like the future of house building. Keep up the good work. I am in the local area (Ludwigs Corner area)Hope to run into you sometime in the future. . Herb
HerbsGT is offline
post #137 of 282 Old 02-16-2019, 11:09 PM Thread Starter
Have Dog - Will Travel
Jere39's Avatar
Sounds good Herb - I get around, should be an opportunity to spot each other somewhere around the area. I shop the hardware store, Frames, and Littles often enough.
Jere39 is offline
post #138 of 282 Old 02-16-2019, 11:37 PM
Jere,
I'm interested is the garage floor, suppose they are going to set a beam on the center column and set precast floor?
It seems as the build is going real fast but consider construction time at the plant, transport, site prep, etc.
With the declining numbers of people entering the trades, this very well could be the way of the future.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #139 of 282 Old 02-17-2019, 07:24 AM Thread Starter
Jere39's Avatar
Well, this has been a very interesting learning experience for me. I do not believe there will be a precast floor in the garage. The garage itself was delivered as three practically hollow modules and set together on the foundations walls of the garage. You can see the garage where the entry sill is in this picture. The 'door' is still filled in and Tyvek covered. There is stone backfilled in the garage up to about a foot below the haunches, the sill, and the column. I suppose they could still get a central beam from the left end where the haunches are to the column which sets on the right side of that garage door sill. But, I now suspect the floor will be poured concrete and the haunches and column will be incorporated to prevent settling. But, I've been wrong on a few things already, so this will be a new building practice to me when I see it.
Still plenty of fill on site, and it will be needed to get the grade up where I think it ought to be on those foundation walls to make the setting look right.
Jere39 is offline
post #140 of 282 Old 02-17-2019, 08:14 AM
BoWoggie's Avatar
When my in-laws retired from farming and moved to town, they had a small modular home built. Nothing on this scale of course. Their house had siding on it. The house was mostly sided when it was delivered. If this house is to be sided, I am surprised than none is on yet. Time will tell I guess.
Sometimes It's better to keep your mouth shut, and have the world think you a fool, than to speak, and remove all doubt.
BoWoggie is offline
post #141 of 282 Old 02-17-2019, 09:33 AM
Don
They may have a header beam which is the portion above the garage opening to support the roof and king studs on the ends to hold the header beam up, already part of the section where the proposed garage is. Similar to this picture but only a two car opening, not a three car opening.
Don
post #142 of 282 Old 02-17-2019, 09:53 AM
BoWoogie,
I am guessing but I imagine that your in-laws home was a two section ranch type of home. Long straight runs on the front and back, ends were sided once set together?
I use a Van Mark Cutting Tables | Trim-A-Table TAT50 to cut siding, it cuts down to a 2/12 pitch. I also use a formula to keep seams away from each other, full 12' 6" piece, half 6' 3" piece, three quarter 9' 4 1/2" piece and finish with 3' 1 1/2" piece. I continue this pattern up the wall and gable end keeping my seams uniform. It drives me nuts seeing contractors that use whatever is left to start the next row. I am more interested in how the siding job looks once completed than what I put in the dumpster, most all of the off cuts can be used somewhere if not thrown on the ground and trampled on. Leave what is left for attic stock with the homeowner if they wish.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #143 of 282 Old 02-17-2019, 10:03 AM
Jere,
Guessing once again but it appears that the drop in the foundation wall will accept the garage floor, the walk in entry door appears to be ganged with overhead door for this pour. Apparently there is a temporary wall that will be removed where the overhead door will go.
Still very interested in column reason, haunches, fill not being compacted in stages if it is poured.
Keep us posted,
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #144 of 282 Old 02-17-2019, 02:08 PM
BoWoggie's Avatar
It seems very odd to me that the void for the garage door would extend under the walk in door. This is just a guess but......Maybe that is not a walk in door at all but simply framed that way temporarily for construction purposes. Gives workers access to the inside. At some point the temporary framing will be removed and reveal the entire void as garage door. Maybe one of you math wizards can take the width of that ladder, and using that measurement calculate the width of that void.
That concrete pillar in the garage still has me stumped. I know that different areas of the country have different building practices for a variety of reasons. When I first saw it formed up, I thought maybe it had something to do with a single post vehicle lift. After the pour, the post seemed to be solid concrete, so that was out.
This is why I could never have a new hose built. The waiting would drive me crazy. I would have to leave the country for a year, and hope it was done when I got back. Greg
BoWoggie is offline
post #145 of 282 Old 02-17-2019, 04:39 PM
Don
A typical two car garage is 16 foot wide. I would think that void is about 17 foot wide. Enough room to install vertical studs to hold up the top header. Some new garages are 18 foot wide and 9 feet tall. My house built in 1963 has a 16 foot wide garage door and its 7 feet tall. And the garage is 22 foot deep and 24 feet wide.
Don
post #146 of 282 Old 02-17-2019, 06:03 PM Thread Starter
Jere39's Avatar
Pretty sure the overhead garage door and the pedestrian door beside it will both be at floor level. The void in the foundation wall for each of the two doors is at the same height. The opening that is currently being used for construction entrance is the top 3/4 of the pedestrian doorway. It might not be obvious in the picture, but you can see the dark of the garage below the module tyvek line.
Jere39 is offline
post #147 of 282 Old 02-18-2019, 04:37 AM
5K and there's still more
Donewrken's Avatar
Joe made me aware of Jere's interesting thread and all of the speculation caught my curiosity as well.
So I took liberties with Jere's picture and copied the shadow of the ladder and superimposed it back onto the pic, next to the door.
It was hard to see in detail, so I cropped and enlarged it. I also stacked the ladder shadow twice.
Since it is the shadow the scale is not the same as what the rungs would be, but it gives a reference anyway.
If you look close you can see the king behind the ladder.
I then laid the shadow on it's side.
Well there you go.
My thought's, I agree with it being a temporary door opening since it is close to eight feet in height.
I'd guess it will be a single 18 foot roll up.
I also agree that due to zero compaction they will be pouring the slab and beams in a monolithic pour, over cast in foam forms, rebar & wire mesh included.
Just guessing.
fun thread, thanks Jere.
Don
Donewrken is offline
post #148 of 282 Old 02-18-2019, 04:02 PM Thread Starter
Jere39's Avatar
Always good to hear opinions and conjecture. I am confident the front of the garage has a double wide opening for vehicles, and to the left of it, a single wide pedestrian door. This afternoon I stuck my head and camera through the slot for the overhead door and snapped two pictures. First to the left:
You can see the haunches on the left wall, the stone fill that was scooped in before the modules were set above, and the underside of the floor of the modules. That floor seems to me to be temporary, constructed of overlapping sheets of plywood on an inadequate floor joist system. I'd bet it will be removed at some point for a floor pour in there.
And, to the right, much the same, but with a view of the poured column which has some 2x bracing up to the floor which I believe is temporary.
Weather forecast for snow again Wednesday, not sure what they might be working on. And, to answer a question, I cannot see inside any of the living area to determine if there is a finished floor. But, I believe there is based on the website of the module manufacturer.
All for today, thanks for following my research project
Jere39 is offline
post #149 of 282 Old 02-18-2019, 04:14 PM
Craftsman,
The header has to be in place already to carry the roof load, I would assume that the header carries over the entry door also.
I think they may have went outside of the conventional building methods.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #150 of 282 Old 02-18-2019, 05:57 PM
BoWoggie's Avatar
Can't speak for anyone else but all these pics did was confuse me more. When my in-laws modular home was built, only the house was delivered in tact. The garage was completely built on site.
BoWoggie is offline
