Honda 5518 Problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 2 Old 03-17-2019, 06:53 PM Thread Starter
Honda 5518 Problem
I inherited a Honda 5518 when my sister moved to a retirement home. If needed it was to help with snow removal. Anyway, recently an attempt was made to start it, without success even though the motor turned over. A few more attempts and no motor movement. Finally even the dash lights went out. Any suggestions as to where to start looking for problems will be appreciated. Using a multimeter I did verify that the ground was OK.
John
in Baltimore
Avlnfrg is offline
post #2 of 2 Old 03-17-2019, 10:40 PM
Country1966?'s Avatar
Sorry to hear about your sister John.
Well it sounds like it has a dead battery for one thing so either jump it or put it on a battery charger. But before you even do that how long has it been sitting? is the gas stale?
if it has been sitting for over a year or two pump the gas out with a little manual pump you can get from tractor supply or Lowe's. Put fresh gas in, change the spark plug, charge the battery and then try it.
honestly once you get it started you should just have it completely serviced if you're not mechanical
Country1966? is online now
Honda 5518 Battery Hot Issue tbad1964 Introductions 3 10-13-2018 08:47 PM
Honda 5518 custom deck DDinVT Honda 3 10-12-2018 10:23 PM
New member with Honda 5518 JohnPainter Introductions 3 09-11-2018 06:22 AM
honda rt5000 5013 or 5518 plow with hydraulic angle control for sale in newington ct 43128 For Sale & Wanted to Buy (Your Location) 1 07-26-2018 02:27 AM
Honda 5518 PTO shaft removal 5518ca Honda 1 02-05-2018 06:39 AM
