Storage suggestions for chains etc - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 04-21-2019, 10:05 PM Thread Starter
Came across the pictured contraption but its expensive. Anyone with other ideas? Primarily to hold, chains, ropes, tools etc.
Northern Grits is offline
post #2 of 13 Old 04-22-2019, 02:09 AM
Re: Storage suggestions for chains etc
That looks pretty straightforward to make if you have a welder.
dave_r is offline
post #3 of 13 Old 04-23-2019, 04:45 PM Thread Starter
Thats the problem is I don't weld. Yet. Surprised not more after market options since seems to be a widespread problem.
Thanks
post #4 of 13 Old 04-23-2019, 08:24 PM
sld961's Avatar
If you have a Heavy Hitch, or other 2" receiver for your 3pt, you can get a cargo rack. I just got one for mine for chains, shovels, etc. I'm going to close in the sides with sheet metal or something so stuff doesn't fall out, and I'm going to add a couple vertical pipes on the sides to hold shovels and rakes. I also used it to hold some extra ballast in a pinch.
This one was $45 on Walmart.com.
sld961 is offline
post #5 of 13 Old 04-24-2019, 12:21 AM
Thanks
probably not big a market for it, as it wouldn't be that cheap, and it would need to mount to a variety of tractors (some with ROPS of varying dimensions, some without, some with cabs). You'd probably need to sell it for a couple hundred dollars, and maybe only sell what, a couple hundred a year? Lots of guys would pass on that, and just jam a shovel somewhere or rig up a pail, or make their own.
Nothing like the present to start learning to fab stuff...
It's a relatively simple project, and not particularly critical that you get all the welds perfect, or even particularly good.
dave_r is offline
post #6 of 13 Old 04-24-2019, 03:21 AM
Blank Space
Nothing above will protect anything from weather. And I definitely don't want anything THAT far out behind me. Turning with the FEL is bad enough let alone having another 4 feet or so behind me.
If you're handy at all, some people get a 3 point 'Carry All' and build a box to mount on it. Some add pipes for long handled tools. But again, none of what I've seen offers any weather protection as most are made of wood (which adds a lot of weight) with no cover.
I'm thinking about a carry all for other reasons, but I may get a footlocker type box to mount occasionally. They are covered and generally weathertight.
post #7 of 13 Old 04-24-2019, 03:26 AM
Blank Space
And that would just be for temporary use, on and off as needed when you don't have anything else on the 3 point. I used covered w/p 'ammo boxes' (I hate that term) mounted to the ROPS for smaller items like top link and hitch pins, rags, small flashlight, etc. They work better that the usually included tool, err .... pencil boxes because the lids open to the side so they don't run into the ROPS.
post #8 of 13 Old 04-24-2019, 03:36 AM
Blank Space
I don't generally like to make consecutive posts, but another thought. Anything on the 3 point will be limited to when you don't need the 3 point for anything else. Something mounted higher like the first one pictured above will be more useful to many. That can/could be mounted to the ROPS above the rear fenders.
For those of us with Backhoes, that adds another problem though as it would have to be easily removable. Not all that hard to rig up, but more complicated if you want it to hold much weight.
post #9 of 13 Old 04-24-2019, 09:37 AM
Retired & lovin it!
Newsman's Avatar
They're called that for a reason and it's uses are part of the reason you have the right to hate the term. The other name you used is also called that for a reason and you'd be lucky if you could get a screwdriver in it. So that would be completely useless.
MikeC
Newsman is offline
post #10 of 13 Old 04-24-2019, 10:15 AM
At $214 on Amazon, that is a bit pricey.
https://www.amazon.com/Great-Day-TT4...s%2C165&sr=8-7
Without a welder, one would just need to fall back on nuts & bolts & washers.
A suggestion would be that if you were to attach it to the ROPS as the original picture, get either a square tube or flat stock and bolt it to a metal box then attach it all to the ROPS or to the fenders. The lid would keep things from falling out. Likely get it all new for less than $40.
Box:
https://www.amazon.com/RanchEx-10242...HPH6H1RSWMJ8X1
Bar:
https://www.amazon.com/National-Hard...72JW3C3Y4BTWX5
Flaken is offline
post #11 of 13 Old 04-24-2019, 05:33 PM Thread Starter
All good info for me as a newbie. Especially to Flaken for the links on Amazon since I am an Amazon junkie. That very well may be the option I go with.
- Until I have time to learn to weld!
post #12 of 13 Old 04-25-2019, 11:46 PM
no2498's Avatar
a drill hack saw and angel iron your good to go. well some nuts an bolts too
thats how we all started
john
no2498 is online now
post #13 of 13 Old 05-02-2019, 12:57 PM
Metal or wire milk crate with some hardware cloth on the bottom so chains cant fall thru ,work pretty good,and the dirt will fall right thru off the chains..
I need to make some kind of carry rack for my tractors, its tough trying to drive one with a chain saw on the hood and hold it from sliding off..
I put chains in a home made tool box mounted under the seat,I used a piece of a old above ground swimming pool support that is shaped like a gutter on a house,it holds quite a lot of tools too..
Tractor-Holic is offline
Gotta have some storage chrispbrown27 WorkShops, Garage and Shed Discussions 31 04-09-2019 02:03 PM
Carb Kit Storage ZRT 800 WorkShops, Garage and Shed Discussions 4 01-05-2019 10:55 AM
X590 service engine light after winter storage Jay26 John Deere Forum 8 12-11-2018 12:10 AM
Shop Storage Cart Project rayjay Welding, Metalwork, and Fabricating 1 10-14-2018 01:27 PM
Shab-bee Enterprises Presents.... The Tie-Down Strap Storage Unit littletractorguy Backyard Round Table - L & G Tractor Related Topics 30 02-22-2010 12:24 PM
