New (to me) trailer and tie down review - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 08-08-2019, 07:19 PM Thread Starter
Hey all,
A few weeks back I picked up a used 7x18 car hauler, 7K lbs. I am going to make transport my tractor up to my parents house tomorrow to help them with some yard work. I am trying tog et everything loaded up tonight and wanted some tips on my tie down job. I have 4 of those 2in ratchet straps, 3K working load each, 2 in the front and 2 in the back. I think I'll eventually move to chains, but this should work.
In the front, I went over the frame, loader bucket, and down to the d-rings. In the back, I went from the frame just in front of the backhoe and crossed to the opposite corner. Where the strap went over a corner, I put a folded rag between he strap and the corner, though none of the corners seemed very sharp. For good measure, I put the backhoe bucket flat on the deck and ran a 1" strap side to side over it, and one over the seat to keep it from bouncing the whole way. I tied up the losoe ends on all straps.
I feel like this arrangement gives good holding power front to back, but feels a little lacking against the lateral forces. One problem I have with the straps is that the hook doesn't fit in the stake pockets or inside the rub rail, so I went to the d-rings on all corners. I'd have to go to the outside and attach it to the rub rail directly.
The trip is about 50 miles one way. I live ~5 miles form the highway, my plan is to pull over and check for tightness shortly after getting on. Then again about 30 miles later before I get off the highway.
What changes would you recommend?
ID:	2390137   Click image for larger version
ID:	2390139   Click image for larger version
ID:	2390141   Click image for larger version
Location=Oxford, CT
Equipment:
2010 Stihl BR600 backpack blower
2012 Husqvarna 562XP with 20" and 28" bars
2013 Protero PTO-PV18 collection system.
2014 Wallenstein BXM32
2015 Stihl KM130 with line trimmer and hedge trimmer.
2015 Massey Ferguson GC1720 with 2360 front snowblower and 60" drive over MMM.
Fiziksgeek is offline
post #2 of 16 Old 08-08-2019, 07:40 PM
4Get GTO's Avatar
Re: New (to me) trailer and tie down review
I honestly think you did well. Not sure if I'd change. Don't even think that I would consider chains either..! 👍
4Get GTO is online now
post #3 of 16 Old 08-08-2019, 08:04 PM Thread Starter
Thanks for the vote of confidence. I've only towed the tractor a couple times myself and used a landscape trailer. Having sides and a folding ramp gave me some comfort, even if the straps came loose, I wouldn't lose the tractor. The 18" car hauler fits the tractor much better and gives me plenty of room to move the weight forward or backward to get the weight distribution right. But its a flat deck, if the straps come loose....it could just slide right off!
Location=Oxford, CT
Equipment:
post #4 of 16 Old 08-08-2019, 08:29 PM
kklowell's Avatar
I too think you tied it down well. I always liked straps better than chains if I wasn't hauling something like an excavator. I thought that straps were easier to keep tight.
kklowell is offline
post #5 of 16 Old 08-08-2019, 10:18 PM
Cat385B's Avatar
I work with heavy equipment, and drove a lowboy for five years. You did fine.
Cat385B is offline
post #6 of 16 Old 08-08-2019, 10:45 PM
Handshake Seals the Deal
Andrew2's Avatar
We do commercial hauling also and we usually use chains to haul equipment. But in your case considering the size of the tractor i would do what you did. Chains are hard to work with...and its not a long haul either so you should be just fine. I like you plan about stopping and rechecking. More people need to do that. Hope you get it hauled successfully and remember - be safe.
Andrew2 is offline
post #7 of 16 Old 08-09-2019, 05:27 AM
20,000 Posts & Climbing
Looks fine for a short trip like that.
I prefer chains with hooks welded to the bucket at least. Tires flex, even with the trailer suspension, that puts a bit more stress on the rub points with straps. That TLB weighs about 3000 lb.
TUDOR is offline
post #8 of 16 Old 08-09-2019, 11:48 AM
Douglas1953's Avatar
X2
Doug
Douglas1953 is online now
post #9 of 16 Old 08-09-2019, 02:29 PM
Senior MTF Pollster
Austen's Avatar
Looks like a sturdy trailer, congrats!
Bolens HDT1000 #11- Coming eventually!
1977 Economy Tractor
Hydraulic lift conversion
24" model front king pins
48" Belly mower
32" tiller
3pt hitch
"So I say to you, ask, and it will be given to you; seek, and you will find; knock, and it will be opened to you." - Luke 11:9
Austen is offline
post #10 of 16 Old 08-09-2019, 02:59 PM
Collector of many tractors
Kbeitz's Avatar
Don't forget to tie down you'r hood. many tractors lost the hood when air gets under them...
Kbeitz is offline
post #11 of 16 Old 08-09-2019, 08:27 PM
JohnW's Avatar
That is why most people in the know haul them backed onto the trailer, I also like to have a strap or chain across the middle of whatever it is I am hauling. Kinda like a seat belt, helps reduce bounce from the tires.
Logic is most useful. If only more humans would learn it and embrace it.
JohnW is offline
post #12 of 16 Old 08-10-2019, 10:58 PM
Inveterate Putterer
Mikey4's Avatar
Take care to keep the tails of the straps from flapping in the breeze. After a 50 mile trip the ends might be be frayed.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is offline
post #13 of 16 Old 08-28-2019, 08:35 PM Thread Starter
Just following up. The trip went well with no issues, up and back. I stopped and checked the straps as planned, and none of them loosened at all. I didn't see any cuts on the straps at contact points, though I have since invested in some strap abrasion protectors, and may still with to chains long term. I did have one guy turn in front of me that required me to hit the brakes pretty hard, not emergency hard, but hard enough to make me pucker bit, but everything was ok.
I'll call everything successful from my truck to the brake controller to the trailer to the tie down job!
Location=Oxford, CT
Equipment:
post #14 of 16 Old 08-28-2019, 08:39 PM
kklowell's Avatar
Glad it went well... but I think we all expected that it would,
kklowell is offline
post #15 of 16 Old 08-28-2019, 09:05 PM
Andrew2's Avatar
That is definitely a true statement. But of course sometimes the unexpected happens...
Glad to hear all went well. 👍
Andrew2 is offline
