Late '50's 8B engine oil - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 07-26-2016, 12:54 AM Thread Starter
Certified Shadetree Mech.
jcsmith's Avatar
I have a late 50's 8B, ( the data plate is missing ), with a plain replacement shroud. The manual calls for SAE 20 oil. Should I use 20wt or is 30wt okay. It's on a front tine tiller.
Also does anyone know what year B&S started stamping the model,type, and code on the shrouds?
Thanks for any info.
Chris
1968 Cub Cadet 104, '96 service replacement K301, 42" deck
2007 John Deere LA 130,21hp v-twin intek , 48" deck , 1997 Scotts 42502X8,( by Murray ) 2nd repower, '96 18hp B&S Twin ll,42" deck
As you slide down the Banister of Life, may the splinters point in the right direction !
jcsmith is offline
post #2 of 3 Old 07-26-2016, 09:20 AM
Re: Late '50's 8B engine oil
Hi,
The manual I have (Briggs CE8069) calls for Mobil Arctic # 20 which is 30 wt oil. I do not think you would want to run 20 wt unless you are running the engine in cold weather.
Dave
DLF_IN is offline
post #3 of 3 Old 07-29-2016, 01:12 PM Thread Starter
jcsmith's Avatar
Thanks Dave. That is great info. I must have misread the owners manual online. The manual calls for SAE No. 20 oil above 32 degrees, SAE No. 10w below.
Chris
jcsmith is offline
