MTD 990 Kit - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 107 Old 07-14-2019, 04:11 PM Thread Starter
VTXRider's Avatar
MTD 990 Kit
This was posted on FB marketplace in the Detroit area. The owner offered to exchange halfway. About 1hr 20mins drive. This was a restore project that the owner lost interest. Everything but a seat and seat spring. This was a working tractor used to mow the Wayne State Univ. campus.
3pt hitch, good tires, good dash tower, engine honed, carb rebuilt, mower deck is nice but needs spindle bearings replaced.
1979 with a 1978 engine. Stickers are still on the dash tower.
$150 for the lot. Needless to say I am delighted.
ID:	2386541   Click image for larger version
ID:	2386543   Click image for larger version
ID:	2386545   Click image for larger version
ID:	2386549   Click image for larger version
ID:	2386551   Click image for larger version
ID:	2386553   Click image for larger version
ID:	2386557   Click image for larger version
Chuck L
3 Late Model MTD 990s - (2 1980 Farm Kings and 1981 Wizard), 1979 Farm King, 1978 Farm King, 1973 Farm King for parts. Craftsman DTY4000, DLT2000.
Implements: Haban 42" snow blower, 3-PT Carry All, 3-PT Winch Boom, 50" Mower Deck, 50" Rear Blade, 54" Front Blade, 4500w Generator, MTD 990 Rear Tiller.
8hp MTD Snow Blower, 2004 Honda VTX1300 Motorcycle.
KG8NS Walker, Michigan
VTXRider is online now
post #2 of 107 Old 07-15-2019, 11:26 AM
Lance Skene's Avatar
Re: MTD 990 Kit
That was a good score... quite the puzzle tho... should keep you busy for a few days..Lol
Lance Skene is offline
post #3 of 107 Old 07-15-2019, 12:32 PM Thread Starter
VTXRider's Avatar
Re: MTD 990 Kit
I got the tires on and the wheels mounted so it is rolling and steering.
Chuck L
post #4 of 107 Old 07-15-2019, 01:01 PM
Re: MTD 990 Kit
Lookin alot better already
post #5 of 107 Old 07-15-2019, 01:29 PM
burned300's Avatar
Re: MTD 990 Kit
Great Score!
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #6 of 107 Old 07-15-2019, 01:45 PM
B440's Avatar
Re: MTD 990 Kit
Great puzzle! I like those.
B440 is online now
post #7 of 107 Old 07-15-2019, 01:58 PM
Re: MTD 990 Kit
I think I'll tag along.
Interesting to see what you end up with.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #8 of 107 Old 07-15-2019, 11:12 PM
Hammerhead007's Avatar
Re: MTD 990 Kit
Great score!!! I'm on board as well. Can't waite to see how this looks when you're done.
Hammerhead007 is offline
post #9 of 107 Old 07-16-2019, 11:03 AM Thread Starter
VTXRider's Avatar
Re: MTD 990 Kit
The 50" deck is not as nice as it looks so it is parted out.
The blade baffle is gone, the gear box is cracked on the top side, and two of the three blade spindles need bearings. I will replace the bearings and sell the spindle set. Will sell the idler pulleys also, which are tight.
Chuck L
post #10 of 107 Old 07-16-2019, 05:26 PM Thread Starter
VTXRider's Avatar
Re: MTD 990 Kit
Found the spindles to be unobtainium. MTD part number 741-0211 or 941-0211.
So the spindles are scrap.
Looks like the bearings may be pressed into the outer shell.
Anyone ever try to press the bearings and spindle out of these?
Chuck L
post #11 of 107 Old 07-16-2019, 05:34 PM
kklowell's Avatar
Re: MTD 990 Kit
That's a great score.
kklowell is online now
post #12 of 107 Old 07-17-2019, 10:42 AM
Re: MTD 990 Kit
Ive never had one apart so cant help ya there... but I have 2 or 3 old rusty 42" decks that I got from littletractorguy... if they have the same spindles I Might have a spare. I just recently put my Columbia deck on the 960 that I got from him and was surprised how quiet it is so I dont think I need any parts off those spare decks.
It may be possible to find some modern and readily available spindles/pulleys/blades and modify the deck to use those.... bit of grinding/welding involved but Im sure it wouldnt be too hard to do.
post #13 of 107 Old 07-17-2019, 10:52 AM Thread Starter
VTXRider's Avatar
Re: MTD 990 Kit
I already have a nice 50" deck so I will just keep some of the spares and sell the extras.
My deck has easily replaceable spindle bearings.
Chuck L
post #14 of 107 Old 07-26-2019, 03:49 PM Thread Starter
VTXRider's Avatar
Re: MTD 990 Kit
The deck spindles do not want to be pressed apart so they are in the scrap pile.
Both drive shaft u-joints are bad. I do not like that task.
The charge pump makes a noise I never heard before. I can hear the 6 carrier rollers clicking as the shaft is rotated by hand. I am not sure if this a bad thing.
ID:	2388093   Click image for larger version
Chuck L
post #15 of 107 Old 07-26-2019, 04:00 PM
Re: MTD 990 Kit
Are you sure the spindles press apart? For my Gravely zeroturn (which Gravely would prefer I buy whole new spindles for when they wear out), my dad figured out that the spindle shaft was screwed together (like a nut & bolt, just without the hexes), with a dose of red loctite to require heat to get it apart. Saved me a bunch of money by just replacing the bearings...
Maybe use an angle grinder with a cutting wheel to cut one of the old spindles in half (in the direction the spindle is) and see how the spindle goes together?
dave_r is offline
