How are sheds measured? - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 54 Old 05-02-2019, 05:42 PM
Re: How are sheds measured?
Before you start negotiating make sure you have a full list of issues to be resolved. It's much harder to go back the second time.
Dee_Veloper is offline
post #17 of 54 Old 05-02-2019, 06:16 PM
Hangin with the cool kids
poncho62's Avatar
It makes no sense to build a 15 ft wall instead of 16 ft. You would save no money and have waste. Framing, paneling etc are dependent on 4 ft measurements. 4 panels equal 16 ft.....15 foot is still 4 panels with a foot cut off....Waste.
Just sayin'
Ford LGT100
Ford LGT125
Ford LGT165
John Deere STX38
poncho62 is online now
post #18 of 54 Old 05-02-2019, 07:09 PM
mowergene's Avatar
I had a steel shed erected a few years ago.....double garage size w/extra depth. I poured the footings and that's the size it is.
In the past:
In use:
mowergene is online now
post #19 of 54 Old 05-02-2019, 07:58 PM
Still lovin' the 322!
PA318Guy's Avatar
You could offer to do a 40 ft x 40 ft garden as final payment and then just plant a row or two of cantaloupe or watermellons and let them spread out. Tell him the tilled area doesn't matter only the plant coverage!!
Current Machine JD 322
PA318Guy is online now
post #20 of 54 Old 05-02-2019, 09:46 PM Thread Starter
Here's what I think is going on. It's a Strongpanel pole barn. The steel sheets are sold in standard lengths like 8ft, 12ft, etc. The 36x36 barn has the shed on one side. He wanted the roof to come out "right". So pitch is (from memory) like a 12-4...you can walk on it (if you're careful), so roof panels are like 22 to 24ft one side, about 40ft the shed side (half of barn+shed). So my guess it was longest panel available (no overlapping).
Sent from my Bell Rotary
Sevenhills1952 is offline
post #21 of 54 Old 05-03-2019, 04:18 AM
20,000 Posts & Climbing
Somehow, I don't think so. A steel roofing panel will expand and shrink according to the temperature, and roof panels do get a tad warm under the summer sun compared to overnight winter temps. A 12' long panel will measure almost 3/4" difference in length between the extremes of the temperature. For a 40' panel, it's more like 2.4" for a 150 F temperature differential.
That's why bridges have expansion joints every 100' or so.
TUDOR is offline
post #22 of 54 Old 05-03-2019, 05:35 AM
Blank Space
Standard 5 rib panels (and most other shapes) are cut and pressed from roll stock. I've watched it being done. There is no standard or maximum length beyond what can be carried by truck.
I can order a 24' panel, or a 26' or a 33'. I can even order them at 24' 7" if I choose.
Sent from my keyboard using my fingers.
post #23 of 54 Old 05-03-2019, 05:39 AM
Blank Space
I don't doubt there's some change, but I'm not sure how much. Remember, they're put down with about a #8 screw on 24" centers. The screw is self drilling so the hole is a tight fit, no room for movement.
post #24 of 54 Old 05-03-2019, 07:05 AM
Sorry, misplaced decimal and wrong coefficient of expansion.
Actual length difference for a 12' pan is 0.156". For a 40' pan it's just over 1/2".
As you say, the holes for the screws will be tight, but the steel is still going to move. Something will have to give to compensate for that movement. Usually, the screws bend back and forth as the steel expands and shrinks, but sometimes the steel tears and makes oblong holes.
TUDOR is offline
post #25 of 54 Old 05-03-2019, 10:19 AM Thread Starter
The roof is white just like the garage. Garage was built over 30 years ago and there aren't any oblong holes or missing screw heads. They're about 2 1/2" long, rubber washer and metal washer.
post #26 of 54 Old 05-03-2019, 03:36 PM
Blank Space
^^ The problem may be more hidden that that. Yes, there will be some movement and it's more likely that the screw wiggling will loosen in the wood underneath than mis-shape the hole in the metal. The washers will degrade in the Sun and heat. Eventually water can seep through the degraded washer and into the wallowed out screw hole in the wood. And so it begins.
I've looked at screws I put in 5 years ago and see the process in progress. On a roof, it's far less likely that anyone will inspect each screw. Even those that begin to leak may not show any real damage.
I have metal on most of my house and will be doing more in the next few weeks, but I have no idea if any of it is or will leak water into any living space.
post #27 of 54 Old 05-03-2019, 03:38 PM
Blank Space
But back to the Nitty of the Gritty, what did they say? What did they say? It's been a couple of business days and we all wanna know!!!
post #28 of 54 Old 05-03-2019, 07:39 PM Thread Starter
I'll probably know Monday. The guys didn't work yesterday and today, the main guy has a drag car and was racing.
Ok with me... I'm not in a hurry and it gave me a chance to bush hog, move their stuff around.
I'd rather have a more useful shed which would be 20-24ft x 36. I'll talk to the owner about it. Just more posts, rafters, then metal roof up under this a few feet overlap.
A 14 to 15ft x 36 ft shed isn't that useful. Extra 5-10 ft would make a huge difference and I have plenty of room.
post #29 of 54 Old 05-03-2019, 09:06 PM
Profound Ag's Avatar
What a weird circumstance. Never heard a building being specced by roof size before.
There is no substitute for hard work- Thomas Edison
Profound Ag is offline
post #30 of 54 Old 05-03-2019, 09:53 PM
wally2q's Avatar
if they sell a "shed size" that is X by Y, but then say, "roof dimensions"..... roof dimensions is NOT shed size. Shed size is standardized by exterior wall dimensions - that's how the building permit is defined, and that's the law.... No contract between 2 independent parties is "above the law".
So go to town and ask for a copy of the plans / building permit.... it will probably state the actual shed size as defined by walls... then call the contractor on it and say: "I ordered and paid for a 36x16 but the permit you filed is for a 35x15 shed - what gives??"....
35x15 is 91.1% of 36x16 by area.... so tell him you will only pay the balance payment that adds up to the total of 91.1% of what you asked for, since that is all that you got.
Even in court, you will win this fight in a heart-beat... the official size is what's on the permit - not what he "tells you".
This whole case is equivalent to selling a car... if he sells you a car, and says it "made for 6 passengers"... but then he says, actual seating is for 5 (5 seat belts), the 6th person can easily lay down in the trunk - that doesnt work!!!... The car is certified for 5 passengers, not 6... Period. The definition is standardized by law.
cheers!
wally2q is offline
' Tractor Sheds ' x595 WorkShops, Garage and Shed Discussions 383 02-10-2019 07:16 PM
