Kubota L4610 service time! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 05-12-2019, 04:14 PM Thread Starter
Professional Homeowner
steddy's Avatar
Ugh... $400 later, we’re good to go for many more hours. Kubota fuel, oil, hydraulic, and HST filters totaled about $140. Hydraulic fluid was about $216. Plus 2 gallons of Shell Rotella diesel oil.
The HST filter I’m thinking might have been original to the tractor in the early 2000s. All the other filters were Wix, but the HST one was still Kubota branded. Fluid itself didn’t seem too bad. Hydraulic filter sounded like there’s solids in it, and had a big chunk of silicone on it. HST filter was stuck but good. The housing twisted on the flange trying to loosen it with channelock pliers. A screwdriver and hammer prevailed where a spanner wrench was designed. Was a bit rusty on top.
My best friends today were a funnel with a flexi extension and a couple tarp straps. A 1 gallon ice cream pail made it real easy to pour in the hydraulic fluid a gallon at a time. I recommend this process to fill a hydraulic system when an oil pump isn’t handy. Sure made it easy. Same went for engine
Phone is being stupid. I’ll have to add slightly more interesting pictures later.
Overkill.
I love overkill.
I'm Ted.
(Click Here)
steddy is online now
post #2 of 3 Old 05-12-2019, 04:38 PM
We're all friends here
APinNY's Avatar
Re: Kubota L4610 service time!
HST oil usually looks clean. If the filter is that old, chances are the oil was too. As much as you use that tractor it was probably happy to get some maintenance. Then again, it's a Kubota. Who knows how long it would run without it.
Al
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #3 of 3 Old 05-12-2019, 07:14 PM Thread Starter
steddy's Avatar
More pictures...
Oil and fuel filters with easy to see information written on them. Lots of sediment in the fuel filter bowl. I had the presence of mind to write down the wix numbers in my notes to replace filters again down the road with aftermarket if I feel cheap when the tractor is old and I don’t care as much about it, and have ambition to research if Wix filters are as good or better than Kubota for 1/5 the price.
Not one, but TWO drain plugs on oil pan. There were also two drain plugs on the hydro system- one on the hydraulic reservoir and one on the trans. Very handy, since they drain independently and the entire system holds over 10 gallons. I was able to get about 7.5 drained out. I wasn’t going to screw with removing lines and draining the loader. Level may drop a little so I’ll add more if needed.
Next (and last) pic was the chunk of silicone found atop the hydraulic filter.
Next pic shows the funnel strapped in place to fill the engine oil. Used the same truck to fill the hydraulic reservoir back up.
Tip: ALWAYS label the new filters with date and hours changed at (or next service due information)).
ID:	2376327   Click image for larger version
ID:	2376329   Click image for larger version
ID:	2376331   Click image for larger version
ID:	2376335   Click image for larger version
Overkill.
I love overkill.
I'm Ted.
(Click Here)
Kubota L200 ring gear CrackerBarrel For Sale & Wanted to Buy (Your Location) 1 03-21-2019 04:31 PM
Kubota D722 Spokerider Small Engines and Repair 0 02-21-2019 12:05 PM
Kubota L3430 HST Transmission Problems gehdi Kubota 4 02-05-2019 05:45 PM
Sears Suburban Kubota Diesel Repower! Long time no post! ElectricalBen Craftsman/Sears Forum 8 01-15-2019 06:57 AM
Late season seat time Talntedmrgreen Simplicity/Allis Chalmers Forum 13 12-12-2012 11:14 AM
