Vintage Briggs engine. What Oil? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 01-02-2015, 11:03 PM Thread Starter
10hp cast iron pre 1981 (its a 1977 Briggs engine-243431)..I know oil classifications since this engine was built are obsolete with today's modern oil..questions is do I need to worry about zinc (ZDPP) ppm?..would a modern synthetic work?..my gut is do what we have always done and use straight 30wt oil but I am a little worried about vintage Briggs engines needing some zinc..30wt Shell Rotella T is my go to oil as it does have 1200ppm zinc..any ideas on what to use?
snooter is offline
post #2 of 6 Old 01-03-2015, 12:40 AM
3v0
What did you say ?
3v0's Avatar
Send a message via Skype™ to 3v0
Re: Vintage Briggs engine. What Oil?
Have you used Rotella T on old engines without first tearing them down to clean the decades of sludge out ? I would worry that the high detergent would put this stuff back into the oil.
Kubota BX2200 FEL, 1975 Essick VR30RE Road Roller, Kwik Way Dirt Master Backhoe
1982 Red Cub 682, 1973 John Deere 112,
1974 Gilson Bros Super 8
ZombieEngines
3v0 is offline
post #3 of 6 Old 02-23-2015, 07:25 PM
Yamaha-YT125's Avatar
Considering you can compress the valve springs with your fingers on any Briggs, Tecumseh/Lauson, Kohler I wouldn't worry about zinc
1985 Yamaha YT125 Tri-Moto
1985 Allis Chalmers 611 LTD
1965 Bolens 1000
1948 Simplicity Model D
1986 Simplicity 860E
Yamaha-YT125 is offline
post #4 of 6 Old 02-23-2015, 09:39 PM
professor's Avatar
What yamaha said.
I have a supply of 15 wt full synthetic that we tested with the viscosity of 30 wt. at 212degrees- we run it in the go karts (clone motors/ run hard), I run it in my motors.
My pull start little plow tractor starts in the zero temps we have had.
I know the oil helps.
Every day is a victory.
'64 Simplicity Broadmoor
'66 Simplicity Broadmoor 707
'68 Sears Xl 10
? Dynamark 11/42
'71 Wheel Horse Special
'71 Wheel Horse Gt14
'72 Cub 127
? Bolens 10H
professor is offline
post #5 of 6 Old 02-23-2015, 09:49 PM
I've always gone straight to Rotella when I've purchased any equipment off of Craigslist. And ive had quite a few engines from the same time period of yours. I understand this can be a hotly debated subject, but I'm of the option there isn't a reason not to use detergent oil in 99% of engines out there. If you are concerned with too much sludge getting suspended in the oil, do a couple more rapid drain and fills.
I ran penzoil platinum once in a old Tecumseh snowblower I'd picked up off CL. The oil turned black in an hour or two of operation. Dumped that and the oil color acted more normal from that point on till I sold it a couple years later.
TWG1572 is offline
post #6 of 6 Old 06-15-2015, 01:45 PM
The PP was cleaning the engine sounds like. I would guess a non detergent oil would get black fast. Never ran it.
slomo
slomo is offline
