Ratchet rake vs debris rake - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 03-24-2019, 01:07 PM Thread Starter
RisingFriendRanch's Avatar
I have 250 acres of sage and bitter brush to remove. Quite a bit of it is 2"+ diameter so brush hogging is out. Interested in your opinions on the the ratchet rake and debris rake(like from Titan attachments).
RisingFriendRanch is offline
post #2 of 11 Old 03-24-2019, 01:27 PM
mrbeef's Avatar
Re: Ratchet rake vs debris rake
What type machine are you using? Weight and HP?
250 acres is a lot of ground to clear with anything less than a couple hundred horse dozer or excavator.
Maybe a mulching attachment depending on the machine you have.
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
post #3 of 11 Old 03-24-2019, 01:34 PM Thread Starter
I have a 2011 NH Boomer 35. I will be clearing in stages. The brush has come out really easily the times I have removed it with just the bucket. Plan was to push it into piles and burn the following fall/winter. I have thought about the dozer idea but the local equipment place wants $1200 plus for 16 hours on the machine.
post #4 of 11 Old 03-24-2019, 03:34 PM
Seppi M makes a 3 point forestry mulcher for small tractors. I wonder if any rental stores near you would have one available.
Cat385B is online now
post #5 of 11 Old 03-24-2019, 04:05 PM Thread Starter
When you use the mulcher are you guys getting much regrowth? The times I have brush hogged this stuff, it has regrown quite quickly.
post #6 of 11 Old 03-24-2019, 06:44 PM
Yep, almost like you just ****** all those little trees off a bit.
post #7 of 11 Old 03-24-2019, 08:39 PM Thread Starter
I was told by some people in my area that if you remove most of the root system then it is less likely to come back. That is why I was looking at the debris rake more since I can dig down into the roots.
post #8 of 11 Old 03-25-2019, 10:15 PM
no2498's Avatar
kill it in the spring you may need to do it a few times to kill it off all the way
john
no2498 is online now
post #9 of 11 Old 04-10-2019, 11:09 AM
I have been using a Ratchet Rake for clearing brush from a treeline and pulling out multiflower rose in one field. It does a good job and makes the chore much faster.
dilligaf1 is offline
post #10 of 11 Old 04-10-2019, 11:53 AM
Have Dog - Will Travel
Jere39's Avatar
I can honestly say I had never heard the term "Rachet Rake" before, so I googled it and watched some video. Looks like a handy attachment to a sturdy CUT and FEL. For What its Worth, my neighbor spent about 3 weeks running one of these on his 30 acre hill side and successfully machine handled stumps, brush piles, multiflower rose, various other briars, some mostly impenetrable by human, even my Brittany avoids them. I'm not sure this is a rentable item, it likely comes with an operator, and a tall hourly price tag. But, it worked:
Jere39 is online now
post #11 of 11 Old 04-10-2019, 11:59 AM
If I were in your boat, I'd seriously consider going with an herbicide option. Hire a crop duster and it's taken care of. Or rent a pull behind sprayer from the co-op if it has sufficient height clearance.
I think if you just mow, without spraying, you are just going to make them angry and get more regrowth. Which you are then going to have to mow. If you keep mowing, sooner or later you'll get them killed off. But a brush hog/forestry mulcher/etc. is not going to be a do it once and be done option.
TWG1572 is online now
Anyone have experience using a tow behind vac? JD317GA Gravely 65 10-03-2018 08:48 AM
Ratchet vs Breaker bar cygnusx1 MTD 28 04-13-2018 08:36 AM
X738 With Cyclone Rake Commander Pro retrofit RT3360 John Deere Forum 7 03-29-2018 04:46 PM
Box blade and landscape rake Duff Daddy John Deere Forum 41 03-13-2018 10:05 AM
Rock Rake and Landscape help SteveKoz John Deere Forum 6 02-04-2018 11:19 AM
