What kind of grass is this? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 28 Old 08-16-2019, 07:14 PM Thread Starter
Posting a couple of pics of this grass that grows around here. Anyone know what kind of grass this is? Is there anything I can do to halt the growth of this stuff? It shows up around the end of June/first of July and sticks around until the first frost. It grows so fast, regardless of how hot it is or how dry it is. It needs to be cut about every four days or it gets out of control. It grows so thick. The stems are very tough and if you don't have very sharp blades, it doesn't cut good and leaves stragglers all over the yard. Any help identifying and eliminating this stuff is greatly appreciated.
ID:	2391565   Click image for larger version
BowHS is offline
post #2 of 28 Old 08-16-2019, 07:49 PM
Martian Wx Moderator
Mark / Ohio's Avatar
Re: What kind of grass is this?
Crabgrass, wire grass, fall grass. Different people call it different names but think they are all the same. Pre-emergence in the spring helps. Little harder later on to kill it without killing the good grass.
I just leveled the top of mine. I like that it stays green when the summer heat browns out the other but that is all I like about it.
Mark -2002 John Deere LT150H
Mark / Ohio is offline
post #3 of 28 Old 08-16-2019, 08:12 PM
We have an entire region here which I live in called the Wiregrass.
This is another of the reasons that I sharpen my blades often, sand being the primary reason. Can always tell when the blades need a touch up when I begin leaving the stragglers standing.
Flaken is offline
post #4 of 28 Old 08-16-2019, 08:25 PM
How to control Aristida stricta:
https://www.todayshomeowner.com/how-...-in-your-lawn/
And the Wiregrass Region:
https://en.wikipedia.org/wiki/Wiregrass_Region
Flaken is offline
post #5 of 28 Old 08-16-2019, 09:18 PM
mdog892001's Avatar
The first two pics look like Bahiagrass. Itís a native grass mostly found in the south. Very drought resistant.
mdog892001 is offline
post #6 of 28 Old 08-16-2019, 10:29 PM Thread Starter
I'm in the northern middle portion of SC. Wiregrass seems to be more GA and FL, but it does bear a resemblance. It is also similar to Bahiagrass, but there is some actual Bahiagrass in the yard as well. The Bahiagrass grows taller and has black seeds. This doesn't grow as high, but grows close together, and the seeds are more greenish/yellowish. Not sure exactly what this is, maybe a relative of one or both. Reading about wiregrass in the links Flaken posted, it looks like I'm stuck with it. Yard is way too large to try some of the methods. I just hate the stuff, it grows way too fast and looks awful, not to mention hard to cut. It is all over the place, everyone has it in their yard for miles around.
BowHS is offline
post #7 of 28 Old 08-17-2019, 07:43 PM
Country1966?'s Avatar
Don't mess with off-the-shelf round up.
find a farmer who gets the real stuff Farmers have access to commercial Roundup as long as they have a chemical license.
At least that's the way it is in Ohio.
I would start by trying a strong mix of Roundup
Massey GC2400
Gravely ZT HD 60" 24hp Kaw.
Old Troy Build Horse Tiller
Husky Snow Blower 24" 6hp
Not Enough Barn
Country1966? is offline
post #8 of 28 Old 08-20-2019, 03:02 PM Thread Starter
I have considered trying Roundup or something similar on a portion of the yard. Nobody around here has grass, it is all weeds. It gets to a point where you just want to give up. You can't keep up with it. I can't get out and mow every four days. This grass has taken over in the last 10 years or so. It gets worse every year. I used to enjoy getting out and mowing the lawn, but every year for the past few years I hate it more and more. If the yard wasn't so large, maybe it wouldn't be as big of an issue.
BowHS is offline
post #9 of 28 Old 08-20-2019, 03:23 PM
Depends upon your definition of 'weeds'. Wiregrass, as it's name implies, is a type of grass. Sure, it's not as pretty or as prestigious as Bermuda or Kentucky Blue, but it does cover the ground. Besides, it's a grass that is native to your area and makes it much easier to grow.
My yard has about seven different species of grass from the previous owners various tastes. Everything from pasture fescue to wiregrass to centipede and it all grows at different rates, some even stays greenish and grows year round. I mow 12 months of the year.
Flaken is offline
post #10 of 28 Old 08-20-2019, 04:46 PM Thread Starter
I guess I have a very broad definition of weeds. We have a collection of different things as well, but it seems the wiregrass takes over mid-summer through mid-fall. I guess my point is that if I had something that looked better and didn't grow so fast I wouldn't consider everything such a chore. Frankly I could care less about the look, just wish I had something that didn't need to be cut so often. If I go over a week without mowing, the yard looks like a vacant lot. As I get older, it gets harder to keep up with it. But that is life.
BowHS is offline
post #11 of 28 Old 08-20-2019, 05:16 PM
Would a goat or something eat it for you?
I'm guessing it grows more because the good grass dies off in drought. So need to either use sprinkler or add fertiliser to help the good grass grow better to keep the bad grass out.
Cover it with a black/grey plastic sheet tarpaulin and it wont grow Or if theres anyway you can shade the area, it won't grow as fast.
cj12 is offline
post #12 of 28 Old 08-20-2019, 06:06 PM
Yup, I've noticed that a tarp on the ground does a good job of killing whatever is under it.
Dan
Bolens / TroyBilt GTX20
MF / Snapper 1855
Bolens / Iseki G152
JD 116 - sold
DL-North is offline
post #13 of 28 Old 08-20-2019, 08:05 PM
B440's Avatar
Or a portable pool....
B440 is offline
post #14 of 28 Old 08-21-2019, 03:51 PM Thread Starter
I have thought about a goat or goats. The tarp wouldn't really work due to the size of the yard. I guess I could get multiple tarps and do it in sections. It is possible it is choking out the "good" grass. I'm going to look into some fertilizers or weed control products to see if anything might work. If I can find something that will at least knock back how fast it grows I would be happy.
BowHS is offline
post #15 of 28 Old 08-23-2019, 09:31 AM Thread Starter
Posting a couple of pics of a strand of the grass I am talking about. It is not Bahiagrass, and I don't think it is wiregrass based on some of the images I have looked at.
I cut the yard yesterday, some of the stems were 16" high. It had been 13 days since I had last cut. Ridiculous how fast this stuff grows.
ID:	2392567   Click image for larger version
BowHS is offline
