Trashed transaxle - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 06-08-2009, 04:46 PM Thread Starter
roobarrb's Avatar
Yikes Trashed transaxle
The transaxle on my 1994 12.5hp MTD 444 (sold as Lawnflite here in UK) has literally fallen apart. While mowing, the axle on left hand side, complete with wheel, started to slide out of the housing leaving me freewheeling down a hill with no brake. Luckily I pitched head-on into a tree before the wheel and axle actually came right off!
I pulled the axle out and it has a threaded end that still seems to be intact. Can this be fixed easily? Would it require a whole new axle?
Thanks
roobarrb is offline
post #2 of 14 Old 06-08-2009, 04:50 PM
The Travelin' Mod
davidg's Avatar
Re: Trashed transaxle
dunno, need the model numbers and manufacturer of the tranny to tell. just giving the machine model does nothing, as so many identical numbered machiens here will have totally different parts.
Check out our new HOMEPAGE
davidg is online now
post #3 of 14 Old 06-08-2009, 05:31 PM
Retired Aug.31 2007
jeepersmitty's Avatar
Welcome to the forum. If you can get some numbers I am sure someone can help you.
I always know...
jeepersmitty is offline
post #4 of 14 Old 06-08-2009, 09:30 PM Thread Starter
roobarrb's Avatar
Hi
Model number is 135h450e611
Hope this helps
roobarrb is offline
post #5 of 14 Old 06-11-2009, 08:21 AM Thread Starter
roobarrb's Avatar
This may be a dumb question, but do I have to remove the drivebelt before removing the transaxle?
Any help gratefully received... my grass is getting very long.
roobarrb is offline
post #6 of 14 Old 06-12-2009, 03:15 PM
Simplicity Benn
Benn's Avatar
welcome to the forum btw! im sure someone here will lead u in the right direction
Benn is offline
post #7 of 14 Old 06-13-2009, 08:14 AM
yes, easiest to just remove the bolt and pop that large pulley off before dropping th trans down
kcp877 is offline
post #8 of 14 Old 06-13-2009, 06:45 PM
Collector of many tractors
Kbeitz's Avatar
Screw it back in... With a little lock-tight...
Kbeitz is offline
post #9 of 14 Old 06-16-2009, 02:50 PM Thread Starter
roobarrb's Avatar
Thanks for the suggestions.
I tried pushing axle back into housing but something stops it from going in the last inch or two.
Guess I'll have to resort to surgery.
roobarrb is offline
post #10 of 14 Old 10-06-2019, 12:57 PM Thread Starter
roobarrb's Avatar
This is probably the longest time ever to write a follow-up!
Well the tractor sat under a tarpaulin in the yard since I wrote the above post in 2009.
Last week I decided to fix it. Stripped axle out, took it apart, and found a single nut holding the half-shaft in place had come off. That was it. Quick fix but it took me ten years!
Amazingly, a bit more messing about and I got the engine to start and she's running really well.
Only problem is there's a lot of slop in the axle pivot, meaning when I steer the whole axle moves backwards and forwards.
It's really not worth putting in new parts - and used ones are hard to come by here in Scotland.
Has anyone tried using shims or washers to fix this?
Thanks.
roobarrb is offline
post #11 of 14 Old 10-06-2019, 02:23 PM
Parts collector
mopar65pa's Avatar
Dang man 10 years to find out a nut came loose. LOL............
I am assuming you mean the front axle. solid cast or stamped metal? You can get a new bolt and bushings to solve that problem.
Good luck.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #12 of 14 Old 10-06-2019, 04:29 PM
Thanks.
Better late than never, eh? :P
I can't help with specifics as I'm entirely ignorant of the details on the unit, but I would put in a bushing/weld/shim to secure it. I'm betting that if it is shifting around it will only serve to make things worse. Depending on the gap you're trying to close, I would look at polyeutrathane automotive bushings. Is there perhaps some parts you may have missed during reassembly?
If you can take some pictures; you'll get much better advice. If you take pictures and start a new thread (perhaps link to this one for context on original problem) you'll likely get even better answers.
Bobcat M610
Bolens 750
M&W LC 1890K Zero turn 54"
dtsh is offline
post #13 of 14 Old 10-06-2019, 05:42 PM Thread Starter
roobarrb's Avatar
Thanks for your help, guys.
I should have made clear it is a front axle problem.
I'll have a go at posting some pictures.
roobarrb is offline
post #14 of 14 Old 10-12-2019, 06:27 PM
there may be a centre bolt on the front axle that's loose. Or there's a tube piece that's worn. I'd need to look at mine. I have a parts 400 series that's needs to be disassembled soon.
38racing is offline
