lug tires on ice - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 23 Old 07-10-2019, 01:18 PM Thread Starter
Unhappy lug tires on ice
My Gt52XLSi does a great job of plowing snow, except when it decides it doesn't want to steer. I just installed a set of Snow Hogs hoping this will help. They look so nice I was thinking of putting lugs on the back, instead of the chains I run year around, until I heard lugs are totally useless on a blacktopped icy driveway. Anyone have any experience with this? I really don't want to run lugs and chains.
Oldaarpy is offline
post #2 of 23 Old 07-10-2019, 01:48 PM
Lance Skene's Avatar
Re: lug tires on ice
AG lugs such as what you find on a full size tractor are the ones that dont work on snow/ice... but ATV lug tires work rather well.
Lance
__________________
Cockshutt 50
Ford 861 Powermaster
Deutz Allis Front Mower
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
'57 Bolens Super RaM
Lance Skene is online now
post #3 of 23 Old 07-10-2019, 01:54 PM Thread Starter
Thanks! I'm considering buying a cheapy set from Walmart b/4 winter. Aarpy
Oldaarpy is offline
post #4 of 23 Old 07-10-2019, 02:08 PM
You can usually find some nice used ATV lugs pretty cheap, folks often swap out the tires on brand new quads and sell their take-offs, some Ive bought as cheap as $20 per tire, most Ive ever paid is $100 for two brand new Kenda Bearclaws, recently bought a set 4 Carlisle Badlands XTR radials for $120 and put them on both my MTDs.
Lance
__________________
Cockshutt 50
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
post #5 of 23 Old 07-10-2019, 02:21 PM Thread Starter
Nice!!!!!! They don't look like the standard lug tire that I'm use to. Aarpy
Oldaarpy is offline
post #6 of 23 Old 07-10-2019, 02:32 PM
Well if you mean standard lug as in an AG tractor tire... no, but those dont work well in the winter even on farm tractors... ATV tires dont come in that pattern and are made with a softer rubber.
Lance
__________________
Cockshutt 50
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
post #7 of 23 Old 07-10-2019, 02:38 PM
DURO Red Eagles on the Columbia pushing a 54" snowplow... Kenda Bearclaws on the Ford with FEL.... both have some extra rear ballast but neither have chains....
ID:	2386021   Click image for larger version
Lance
__________________
Cockshutt 50
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
post #8 of 23 Old 07-10-2019, 02:49 PM
The Ford came with these AG lugs which are great in dirt but they were completely useless in the winter so I swapped them out for the Bearclaws....
Lance
__________________
Cockshutt 50
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
post #9 of 23 Old 07-10-2019, 02:55 PM Thread Starter
Yep, those lugs on the bottom is what I was going to buy..won't now...thanks! Aren't many choices, snow/mud wise, for 23x10.5x12 tires. I mow with the Husky, too, so I can't run different size tires without changing them. Aarpy
Oldaarpy is offline
post #10 of 23 Old 07-10-2019, 02:58 PM Thread Starter
You saved me some money..much appreciated. aarpy
Oldaarpy is offline
post #11 of 23 Old 07-10-2019, 03:09 PM
Ya you dont want those AG lugs in the winter... but... if you put a differant size tire on the rear, say 2" larger, then you can add 2" to the front tires aswell so that the tractor is still level.... or... in many cases you can adjust the deck so that it sits level regardless of what tires you have. Plus since the ATV tires run lower air pressure than a turf or AG they dont actually lift the tractor by the full differance in tire size... a 25" ATV tire will actually only lift the rear of the tractor about 1/2" which is not significant enough to to notice in the finished cut. Ive tried it on many tractors and many brands of tractors... a 2" taller ATV rear tire has no noticable affect other than that you can now drive it in the winter.
Lance
__________________
Cockshutt 50
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
post #12 of 23 Old 07-10-2019, 04:30 PM Thread Starter
I'm not really worried about the tractor being level (the snow hogs dropped the front by about 1/4" according to the deck) but the back tires are only about 2" from the deck. Figuring a 25" tire would still give me 1" clearance I'd only need to be concerned about mounting and un-mounting the deck. It's a 52" fab deck and a bear to move around.(Dropping the front of the deck actually made it mow nicer, even though it's lower in the front than recommended.) How wide of a tire do I dare use to replace those that came with it? Aarpy
Oldaarpy is offline
post #13 of 23 Old 07-10-2019, 05:46 PM
Parts collector
mopar65pa's Avatar
Those bearclaws look great. I would love to get a pair of those for my JD300 that I only use for tilling and plowing snow. I have calcium fill V-treads on it now and run chains in the winter. They work ok but still spin on the driveway without ice and just snow. If there is ice they work great. I have a 6* slope so it can be a bugger at times.
I'd love to get a set of the bearclaws for the JD332 also just for mowing since I have a slopped yard.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #14 of 23 Old 07-10-2019, 06:38 PM Thread Starter
If I can run 23x10s I have a better selection to choose from(obviously I know squat about tires). I see a tire named Swamp Fox that looks promising, would you guys recommend Bear Claws for mowing and plowing? I'm running 55lb weights on the tires and have the locking differential.
Oldaarpy is offline
post #15 of 23 Old 07-10-2019, 06:58 PM
I think the softer rubber compound is what helps the most on the ATV tires in cold weather..and the low pressure,you can run them down to very low PSI ..
Also,2 ply tires seem to give better traction than stiffer 4 or 6 ply tires too..
Loading them with liquid ballast really helps too..
Tractor-Holic is offline
