MF 1250 Water Pump Leak - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 1 Old 01-31-2019, 01:44 PM Thread Starter
1998 MF Tractor Model 1250 -Iseki TK532 3 cylinder 91.5 ci 490 hours on the tractor (Serial Number G-G1619).
Today i was using the tractor to move some items around. When I pulled the tractor back into the "garage" I notice a wet spot where the tractor was parked (when I was warming it up). I stopped the tractor and turned it off and there was warm water dripping down from the engine area. Pulled the side covers and notice nothing unusual.
Checked the hoses and they appeared intact. Started the engine again and looked to see if I could see any leakage. I could not really see any leaks but some "steam" under the water pump area.
Engine coolant temperature was low on the peg before I started it the first time and was in the normal range as I operated it and after I re-started it.
I am assuming the water pump seal is leaking and I should replace the water pump.
From what I have read here it appears I should take the radiator out and have it serviced since it would be easier to replace the water pump with it out and of course new hoses.
This is the first major issue I have had with this tractor since I owned it (from new)
Questions:
1. I contacted the dealer that sold me the tractor in 1998 and he will come pick up the tractor (about 90 mile round trip)
replace the water pump ($350) and hoses. Total price about $1,200. Is this a reasonable price?
2. I could try and repair it myself, it does not appear to be that difficult a job but does require actual work. I have a "manual" (see pic) but it is not as detailed as I would like. Is there a better manual for this tractor?
Thanks.
carolinarider is offline
New LS MT125 Mods. Bucket Level Rod and Fuel Transfer. Singalo The Shed 7 03-06-2019 06:11 PM
445 Water Pump & Radiator Replacement? Fishwater2002 John Deere Forum 13 12-24-2018 08:02 AM
Kawasaki 19hp water pump leak in JD 320 jimdelong John Deere Forum 1 09-10-2018 03:26 PM
Water Pump Replacement DRE97 John Deere Forum 15 04-30-2018 05:41 AM
1983 case 1845 tandem pump leak Brady.Murphy Hydraulics 0 12-17-2017 03:29 PM
