JD 112 leaking around brake - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Introductions For New Members. Tell us about yourself
post #1 of 4 Old 06-19-2019, 11:27 AM Thread Starter
Hello all! New to the forum, though I've been finding helpful advice here for years, so thanks! I recently picked up a Deere 112, type t0011, serial 266461m. electric lift. changed all the fluids and cleaned it up and it runs like a champ! However, when I parked it for a week or so I noticed a pool of oil under the rear end. It seems to be leaking around where the shaft comes out to the brake band. A couple of questions: Is this something I can replace without removing the transaxle? Also, which parts are likely to be at fault? Looking over the parts diagrams, I don't see a seal or gasket, so I'm not sure where to start with replacing parts. I have tried to attach a parts diagram of the transaxle gear assembly. I'm guessing that this would be the correct diagram, but which parts would I need? Will I need to replace the brake band since it has been soaked in oil, or can I clean it up with some brake cleaner and put it back on? Thanks in advance for any advice!
Name:	transaxle gears.JPG
skmartin is offline
post #2 of 4 Old 06-19-2019, 11:36 AM Thread Starter
Re: JD 112 leaking around brake
also, I apologize if this post didn't wind up in the right spot. I'm not sure how to get it into the JD lawn tractors part of the forum.
skmartin is offline
post #3 of 4 Old 06-19-2019, 01:57 PM
close enuff works for me
deereboy55's Avatar
Have done the seal before , jack up tractor,,remove tire ,unbolt and remove band brake assembly. Loosen set screw on brake drum ,and remove ( may need puller ) pry seal out and replace ,,seal is available at your deere dealer . Use brake cleaner on the brake band ,it will be fine .
deereboy55 is offline
post #4 of 4 Old 06-20-2019, 11:48 AM Thread Starter
Thanks Deereboy, I just ordered the part through my closest dealer, and hope to tackle this next week when the part comes in. Thanks for the help!
skmartin is offline
You may post new threads
You may post replies
