Johnny Bucket on my John Deere X590 review - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 21 Old 04-13-2018, 08:23 PM Thread Starter
JD Ken
kskomro's Avatar
I must admit, I was a little skeptical about how well it would work, I purchased it with plans to really put it to use. I've owned Kubota FEL's before so I knew the capabilities. I also know the cost. I know after i finished my other major project a few years back i sold my FEL because it sat in the garage for a few year minimal use, money just sitting there, so I sold it. Well a few years later, more projects piled up, I know I needed something. Let me tell you, it's awsome! in the past 3 weeks, I've moved and spread a bunch of crushed stone in my driveway, I've spread 25 yards of Top soil, 5 yards of Crushed white stone, at least 10 yards of dirt with stones in it, 4 yards of mulch, moved many piles of brush from my trimmed trees. No it don't dig deep, but thats ok, I only needed it to dig just below the surface anyway. It dosn't make tall piles of dirt, that's ok to, it takes them down just fine. Most all of the top soil could not be delivered where i needed it, so I had it delivered on tarps in my driveway. I had the first 8 yards of top soil delivered in my driveway, 3 hours later I called the company and asked if I could get anther 8 yards, the guy could not believe I was done with the first load already. When he showed up he asked what i use the little bucket on john deere for, I told him thats all I use, his mouth dropped. I moved it rather quickly with my JB. amazing! I was even able to stock pile a few small piles in rear of my lawn, Top soil, Stone, and mulch. As i need them this summer, I'll simply put Ole JB on, get what I need. I comes on and off easy. I did buy another hitch and wire harness my a smaller cub cadet 2165, It works ok, but you really need weight on rear, or it gets quite harry! The heavy JD and especially the power steering you can really move quick. And the best part is, when i'm done i'll disconnect it, and set it in the shed till i need it again, not like a 10k machine sitting around doing nothing! So I will say, i'm very happy I purchased my JB, w/ bucket extender, tooth bar, brush bars, quick dump actuator.
Sometimes it's better to try and not succeed then to never try and always wonder if you could have.
kskomro is offline
post #2 of 21 Old 04-13-2018, 09:55 PM
Willscary's Avatar
Re: Johnny Bucket on my John Deere X590 review
Yup, the JB jr is one of my best purchases also. As a homeowner and a construction guy, I weighed the cost of being able to lift a load vs how much I would need it. Since purchasing the JB jr, I have done many hours, many yards, and many tons of material moving with it. It is outstanding in moving and grading a pile of material, and not once have I needed to lift material higher than what the JB jr. can lift. I just can't see needing a 5 or 6 foot lift height as a homeowner. I am not uilding a new several story building or putting hay in a loft, I am taking care of my property and for that, the Johnny Bucket is absolutely awesome!
Nice review!
I own a 2017 Simplicity Prestige 27/52 EFI, JB Jr, Johnny Plow Jr.
From 2015 to 2017 I owned a used 2013 Simplicity Conquest 27/50.
From 1996 until 2015 I owned a White LT-16 Vanguard V-twin and 2 stage blower.
In 1991 I purchased a used 1984 Gilson 16 HP opposed twin. It was a horse!
Willscary is offline
post #3 of 21 Old 06-14-2018, 05:59 PM
Awesome review! Mine was just delivered for my GX355, I cant wait to get it installed and start getting some projects done.
Oiler is offline
post #4 of 21 Old 06-14-2018, 06:18 PM
ggsteve's Avatar
I love my JB Sr. You're right, piles of loam, mulch, or whatever disappear quickly with the JB around.
ggsteve
80 Cart
78 JD 316K 49 blower
Woods box blade
ggsteve is offline
post #5 of 21 Old 06-18-2018, 04:08 PM
erichardson's Avatar
I'm so jealous...
2013 John Deere X530
Addicted to AMSOIL!!
erichardson is offline
post #6 of 21 Old 06-22-2018, 01:02 PM
Don
How is the Johnny bucket different from the front scoop John Deere makes for the X590 ?
Don
post #7 of 21 Old 06-27-2018, 08:29 PM
Tech Exchange Moderator
Sergeant's Avatar
Well the Superior Tech Tractor Shovel has One electric actuator & John uses Two On the JBJr.
