Perimeter drain - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 04-28-2019, 02:43 PM Thread Starter
Perimeter drain
Just wondering if anyone has installed a perforated drain pipe around a patio or sun room with little slope? I want to run about 50 ft of drain pipe around a 3 season room that's almost at grade level since in downpours it gets some water in it just a bit. The surrounding area is decorative stone and would run the drain pipe under that then across yard to empty by a storm sewer. Since the yard appears to only have about 1 inch slope between the farther point and drain, I would be able to start just under the decorative stone about at ground level and maybe go another 2-4 inch deeper at drain point. Since the pipe is 4 inch it seems that alone with the 1 inch slope would allow to drain. But given the extra 2-4 inch deeper trench seems like that would work. Does this sound like it would work?, or anything I have forgotten? Thanks
Cub Cadet XT2 LX42 Kawasaki motor
Hunter2 is offline
post #2 of 5 Old 04-28-2019, 06:41 PM
Cat385B's Avatar
Re: Perimeter drain
Run your drain tile around the perimeter of the room, then switch to solid pipe to make the run to the drain. It is easier to get slope on a smooth walled pipe.
Cat385B is online now
post #3 of 5 Old 05-02-2019, 04:01 PM
Yard Nazi's Avatar
Talking Re: Perimeter drain
I have been watching a number of videos regarding a product called Hydroblox. Works without pitch and according to all I had read and watched it is never supposed to clog. Interesting product. I have been thinking of running it down the property line to help move more water to the rear of the property. Might be worth looking at. Bill
How It Works - HydroBlox International
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1978 Lawnboy Model 5269G
1979 Lawnboy Model 7268******1980 Lawnboy Model 5247******1982 Lawnboy Model 5247
1982 Lawnboy Model 5247*******1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is online now
post #4 of 5 Old 05-02-2019, 09:26 PM
Professional Homeowner
steddy's Avatar
Re: Perimeter drain
French drains for your downspouts may accomplish much the same effect, if you have downspouts in the area. So long as your water table isn't insanely high, what you want to do will work fine.
We're building a new home now, and I paid extra for perimeter drain tile, problem (and it's a problem I don't mind having) is the hill the house is built on likely negates the need for any of that. Probably didn't need to have it there, but oh well.
Overkill.
I love overkill.
I'm Ted.
(Click Here)
steddy is online now
post #5 of 5 Old 05-04-2019, 08:30 AM
Retired & lovin it!
Newsman's Avatar
Re: Perimeter drain
Ted, much better to have it and not need it rather than need it and not have it. Easier to do now while everything open rather than later when you'd have to dig down again.
MikeC
Newsman is offline
Full tank with Stabil or drain the tank? Rickoo John Deere Forum 23 12-05-2018 04:28 PM
Kawasaki Drain Valve SOB Backyard Round Table - L & G Tractor Related Topics 12 05-02-2018 08:38 PM
Any ideas on siezed drain plugs? rtm820 The Barn 8 10-02-2013 09:15 AM
Oil Drain Valve AdamsCL John Deere Forum 2 12-12-2012 06:12 PM
Teflon tape needed? metal threads of oil drain tube G110 a_gunslinger John Deere Forum 3 11-09-2012 07:28 AM
