Shed Ramp - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 36 Old 10-12-2019, 07:09 AM Thread Starter
Shed Ramp
I am finally building a shed for my X590. By the way you need 64 doors to accommodate a X590 with a 48 deck and PowerFlow and an inch on either side.
Its built with a pier and beam construction and as a result is about 18 off the ground. 1 subfloor, 6 floor joists, 8 beams, 4 pier. In retrospect Id have put the pier a bit lower. Hindsight is 20:20.
Is there any guidance on design or maximum ramp angle for the X590? Its all very nice having a shed, but not much use if I cant get the tractor in
jma24 is offline
post #2 of 36 Old 10-12-2019, 07:42 AM
Re: Shed Ramp
I'd put a piece of pressure treat in front of the opening and extending a few feet on either side...this will protect your siding. I'd then back fill to create a ramp. A few "test runs" will tell you if it's too steep and can be lengthened or shortened as needed. Bob
rwmeyer is online now
post #3 of 36 Old 10-12-2019, 09:33 AM
Re: Shed Ramp
As far as guidance or design, you could look at the ADA designs for wheelchair ramps. That will provide a nice gentle slope allowing the tractor & mowing deck to clear easily. Generally, it is a 1:12 ratio, or for a 1 foot rise the ramp would be 12 feet long. Adjust to your own needs.
Flaken is online now
post #4 of 36 Old 10-12-2019, 09:44 AM
Have Dog - Will Travel
Jere39's Avatar
Re: Shed Ramp
Good start on your shed. I chose a pre-built shed about 15 years ago, but had it set on a 12" high stone pad. So, coupled with the floor substructure of the shed, I needed a ramp about the same height you do. Here is an old thread of my construction, pre-built setting, and ramp design/construction:
https://www.mytractorforum.com/52-wo...cess-ramp.html
Two things I chose to do that may be useful:
1 - I sawed off the top of my ramp joist to make a better final approach angle to my shed (see the pictures)
2 - I did not connect the ramp to the shed - allowing them to settle and shift (due to frost heave in my area) independently. This has worked well, 15 years later, and no maintenance needed on either.
Good luck, hope you wrap up construction before the snow flies!
Jere39 is offline
post #5 of 36 Old 10-12-2019, 09:47 AM
Re: Shed Ramp
Consider making the ramp curved so that you don't bottom out at the threshold. What material do you plan to make the ramp out of?
LLigetfa is online now
post #6 of 36 Old 10-12-2019, 10:03 AM
20,000 Posts & Climbing
Re: Shed Ramp
There are 3 different critical angles depending on the attachment.
Snow thrower/blower - The angle formed from the ground when a straightedge is touching the ground contact patch of the front tire and the lowest point of the thrower/blower in its raised position. This is the maximum front departure angle at the bottom of the ramp
Mid mount mower deck - The angle formed between the front and rear tire ground contact patches and the middle of the deck shell edge when fully raised. This is the maximum angle between the ramp and the shed floor.
Rear implement - The angle formed between the rear tire ground contact patch and the bottom of the implement in its raised position. This is the rear departure angle at the bottom of the ramp.
Hint: Use something less that the maximum angle just in case a tire develops a slow leak.
A berm in front of the door as suggested by rwmeyer would be a good starting point. You will likely need at least 7-9' of ramp from the edge of the floor to grade to cover all three angles.
An inclinometer would be a handy tool, or a digital level. Otherwise your left with calculating the geometry of a triangle, or trial and error.
TUDOR is offline
post #7 of 36 Old 10-12-2019, 10:14 AM
Re: Shed Ramp
Depending on your location and usage, will it be damp, winter usage, etc.
There is nothing slicker than a board when it's wet.
The deck needs to clear the apex going in and out.
My 16' trailer with fold down ramp is somewhat steep and gets petty close to the deck at transition from ramp to trailer, it has a four foot fold down ramp and the trailer sits about 16" of the ground. I try to find a low spot to load and unload my 455.
