Part 2, (W/Pictures Fixed) The Build to "Beware of Husqvarna Garden Tractors!" - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 29 Old 07-06-2019, 02:56 PM Thread Starter
FLHusqGT's Avatar
I want to thank ponch62, and the Administrators/ Forum Members I dont know by name, for their help in fixing my picture blunder that ultimately led to the solution to delete-start-over.
They were quick and professional with me and recognized all the work I had put in to bring this picture tutorial (or attempt) to this Forum.
Going back in time to JUN2018, Rebuilding my very expensive $3,000 piece of lawn furniture, into the Garden Tractor I thought I bought.
The chassis failed at 63hrs, 11 months after purchase. I now have 174.7 hrs on the meter, the first 100 hrs after rebuild, spent, exclusively using the Johnny Bucket. The JBJR is well built, and Im happy to report, Johnny Products know how to keep their word also. The JBJR is capable of more than they represent. Thank you, to Johnny Products.
JUL2018-
Turning a GT48DXLS into an actual Light Duty Garden Tractor.
I want to show the process as it unfolds as best I can, mistakes and all, to hopefully inspire someone in my position (with a buckled frame) that finds himself on the fence, questioning, if you can do this, or to just pay the $500 to $600 as quoted from the Dealer to have the same problem frame. It is my hope that the answer is "if that guy can do it....so can I".
This build will start with a $70 Harbor Freight canopy for shade. The Temperatures in July/Aug here in Florida are a Brutal 90F plus 80% to 100% humidity with a thunderstorm 4 times a week to interrupt the personal sweat shower.
My tractor is in pieces on the back porch, lawn, and canopy.
There are I think 27? sections or postings to get this whole thing up. If there is a detail you are interested in, let me know. Chances are, I have the picture, or the answer is still coming. I will be getting my originals that I archived on CD's, It was a big project.
Here is the new TS/ GT Chassis, (To be clear, UPS only charges $13. in shipping to your door from Husqvarna, Husqvarna charges the Dealer $90. in special freight to ship to your Dealer. I went with UPS)
ID:	2385137   Click image for larger version
ID:	2385139   Click image for larger version
ID:	2385141   Click image for larger version
ID:	2385145   Click image for larger version
ID:	2385147   Click image for larger version
ID:	2385149   Click image for larger version
Be Aware, Husqvarna does not build Garden Tractors!
FLHusqGT is online now
post #2 of 29 Old 07-06-2019, 03:29 PM Thread Starter
FLHusqGT's Avatar
Re: Part 2, (W/Pictures Fixed) The Build to "Beware of Husqvarna Garden Tractors!"
01JUL2018,
The 1/4" x 3" x 60" flat bar being prepped for the fabricators. The 2 rails are 25 lbs, the frame is 26 lbs.
I'm using HF transfer punch set, they were sized correct to ensure that the center would be dimpled to keep the over 50 holes as accurate as possible, thanks to machine forums.
A look at the rest of it in waiting on the porch with the complete manual I constructed of the Tractor, Kawasaki, Tuff Torq, Parts list's, Trouble Shooting and Transaxle Maintenance, all laminated. The reason for laminating? Greasy fingers, torrential rain, and torrential rain. I got tired of wet soggy pages I would have to remake.
This is the HF 12 speed drill press I bought for the job. The holes were to be drilled at 250 to 400 rpm with plenty of cutting oil to keep the bits cool so they would not dull. I also bought Cle-Line 15 bit set, 135 degree split points that were well worth the money for a project this size with 1/4" steel. They were cool to the touch and didn't dull (another piece of good advice, I was tired of bits going dull to quick). The oil I used was 30 wt, and dispensed it out of a $10 oil can that had a long spout. I just kept the bits oiled and used a steady hand, with a lot of patience. (all day plus the next morning)
ID:	2385187   Click image for larger version
ID:	2385189   Click image for larger version
ID:	2385191   Click image for larger version
ID:	2385195   Click image for larger version
ID:	2385197   Click image for larger version
post #3 of 29 Old 07-06-2019, 03:35 PM Thread Starter
FLHusqGT's Avatar
01JUL2018-02JUL2018,
More project pictures,
Those are 3/8 bolts holding that wood on solid for flat drilling surface.
I ended up drilling most holes 2 sizes over with the edges deburred on both sides. My logic on this was that as careful as I was, I noticed that the holes would still have miner alignment issues. I wanted the fabricators to be able to weld without having to chance fixing my work (they are pro's I'm not!). I also made sure that the bar would be perfectly flat on both sides with out it biting me when I was bolting it back together (guaranteed no burrs)
ID:	2385201   Click image for larger version
ID:	2385203   Click image for larger version
ID:	2385205   Click image for larger version
ID:	2385209   Click image for larger version
ID:	2385211   Click image for larger version
post #4 of 29 Old 07-06-2019, 03:43 PM Thread Starter
FLHusqGT's Avatar
02JUL2018, 03JUL2018
My part is almost finished!