The STTS uses a clam shell design for Dumping the JBjr dumps in a traditional way Forward and doesn't require a Manual arm to change out Bracket for Dumping Like the STTS.
The STTS also Has a reinforcement Plate In the Middle Of the Bucket That Interferes with Bucket capacity . The JBjr doesn't have a Middle reinforcement Plate.
You Can also Trade out Your JBjr for a Blade That angles the STTS You can lift clam shell to doze straight a head Only.
You have several attachment available for the JBJr as well That increases it usefulness.
Such as the Bucket Doubler which allows to to Take On More Material with the Bucket.
There is a Tooth Bar to assist with excavating.
There is a Lawn Dethacher attachment to have a front Dethacher without removing the Bucket.
There is also Caddy Arms to Transport Longer Loads.
Even a Snow Shoe for the JB jr to allow snow Plowing with the Bucket,.
You Can even get a Faster dump actuator to speed Up dumping .
The STTS is really used for Transport of loose Loads and spread Material In Blade Position and some Light dozing
The JBjr Can Be used for some excavation, Snow, Transporting Bulky Loads.
The JBjr Is basically a Low Loader because so much More Can be done with it compared to the STTS
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
MSGT 11 & 18 Series Retired
Sergeant is offline
post #8 of 21 Old 06-28-2018, 11:36 PM
Don
Thank You Sergeant for that education on the Johnny Bucket. I probably wouldn't excavate with the Johnny Bucket I would use it to move mulch, topsoil, or plants. But I like that clam shell bucket John Deere has because I was thinking instead of scooping up mulch I could clam shell down on the pile of mulch or topsoil and move it or clam shell down on topsoil or mulch to level it out. It is half the price of the Johnny Bucket.
Don
post #9 of 21 Old 06-29-2018, 08:09 AM
ggsteve's Avatar
I'll be interested to see comments on this. I didn't think you could scoop as a clam shell, I thought you just dumped that way. Disclaimer - I have never used the Deere bucket so I may be completely wrong.
P.S. That is the best avatar I have ever seen
ggsteve
80 Cart
Woods box blade
ggsteve is offline
post #10 of 21 Old 06-29-2018, 08:59 AM
Don
It opens as a clam shell so can you have it open and go up to a pile of material, go down on the pile of material and close it. Or can you leave it open and be on the ground back dragging material.
Don
post #11 of 21 Old 06-29-2018, 12:36 PM
ggsteve's Avatar
I see. I watched a couple youtube videos.
ggsteve
80 Cart
Woods box blade
ggsteve is offline
post #12 of 21 Old 06-29-2018, 07:32 PM
Sergeant's Avatar
Well the Blade Portion of the Clam shell Can But the shovel Portion stays In a elevated Position when Open Here Take a Look at MTF Member stladrill 's video On His former X366SE with shovel and teeth Mods
White Model: GT2055
Sergeant is offline
post #13 of 21 Old 06-29-2018, 10:36 PM
Don
You know I thought it be like the four in one bucket on the one or two series tractors but it isn't.
Don
post #14 of 21 Old 06-30-2018, 11:51 AM
Willscary's Avatar
Have you watched my JB jr videos? Extremely useful tool that has paid for itself over and over in the short time I have owned it.
If you have not watched these and would like to, you have to click on the "YouTube" word in the bottom right of each window and watch them on the YouTube site. Apparently the links on this post do not allow you to watch directly in this window.
post #15 of 21 Old 06-30-2018, 12:02 PM
Don
You know I did watch all your videos. How long did it take to place dirt a long the driveway? I noticed you are barefoot too.
Its funny, I always wear these red wing steel toe boots and long pants when I'm operating my tractor. Even when it's 100 degrees out. The other day I cut the grass. Got off the tractor. Came inside to take my boots off and saw old roofing nails stuck in the bottom of my boots. I never felt the nails stuck in the bottom of the boots. Those boots saved my feet from injury. We just had our roof replaced and they ran a magnetic roller in the yard but I guess they missed some.
Don