I would go at least 8 feet, more if you can.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #8 of 36 Old 10-12-2019, 11:37 AM
Re: Shed Ramp
How about a pair of arched aluminum loading ramps. You could build a set of stars to walk in and the ramp will go right over them to get the tractor in and out.
Kawacub1046 is offline
post #9 of 36 Old 10-12-2019, 01:06 PM
Re: Shed Ramp
I put a small deck at the doors and a gradual ramp to the grass then landscaped around the ramp, will look pretty nice in a few years when the trees grow up. Decking is composite over pressure treated framing. I was worried that it might be slick when wet but the texture of the composite boards provides good traction even with smooth sole shoes.
2008 John Deere 3320 with 447 hoe
2014 John Deere X739
eric102 is offline
post #10 of 36 Old 10-12-2019, 05:58 PM
Re: Shed Ramp
I would have suggested making the door a little wider, so you have more clearance on the sides, both for any trim you may decide to add around the doorway, if you use doors, they may reduce the available width a bit, and to make it easier to get in/out of the shed with the tractor.
dave_r is online now
post #11 of 36 Old 10-12-2019, 06:39 PM
POENY's Avatar
Re: Shed Ramp
This approach worked for the shed (similar height and design as this one) I built at my last house. I used #2 to dust crushed stone that naturally packed well and was impervious to about everything.
2007 John Deere X748 w/SEat - aka Herman
John Deere 54" Snowblower, 54" Snowblower chute rotation modification, WE - Weather Enclosure, lights, & propane heater,
62C MMM, HDAPs w/ Rim Guard, 4 Suitcase weights, Hitch w/ platform & 16 gallon sprayer, Johnny Bucket Sr
POENY is online now
post #12 of 36 Old 10-14-2019, 09:48 AM Thread Starter
Re: Shed Ramp
Wow, thanks for all the thoughtful replies! Theres a lot more to a simple ramp than I thought.
Probably for now Im going to hit The Home Depot for some aluminum ramps. This will keep me going whilst I do an actual design.
Im very tempted to do some grading to bring the level up a bit so the ramp doesnt need to be so long. Also considering a much steeper ramp than a 1/12,
My barn has a 6 concrete lip on the way in and its still quite possible to get the tractor in (though the doors are only 40 wide so the mower deck wont go through), so a step by the door is something I should consider. Maybe not 6!
jma24 is offline
post #13 of 36 Old 10-14-2019, 09:49 AM Thread Starter
Re: Shed Ramp
So you got crushed stone delivered and then dumped it in a pile? That sounds like an attractive option.
jma24 is offline
post #14 of 36 Old 10-14-2019, 09:51 AM Thread Starter
Re: Shed Ramp
I didnt route the door jambs yet, this should give the clearance I need. I found my other 64 gate is plenty wide enough so fingers crossed!
Definitely not straightforward to widen the door now
jma24 is offline
post #15 of 36 Old 10-14-2019, 10:27 AM
RT3360's Avatar
Re: Shed Ramp
Just a thought about the door or doors. An overhead garage door is my preference, since a swinging door will run into any snow-ice that may be outside. But then again, you didnt say when you planned to use it. Spring, Summer, Fall use only eliminates the snow issue, but then, when you find out how much you enjoy the X590, you will want to use it year round. Then comes the question of what happens when you run a blower over grass, since you may not be able to just drive through the snow. Besides if you have a blower on the tractor, you might as well use it. My driveway is concrete from the house to the road, but gravel from the detached garage to the concrete driveway. The runners can be adjusted, but I chose to make some extenders that quickly attach to the runners with a couple of wingnuts. I posted a link for them on MTF. They also work very well on grass, leaving about an inch of snow and eliminated my scrapping the the grass. I also find a garage door opener very handy. After leaving the garage,, I can just push the button to close the garage door so snow doesnt blow in the whole time Im out blowing and then open it before putting the tractor away.
JD Ztrac 757 60
Craftsman DLT2000, 48
RT3360 is offline