By the way, I did wipe them down in WD40 to keep them from flash rusting.
I'm getting these ready to use paint to color the square holes that are going to be punched by the pro's for $1 each, well worth it!
That's 3M painters tape. I used an ex-acto knife to cut out the squares and black spray paint. The surface was prepped with acetone and denatured alcohol.
ID:	2385215   Click image for larger version
ID:	2385217   Click image for larger version
ID:	2385219   Click image for larger version
ID:	2385223   Click image for larger version
ID:	2385225   Click image for larger version
ID:	2385227   Click image for larger version
ID:	2385231   Click image for larger version
post #5 of 29 Old 07-06-2019, 03:44 PM Thread Starter
FLHusqGT's Avatar
04JUL2018
next was to prep the frame for welding using any number of tools to sand paint away from all potential spots to be welded by a minimum of 1". I did all the sides and 2" just to be sure. The best tool was the 3M Roloc Bristle Disc (green) 18527, 3" with a die grinder for the 15,000 to 20,000 rpms. They are great for head gaskets too, they don't harm the metal and they are truly fast and easy. The corners and edges were done with a Dremel.
post #6 of 29 Old 07-06-2019, 04:13 PM Thread Starter
FLHusqGT's Avatar
17JUL2018,
My modified frame is back and I had the brilliant idea to paint this myself with rattle cans.
I was using the mouse to scuff the surface, not clean to bare metal.
Below is how it turned out with 4 layers of primer 92-94F and 90%+ humidity.
Yep, bad idea. It was terrible. The paint would dry hitting the metal and that soft surface is the powder like feel that would just rub off. Too Hot, To dirty, and TOO Much humidity to paint.
I opted to have powder coaters in Tampa (another hour + away) get the job done right.
ID:	2385237   Click image for larger version
ID:	2385239   Click image for larger version
ID:	2385241   Click image for larger version
post #7 of 29 Old 07-06-2019, 04:17 PM Thread Starter
FLHusqGT's Avatar
30JUL2018,
$100 at the powder coaters and it was well worth it. The original quote was $150 but it came out at $100. They know how to keep their word too.
ID:	2385245   Click image for larger version
ID:	2385247   Click image for larger version
ID:	2385249   Click image for larger version
ID:	2385253   Click image for larger version
post #8 of 29 Old 07-06-2019, 04:24 PM Thread Starter
FLHusqGT's Avatar
12AUG2018, Time to transfer the motor and transaxle to the new frame. I created a way to safely hold the motor until I installed it.
this was easy and I could quickly roll it around out of the way. The movers dolly is HF, been used for many things.
The bolt at the bottom of the motor shaft came out easiest with a impact wrench while using the old belt on the drive pully (twisting it tight so as to not allow slippage and to not do anything damaging to the pulley. The HF air tank is modified to be able to use air tools but won't last long. I get about 3 or 4 good uses with the impact.
Out with the old chassis,
In with the new chassis,
ID:	2385257   Click image for larger version
ID:	2385259   Click image for larger version
ID:	2385261   Click image for larger version
post #9 of 29 Old 07-06-2019, 04:32 PM Thread Starter
FLHusqGT's Avatar
12AUG2018 more stuff
I decided to go with a Kevlar drive belt. The stock belt had less surface area in contact with the pulley.
the old belt;
the Kevlar belt, Minor difference, but Ill take it;
Having the belts stretched out;
This is the actual code for the drive belt, the one from Husqvarna is not actually terrible in price, the one for the fabricated deck is!
The deck belt (fabricated clear cut decks only) is 4LK1360 1/2x136 (AK134).
This is the drive belt package;
notice the Ariens part #, its common for many different makes and has a Stens # too.
Starting to fit parts together;
ID:	2385267   Click image for larger version
ID:	2385269   Click image for larger version
ID:	2385271   Click image for larger version
ID:	2385275   Click image for larger version
ID:	2385277   Click image for larger version
post #10 of 29 Old 07-06-2019, 05:49 PM
RT3360's Avatar
So what were you doing when the frame bent? I had a GTH27V52LS, but sold it to the widow I have helped mow with it the last 4 summers plus this one. I wouldnt want her to have a problem with it. All Ive used it for is mowing.
If I should be adding stiffeners, Id like to do it before theres an issue. It mows so good Id like it to keep working as long as she needs it and shes about 85. Yep and she still mows most every week.
It looks like you welded the 1/4 plates on the inside of the frame. Did that cause you any issues with bolts or need to add bigger washers to cover the oversized holes?
Sorry to interrupt your thread.
Thanks in advance.
Craftsman DLT2000, 48
Ariens ST824 snowblower
RT3360 is offline
post #11 of 29 Old 07-06-2019, 06:32 PM Thread Starter
FLHusqGT's Avatar
This is a very easy transaxle to perform oil changes on, the down side is that little reservoir bottle. The bottle is an expansion tank not under pressure. The pump fluid gets hot and expands into the bottle as needed and as it cools goes back into the pump chamber. So far so good.
