hydrostatic - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 09-10-2019, 06:40 PM Thread Starter
Duramarc's Avatar
hydrostatic
So over the years my jd 855 pedal has become harder to press. Has anyone else experienced this?
it's become so bad I have to stomp on it to get it to move.
Duramarc is offline
post #2 of 6 Old 09-10-2019, 06:47 PM
Blank Space
Re: hydrostatic
I would be inspecting the linkage for obstructions or bent parts and I've have a can of spray lubricant in my hand to squirt every place that should move.
LS MT125
post #3 of 6 Old 09-10-2019, 08:52 PM
Professional Homeowner
steddy's Avatar
Re: hydrostatic
Agreed. Lube linkage pivot points. Could also be a bad bushing somewhere. Hopefully not something inside the hydro itself.
steddy is online now
post #4 of 6 Old 09-12-2019, 01:13 PM Thread Starter
Duramarc's Avatar
Re: hydrostatic
I think it may be inside
Duramarc is offline
post #5 of 6 Old 09-12-2019, 04:46 PM
20,000 Posts & Climbing
Re: hydrostatic
There isn't much inside that can cause your problem, but there is a bunch of stuff on the outside.
Note that I'm not discounting the possibility that the problem is inside, but the odds favour the pedal to transmission linkages as the source. Only after the linkages have been proven to operate freely and correctly do you consider opening a hydro.
TUDOR is offline
post #6 of 6 Old 09-12-2019, 05:15 PM
steddy's Avatar
Re: hydrostatic
Maybe disconnect the linkage right at the hydro? Might tell you where the drag is. However, if there’s a bad bushing in the linkage, the resistance from actuating the hydro might be just enough resistance to magnify a bind in the linkage (bushing).
Is it just as hard to move the pedal with and without engine running?
