John Deere 400: snowthrower bearing trouble - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 03-07-2019, 07:19 PM Thread Starter
Hello all,
I’ve been struggling away trying to get the left-side auger bearing off my model 50 snow thrower. The bearing is done and I can’t seem to get the inner race to slide off the shaft. I drove the shaft sideways and moved the bearing a bit but now the auger is hitting the housing on the opposite side. I don’t think I have room to get a gear puller on the bearing. Is the shaft meant to slide all the way through inside the auger pieces? Is heating up the inner race the solution here? I don’t have torches or I’d have tried that already. Any help or advice is appreciated. I’m in Canada and 400s and attachments seem pretty scarce. Thanks
Ryan
Ry18an is offline
post #2 of 3 Old 03-07-2019, 08:15 PM
Red Plaid is Timeless
grandpajay's Avatar
Re: John Deere 400: snowthrower bearing trouble
The driveshaft axle goes all the way through the auger. Have you loosened the eccentric collar on the inner bearing race? You'll need to loosen both collars and slide the shaft over. IIRC when I replaced the bearings, I made sure that the bearing plates were reinstalled from the outside to make future bearing replacement easier. I may not be remembering correctly, though.
1981 JD 400 K582. 60 deck, SSQA 50 snowblower, suspension seat, left side brakes, 2 pedal foot control, H5 with separate deck lift and 3PH. Home made 3PH, mini SSQA loader, landplane, 10 weight capacity hitch, stacking starter weights, fender extensions, LED lighting.
grandpajay is offline
post #3 of 3 Old 03-13-2019, 11:15 PM Thread Starter
Thanks! Yes eccentric collars are off. I’m going to try heating the bearings.
Ry18an is offline
Parts cross reference jrd Gravely FAQ and Stickies Section 75 10-13-2017 11:41 PM
The 318 John Deere Onan "Kustom Small Engine's" Re-build & Restoration project begins Hammerdown John Deere Forum 119 06-17-2013 08:50 AM
John Deere 400 light mod Brians445JD John Deere Forum 8 11-25-2012 08:52 PM
John Deere 400 no deck 98Murray What Is It Worth ? 3 11-16-2012 08:20 AM
