Stuck!! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 36 Old 07-13-2019, 11:00 PM Thread Starter
Stuck!!
Hi
I have Mitsubishi 1800D tractor that I bought on Craigslist. I only needed a little tractor because I have 6 acres, and don't really do anything heavy duty. What I didn't know was that this tractor is almost unheard of, and nobody has any parts for it.
My problem is that as I was using it, it started binding up, and eventually stalled out. Now it is stuck in gear, but won't move. I can't get the gear stick out of gear, with or without the engine running. If I start it with the clutch depressed, as soon as I let the clutch out the engine stalls. Also, I can't move the high/Low selector either. I have tried rocking it backwards and forwards, but can't free anything up.
Does anyone have any ideas where to start looking? I really don't know much about tractors!
Thanks in advance
David
dheaslip is offline
post #2 of 36 Old 07-14-2019, 08:26 AM
tbrake08's Avatar
Re: Stuck!!
Sounds like shes definitely stuck in two gears. On the shifting levers suspecting they are down in front of the seat. Do they feel tight or loose ? When shifting while engine is off can you hear or feel them going between the gears on your shifting pattern ? Its possible that the collar that slides on transmission shaft has locked in 1,2 or 3,4.
tbrake08 is offline
post #3 of 36 Old 07-14-2019, 08:41 AM
MTF CSI
poncho62's Avatar
Re: Stuck!!
Moved this to the Chinese Tractors section. You will get more exposure there.
When you said small tractor, I took it to be a CUT tractor, someone correct me if I am wrong, thanks.
Ford LGT100
Ford LGT125
Ford LGT165
John Deere STX38
poncho62 is online now
post #4 of 36 Old 07-14-2019, 10:50 AM Thread Starter
Re: Stuck!!
Hi, and thanks for responding. The gear shifter is stuck absolutely solid and won't move at all, either with or without the engine running.
dheaslip is offline
post #5 of 36 Old 07-14-2019, 11:18 AM
Re: Stuck!!
That tractor is not unheard of but it is grey market. They can be good tractors but you can't walk into a tractor dealer and get parts. You may find a manual or parts list pfd online if you search for a bit.
Sounds like your shift forks have slipped out of position and you are jammed between gears. You may be able to access the linkage below the shifter boot if it has an access cover. I have not worked on your model so I don't know what you can access without splitting the tractor. Unfortunately you have to split most tractors to do much transmission work. If you have to do this, you will need a garage to work in with either some hoists, cranes, or at least a couple of floor Jack's, and a few jack stands. It is not a small job even on a small tractor, so plan on it taking a space in the garage for a week to month depending on what parts you order. I may be a good idea to replace the clutch and rebuild the transmission so you don't have to do it again soon.
Sent from my XT1254 using Tapatalk
4seasons is offline
post #6 of 36 Old 07-14-2019, 11:30 AM
tbrake08's Avatar
Re: Stuck!!
Is there a cover that the levers go thru ? Any pics you can add ?
tbrake08 is offline
post #7 of 36 Old 07-14-2019, 11:56 AM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
Re: Stuck!!
Hi
Thanks in advance
David
Were you in the middle of shifting gears, or just driving along when this happened?
If it came about slowly while you were simply driving, I would suspect it is not a case of grabbing two gears at the same time. That would have resulted in an abrupt halt with drive wheels skidding.
2WD or 4WD ? Has it got the correct tire sizes so both front and rear are turning in sync at the correct speed? Have you tried jacking it up so the wheels can turn freely / independently, relieving any driveline preload?
Did you check the oil level in the trans? Did you then drop the trans oil plug and check for "gray matter"? Grindings, bits of bearings or teeth?
As suggested, if you can, remove the shifter boot and see if you can lift the shifter out. You may be able to move the forks about with a big screw driver?
Would you be lucky enough to have a row of bolts around the top of the trans.... as in removeable top?
Larry ( in Southern Ontario )
Larry LGT 165 is offline
post #8 of 36 Old 07-14-2019, 04:12 PM
Kubota Ronin's Avatar
Re: Stuck!!
Just a heads-up... Mitsubishi is Japanese, not Chinese.
Agree jacking it off the ground and see if that relieves the bind.
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #9 of 36 Old 07-14-2019, 05:01 PM
20,000 Posts & Climbing
Re: Stuck!!
Moved again to the Grey Market forum for compact utility tractors (CUT).
TUDOR is offline
post #10 of 36 Old 07-14-2019, 05:18 PM
Re: Stuck!!
Three stars for you (In Japanese "Mitsu" = three, "b(h)oshi" = star, hence the Mitsubishi three-star logo.)
That's just an interesting fact...
Kubota AMX-3
Shibaura LT16B
post #11 of 36 Old 07-14-2019, 08:22 PM
Re: Stuck!!
Arigatou.
TUDOR is offline
post #12 of 36 Old 07-14-2019, 09:00 PM
Re: Stuck!!
Actually it was early and I remembered it wrong... Mitsubishi = "Three Diamonds". oi...
Anyhow you can upgrade for free.
Kubota AMX-3
Shibaura LT16B
post #13 of 36 Old 07-16-2019, 07:02 AM
Re: Stuck!!
That's a 4WD tractor correct? And you had it in 4WD, correct?
It's bound up. Get all 4 wheels up in the air and let it unwind and take the pressure off the driveline, and hope that you didn't break something. They're not like your AWD passenger vehicle-the 4WD isn't meant to operate on any hard surface, even dry ground.
DoItMyself is offline
post #14 of 36 Old 07-16-2019, 09:04 AM
Re: Stuck!!
suggested this a few days ago and have not heard back.
"2WD or 4WD ? Has it got the correct tire sizes so both front and rear are turning in sync at the correct speed? Have you tried jacking it up so the wheels can turn freely / independently, relieving any driveline preload?"
Hopefully it relieved the driveline preload and resolved the issue.
post #15 of 36 Old 07-16-2019, 10:28 AM Thread Starter
Re: Stuck!!
Hi
No, this is a 2WD.
At the moment the tractor is stuck on a soft surface and I'm having trouble jacking it up. I'm hoping I can get a friend to help me tow (drag it, since the rear wheels are locked) to some hard ground!
Thanks
David
dheaslip is offline
