Carpenter bee problem. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 05-08-2019, 10:18 AM Thread Starter
I have carpenter bees, they look like bumble bees and they chew holes about 3/8" in wood. I spray what I can but it's a tough battle.
The main problem I need advice with is right now I'm having a large barn built and they're drilling as it's being built! Treated or untreated wood, doesn't matter. Is there a spray or something I can do? I could call an exterminator (expensive), I thought about old motor oil (messy).
Any ideas, thanks.
Sent from my SM-S320VL using Tapatalk
Sevenhills1952 is offline
post #2 of 10 Old 05-08-2019, 11:07 AM
Re: Carpenter bee problem.
Here's some reading for you on the problem https://www.google.com/search?source...31.lJGZrKK6Cj4
9297oldram is offline
post #3 of 10 Old 05-08-2019, 11:22 AM
Pinehillian's Avatar
my neighbor and i have decks and tiki bars with that problem, we both use babmittin rackets if you can reach them. 1 good wac
Pinehillian is offline
post #4 of 10 Old 05-25-2019, 02:10 PM
Get a brown paper bag and blow it up as if to pop it. Tie it off fully expanded and hang it up in the area where you have the problem. It'll look like a hornets nest to the bees and they leave instead of waiting to be killed and eaten by the hornets. I did it and it worked.
homefried1 is offline
post #5 of 10 Old 05-25-2019, 02:29 PM
Kioti SCUT
3 Legged Dog's Avatar
I had the same bee problem on an old garage. The bees drilled into the fascia board, no matter what I did. I tried plugging the holes, sprays, everything. They always went for the fascia board below the roof.
I finally replaced the fascia with solid vinyl planks, and never saw another bee. Cal
2017 Kioti CS2210 SCUT w/FEL (the 3 Legged Dog)
2019 PJ model UK142 T/A 14' utility trailer
Husqvarna YTH2348 yard tractor/mower
MTD Yard Machines E644E snowblower
Rigid RD8000 8k/10k generator
3 Legged Dog is offline
post #6 of 10 Old 05-25-2019, 04:24 PM
Steve Urquell's Avatar
I had some that only drilled a cedar board in the middle of an awning. Just had my siding replaced with steel and alum soffit. They have been buzzing around the new stuff looking confused.
As far as sprays I've had good luck with Bifen in my yard. It appers to kill them according to a web search. Tempo Dust is recommended to kill the larvae
Steve Urquell is offline
post #7 of 10 Old 05-25-2019, 04:53 PM
Other than a few holes only you are worried over, they don't do much harm and they are pollinators which are in short supply. The fascia board they live in look great except for 3 or 4 3/8 holes.
andyma is offline
post #8 of 10 Old 05-25-2019, 04:59 PM
MARK (LI)'s Avatar
WD-40 recommended by an exterminator...it works
MARK (LI) is offline
post #9 of 10 Old 05-25-2019, 06:39 PM
Senior Moment
Greybeard09's Avatar
Originally Posted by andyma View Post
Other than a few holes only you are worried over, they don't do much harm...
Until woodpeckers figure out they are in there... Then it's time for new boards.
Late 50's Bready... aka, "The WoodRat"
1969 John Deere 110 w/front blade
1998-99 MTD/AYP "Black Thing" 18hp Briggs MUTT-Mower
2002 Cub Cadet 2166 (in process)
2006 Cub Cadet GT2544
2011 Cub Cadet Z-Force S 48
Greybeard09 is offline
post #10 of 10 Old 05-25-2019, 10:15 PM
grnspot110's Avatar
My best defense has been an old tennis racket I bought at a flea market for 50 cents!
John Deere: 1944 LA, 1953-40S, 1980-314, 1993-755 w/60" deck, 2000-F725, 2004-790 w/300 Loader, 1980-Power King-2418, 1948 AC "G", 1961 Cub Lo-Boy & 2007-"TS" Gator.
grnspot110 is offline
Kohler K-532 K-582 Governor Problem motobike Small Engines and Repair 1 05-07-2019 07:14 AM
2005 New Holland TC30 electrical problem Wisedm Ford/New Holland Tractors 2 05-02-2019 09:36 AM
Mtd Ranch King problem with belts xman17 MTD 9 03-31-2019 04:21 AM
JD X540 Power Steering Problem dgeiss John Deere Forum 12 08-25-2018 10:23 PM
Solenoid causing problem Zuko Craftsman/Sears Forum 12 07-11-2018 06:58 PM