The bad is that the bottle does not have a very secure way of sealing to the upper case. It can be bumped, leak, and you wont know because the clearest observation of that connection is through the right wheel and not the back.
If the Dealer installs it carelessly, in a hurry, your transaxle could be set up to fail from the start and remember what the warranty is? Good to check.
Mine did not leak but could have. I have an idea for this too involving a JD Dealer. From Tuff Torq the bottle and means to allow fluid to go in are up to the manufacturer, JD uses a hose to pipe fitting with hose clamps for a solid connection. Husqvarna hopes that the connection will just stay based on the bottle hopefully not moving.
Notice the straight piece of plastic from the bottle to the transaxle. The end that inserts into the transaxle is plastic and is over an steel tube. The bottle pushes down on a flimsy mount that is supposed to cup it in place. The bottle can move back with vibration and the hard plastic seal will work its way out. I will fix this by next trans oil change and share pictures.
Until then,
If you still believe Husqvarna over the manufacturer (Tuff Torq) that the transaxle is maintnance free, here is the oil at 63hrs, and 11 months of use,
Just imagine what it would look like after the warranty was up......
Tuff Torq says, first 50 hrs, then depending on use, every 50 to 200 hrs or somewhere in between. I was told specifically, if using for heavy ground engagement work, in high temps, go with 50 hr changes. The oil has to be certified for "wet clutch" applications, meaning "JASO MA-2" API certified. The weight can be 5W-50 or 10W-50 synthetic, in the heaviest conditions and use, or their 30w oil in light use. Translate "light use" as mowing grass. "heavy use" as moving dirt in some way.
Its not about getting it cheaper, just having the right oil for the intended conditions. This is not an endorsement, just what I use for heavy, hot conditions, approved by Tuff Torq
I have attached the Official Tuff Torq K66 oil change procedure, recommendation, and their lubricant chart with part numbers. The K66 schematic and part list will be included later. All of them can be found on their page but these came direct from Tuff Torq in an email to me, with answers. Tuff Torq can keep their word too.
ID:	2385297   Click image for larger version
ID:	2385299   Click image for larger version
ID:	2385301   Click image for larger version
ID:	2385305   Click image for larger version
ID:	2385307   Click image for larger version
File Type: pdf cc K62 & K66 Oil Changing Procedure.pdf (1.53 MB, 2 views)
post #12 of 29 Old 07-06-2019, 07:05 PM Thread Starter
FLHusqGT's Avatar
14AUG2018
The drive belt guide on the transaxle input pulley was bent and able to dig into the belt. This is how I solved that problem,
Doing yet another re-fit, lots of re-fits until it was right,
ID:	2385327   Click image for larger version
ID:	2385329   Click image for larger version
ID:	2385331   Click image for larger version
post #13 of 29 Old 07-06-2019, 07:17 PM Thread Starter
FLHusqGT's Avatar
14AUG2018,
Time to get the pedals, rods for brake and transaxle motion connected and adjusted.
Also the all important cruise control, I'm sure I'll find a use for it sometime?
More pictures and views,
ID:	2385337   Click image for larger version
ID:	2385339   Click image for larger version
ID:	2385341   Click image for larger version
ID:	2385345   Click image for larger version
ID:	2385347   Click image for larger version
ID:	2385349   Click image for larger version
post #14 of 29 Old 07-06-2019, 07:24 PM Thread Starter
FLHusqGT's Avatar
This is how I bled the transaxle. Yes it is self bleeding but It is still recommended to bleed it first, so...
I put the bolt on the input shaft, switched the power speed in the drill to 2 (high) and ripped through one battery charge. The axles barely moved at first but after a few forward input at the pedal and reverse input while spinning the input shaft, it came to life. Bled, done.
another problem was the weak return spring on the brake pedal arm at the transaxle. It would have been ok, but it was slow and I had a 2 pound spring that I put on it that makes sure it is always to the rear (disengaged) unless I want brake applied, cheap upgrade that has worked well.
In the above pictures those are 3/8"x 2" to 3" Stainless Steel bolts and large oversized washers on the inside and regular washers on the outside, with nylon lock nuts.
The frame is reinforced with this in the most critical places. This adds one more extra layer of clamping force to the welded frame.
ID:	2385353   Click image for larger version
post #15 of 29 Old 07-06-2019, 07:33 PM Thread Starter
FLHusqGT's Avatar
16AUG2018,
This is one of the two steering support brackets that had to be cut by 1/4" on each side, and welded to fit in the new frame. Cost on this was $159.86, for two new modified plates.
some extras,
ID:	2385357   Click image for larger version
ID:	2385359   Click image for larger version
ID:	2385361   Click image for larger version
ID:	2385365   Click image for larger version
ID:	2385367   Click image for larger version
MISparty
