Kohler cv15s will not start - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Introductions For New Members. Tell us about yourself
post #1 of 7 Old 05-15-2019, 05:09 PM Thread Starter
Fuel pump was bad. replaced it. rebuilt the carb.. Installed a new pickup coil at the flywheel. used a business card to set the gap. have strong spark at the plug. have fuel to the carb.. Have a backfire at the exhaust. any reason it won't start. Tried either and that didn't work. It is getting gas to the plug. I could always put in a new plug, Any thoughts?
Dan Hewitt is offline
post #2 of 7 Old 05-16-2019, 12:26 AM
Re: Kohler cv15s will not start
Is this a new-to-you engine, or was it running fine before the fuel pump went bad?
You could check that you are getting good compression.
It's also possible the spark plug is bad, in that it doesn't spark when under compression, so you could try a new plug.
dave_r is offline
post #3 of 7 Old 05-16-2019, 07:51 AM Thread Starter
I will check the fly wheel key first. It has a new plug and strong spark.
post #4 of 7 Old 05-16-2019, 08:42 AM
Bad intake valve just did one on my 16 cvs cost was 65 dollars to have valves ground etc. I did the labor.
abu507 is offline
post #5 of 7 Old 05-16-2019, 09:14 AM
I have heard of people putting the coil on upside down.
rayjay is online now
post #6 of 7 Old 05-16-2019, 07:38 PM Thread Starter
Fly wheel key is sheared off. I'll get a new one tomorrow.
post #7 of 7 Old 05-16-2019, 11:58 PM
thanks for posting what the problem turned out to be.
dave_r is offline
shibaura s753 diesel engine won't start paulcalif Generators 2 11-25-2018 04:20 PM
Kohler Command CV15S Rebuild on GT225 Bassguitarist1985 John Deere Forum 48 11-08-2018 04:13 PM
JD 265 won't start - ignition switch? ericole John Deere Forum 17 08-09-2018 11:12 AM
Series 22 with Kohler 15hp. Will a Kohler 17hp fit. Is there Briggs holes underneath? Quick Cal Snapper Forum 7 07-22-2018 01:34 AM
LT155 - Kohler CV15S Will Not Run With PCV Connected superman22x John Deere Forum 5 05-27-2018 10:14 PM
You may post new threads
You may post replies
