Help Identifying Disk Plow - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 23 Old 10-08-2018, 10:39 PM Thread Starter
Originally Posted by TWG1572 View Post
Call me crazy, but isn't this a smaller version of your plow? Looks green and maybe orange to me. Did Case make a disc plow?
Edit: can't get the pic to work. Look at the third plow down on this link
pffarmequipment
That looks an awfullot like it for sure.
Justin E is offline
post #17 of 23 Old 10-09-2018, 08:40 AM
Re: Help Identifying Disk Plow
Originally Posted by Justin E View Post
A few more
Justin:
The bottom picture, (post 14) showing the hitch, indicates to me the definite possibility of the plow being a
J I Case. Case had the Eagle Hitch 3 point hitch, from'54 to early 60's. It was an early version of a quick hitch and was not capable of swinging. To cure that problem the lower 3 point hitch mounts on the implement had a center pivot to allow the implement to "wag" behind the tractor. There should be a pin hole to keep it from swing, for use with "normal" 3 point hitch tractors. I see the large nut in the center in this picture.
Also, the gauge wheel has a really long hub, (post 15) which Case also had. Case implements in mid 50's had green trim/wheels. And the other color is Orange, not Red. It shows in some of your photos.
https://antiquetractorsforum.com/sho.../2212-Case-400
I include these pictures of a Case with a disc plow. This disc plow is NOT like yours because this one is adjustable to maybe throw left or right without turning over. The tractor, Case 400, is equipped with Eagle Hitch.
cyrus is offline
post #18 of 23 Old 10-11-2018, 07:12 PM Thread Starter
So I got on the JI Case page on Facebook and got this.
Justin E is offline
post #19 of 23 Old 10-12-2018, 07:56 AM
Excellent, you found a picture.
Here is a link to the CaseIH website with partsbook for equipment built by either company. The link should take you to the Case 301/302 Eagle Hitch disk plow. Built from '53 to '81.
https://partstore.caseih.com/us/part...58319ag5032073
I will be going to Atwood, TN tractor show, this Saturday. At junction of US 70A/79
cyrus is offline
post #20 of 23 Old 10-13-2018, 03:41 PM Thread Starter
https://partstore.caseih.com/us/pars...58319ag5032073
Thank you! I now know the parts I need. Just have to find them.
Justin E is offline
post #21 of 23 Old 10-14-2018, 07:22 AM
Justin:
copy the part numbers.
Google the part numbers and see what comes up. Never know, they might be available. Certain areas of the country use disk plows.
cyrus is offline
post #22 of 23 Old 10-14-2018, 03:13 PM Thread Starter
I've tried that and got nothing. I've emailed a few people that deal I'm older plows but haven't heard back. I'm thinking I'll order an induction bolt heater to get one off and see if I can find a steel casting place that'll cast the parts for me. Then I'll just have to get someone to make one arm and find two scraper blades.
Justin E is offline
post #23 of 23 Old 10-15-2018, 09:20 AM
Justin:
I just PM'd you.
cyrus is offline
