Need a mower deck hub for a MTD 990 deck - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 05-18-2019, 02:09 PM Thread Starter
Where can I get parts, new or used for a mower deck?
jblaise is offline
post #2 of 10 Old 05-18-2019, 02:23 PM
Re: Need a mower deck hub for a MTD 990 deck
Let us know where you are located??? I know of a couple places in West Michigan.
Here is one: https://www.schreiberssmallenginerepair.com/
wooserco is offline
post #3 of 10 Old 05-18-2019, 02:56 PM Thread Starter
Located in SE TX.
jblaise is offline
post #4 of 10 Old 05-18-2019, 04:44 PM
VTXRider's Avatar
We will need to know which deck you have. The 50" or 42". A picture of the deck and hub would help also.
Chuck L
3 Late Model MTD 990s - (2 1980 Farm Kings and 1981 Wizard), 1978 Farm King, 1973 Farm King, 1973 Farm King for parts. Craftsman DTY4000, DLT2000.
Implements: Restored Sears FEL not mounted yet, Haban 42" snow blower, 3-PT Carry All, 3-PT Winch Boom, 50" Mower Deck, 50" Rear Blade, 2 - 54" Front Blades, 4500w Generator, MTD 990 Rear Tiller.
8hp MTD Snow Blower, 2004 Honda VTX1300 Motorcycle.
KG8NS Walker, Michigan
VTXRider is offline
post #5 of 10 Old 05-18-2019, 08:57 PM Thread Starter
Thanks, Chuck. It's a 50 inch deck but about 1200 miles from me. A couple pix of the pully below.
ID:	2377163   Click image for larger version
jblaise is offline
post #6 of 10 Old 05-19-2019, 08:36 AM
VTXRider's Avatar
Welcome to the forum.
You have the 6 bolt hub, which is the last version. Earlier hubs were 3 bolt.
Good news is the bearings are still available. Spindle Bearings 741-0919 SKF-6204 2RSJEM.
Bad news is the spindle is no longer available. If it is bent, then you may have to find another deck for parts or hope someone on the forum has one to sell. A search shows spindles listed on Ebay and Google but they are expensive.
There seems to be 2 different spindles depending which 50" deck you have.
PN 741-0211 and 738-469B. I think yours is the later. Both show up in a Google search.
The manuals are attached.
File Type: pdf MTD 190-993 50 QD mower deck 770-5334h.pdf (746.6 KB, 6 views)
File Type: pdf MTD 198-992A 50 QD mower deck 770-7898.pdf (1.11 MB, 6 views)
Chuck L
VTXRider is offline
post #7 of 10 Old 05-19-2019, 05:30 PM Thread Starter
Thanks Chuck. I'll pursue that info. Meanwhile if anyone has a hub or deck for sale please contact me. I just had the motor rebuilt so it's too late to walk away now. And it wont be long before the weeds need mowing!
jblaise is offline
post #8 of 10 Old 05-20-2019, 04:44 PM Thread Starter
Chuck, looking at the 190-993 50 QD I'm not sure that is the manual for the 6 bolt hub? Possibly the 3 bolt? Or am I missing something? Thanks.
jblaise is offline
post #9 of 10 Old 05-20-2019, 04:49 PM
VTXRider's Avatar
The 6 bolt does not show in the the manual drawings. A three bolt hub will work. Are the bearings bad or is the spindle bent?
Do you need a complete assy?
Looking on Google search for 14199A spindle assy. The complete unit is available for $115.
https://www.propartsdirect.net/14199A-mtd.aspx
Several others available also.
It looks like Cub Cadet mowers use this spindle also.
Edit: My info in post #6 about the spindle assy and it's parts not being available is incorrect. But it is pricey.
Chuck L
VTXRider is offline
post #10 of 10 Old 05-21-2019, 09:12 PM Thread Starter
I disassembled the spindle assembly and cleaned things up. Not positive the spindle is straight but it does not appear to be bent. Best I can tell everything is ok except the pulley. I can't tell if the pulley has part of the old bearing still attached. I ordered bearings and should know if I have a problem when I try to put all the pieces back together.
I did find a pulley on eBay but the pic wasn't good enough to help me.
Thanks for the heads up on the complete assembly. I came across it too, but wasn't sure if it was the right one. I'm tempted to get it, just in case mine is bent. Prolly won't find out until I install and find too much vibration.
The tractor is about 1200 miles away and I would like to be able to install and run without a lot of delay when I get there. But I hear it's snowing up there so I prolly won't be going anywhere for a bit.
Thanks for all of your help Chuck! I really do appreciate it. I will let you know how things go.
jblaise is offline
Ford GT75 mower deck parts MikeSC Ford/Post 1990 New Holland 6 09-03-2018 09:01 PM
Anyone have the mower deck arms for GT3000? bobotech Craftsman/Sears Forum 1 06-28-2018 09:54 PM
Help with JD265 Lawn Tractor Mower deck please ericole John Deere Forum 5 06-15-2018 01:14 PM
Mower deck / tech manual decoding bbruyn John Deere Forum 4 06-15-2018 10:50 AM
