MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - The Gravely Timeline Thread
post #1 of Old 06-03-2015, 02:32 PM Thread Starter
CTPhil
CTPhil's Avatar
I've heard the occasional rumble about creating a Gravely timeline, but if there is one I don't know about it. So assuming that there is none, how about we create one right here in this thread? If someone has something to add they can just post and add it, and maybe we will end up with something we can output in timeline form.
How it would work is if you had something to add, you just copy/paste the list from the previous post and modify it with your addition. For now we'd be just making a list, just try to insert your addition into the part of the list it should go chronologically. We can clean it up as we go. Info doesn't need to be added in order, if you know something, add it in! Just make sure to keep the list in a separate block form your comments. Let's just dive in and we can discuss particulars as we go.
Let's do this! I'll start with what very little I know:
"1922: The Gravely company was incorporated"
Gravelys: 1951 L, 1952 L, 1954 L, 1956 LI, 1961 LI-SR, 1962 L, 1962 LI, 1963 LI, 1965 L8, 1965 LS, C 10, 524, 5460, 8102.
I can quit any time I want. I just don't want to right now.
The rest: 1969 WH Raider 12, 1983 WH A-111, 1985 WH 314A, AC 917H, 1978 Ford 2600, 1978 Ford 4100, 1975 Ford 3550 Industrial, 1959 Farmall 560, 1949 Case VAC, 1951 Case VAC Eagle Hitch, Troy Bilt Horse, Troy Bilt Pony. Mowers, rakes, balers, and far too much other old junk to list....
CTPhil is offline
