oversteer problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 21 Old 05-15-2011, 09:47 PM Thread Starter
cyser man's Avatar
oversteer problem
Hi guys. I have a Craftsman LTX1000 with 20hp brigs. My problem is that when steering, the wheels turn so much that they dig in and the tractor pushes forward. In my manual it says that there is no adjustment. Is there anyway to correct this?
thanks.
Name's Sean. 2000 Craftsman, 20hp, Snowblower attachment.
cyser man is offline
post #2 of 21 Old 05-15-2011, 10:30 PM
Poster
Metalwiz's Avatar
Re: oversteer problem
You might try additional weight on the front. Reduced air pressure and reduced speed might also help. It's something you'll have to play with. Usually the weight will fix it. Dale
Metalwiz is offline
post #3 of 21 Old 05-15-2011, 10:33 PM
The Magnificent
D-Dogg's Avatar
Slow down?
It seems like the wheels on my DYT4500 would turn well beyond the ability of the tractor at any sort of speed.
D-Dogg is offline
post #4 of 21 Old 05-15-2011, 10:47 PM
The voice of reason !
ranchkingron's Avatar
Sean I'm not sure how you would fix this if theres no adjustments you can make to the tie rods ?
The obvious fix would be not to turn the wheels to lock but sometimes thats not an option, is it possible you have a bent tie rod ? That would put you into a really bad toe in situation and cause at least one wheel to push.
If all is correct then you may have to weld steering stops on the spindles to keep them from going past their maximum turning points.
My guess would be something is bent or worn out as I don't think a company would design a product intentionally to give the consumer problems.
I never even thought that he may be going to fast for the tractor to turn thanks D-Dogg.
Ron
Sometimes a cigar is just a cigar. Sigmund Freud
ranchkingron is offline
post #5 of 21 Old 05-16-2011, 01:59 AM
Young Buck
ubber_gearhead99's Avatar
I was using a GT5000 and had a similar problem. the turning rod wasnt set right, so the tractor turned very far one way, and not very the other. I would try adjusting the steering arm, and seeing if its bent. Ive bent one before.
The 400's coming along, and we're both kicking and screaming!
1975 John deere 400 "rocking and rolling in primer!"
1959' Bolens Ride-a-matic 230 w/ 39" deck,48"plow, 8" mold board plow
Custom Snapper Hi-Vac with Honda engine
Lawn Boy M series with rebuilt engine
ubber_gearhead99 is offline
post #6 of 21 Old 05-16-2011, 05:07 AM
USMC
slkpk's Avatar
If nothing is bent and your front tires aligned correctly you might try more aggressive tires on the steer axle. I have front end slide on my Ingersoll 318LGT with the factory tires but I don't with the tri-ribs. Slowing down in turns will almost cure the problem without doing anything else. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #7 of 21 Old 05-16-2011, 09:53 AM
I think it's the small turning radius that some manufactures are advertising, a selling feature that's not practical unless you are barely moving. Also a good way to wreck the light weight steering linkage if you turn that sharp going too fast.
DonF is offline
post #8 of 21 Old 05-16-2011, 10:13 AM
ezliving4ume's Avatar
Thats the ticket. Then the steering wears out and the customer is back two years later.
"THE BITTERNESS OF POOR QUALITY REMAINS AFTER THE SWEETNESS OF LOW PRICE IS FORGOTTEN"
My tractors:
Simplicity 6216
The LandLord
Why Purchase Simplicity:
https://www.mytractorforum.com/showth...6380&highlight
ezliving4ume is offline
post #9 of 21 Old 05-16-2011, 07:20 PM Thread Starter
cyser man's Avatar
Thanks guys. I was thinking the tie rod thing but was hoping that there would be a quick fix or trick. BTW it doesnt matter about the speed. I can do it from a dead stop. They are just turning too sharp (almost 90 degrees). I will look to see if anything is bent out of shape.
post #10 of 21 Old 05-16-2011, 07:39 PM
The Magnificent
D-Dogg's Avatar
Hey, here's a thought I just had. On a lot of the lighter tractors, there is a sector gear for the steering. Inside the radius of the sector gear, is an arc shaped slot. Though this slot bolts a bolt to keep the sector gear from wandering upward, and limiting the travel of the sector gear. Maybe this bolt has worked loose?
D-Dogg is offline
post #11 of 21 Old 05-16-2011, 08:15 PM Thread Starter
cyser man's Avatar
Thanks D-dogg. I looked there and it isn't loose. I was thinking of somehow filling in the slot a bit to not allow the wheels to turn so sharp. But not quite sure how to do this.
post #12 of 21 Old 05-16-2011, 10:32 PM
Dude11's Avatar
Yup--seen it right off--A comy plot!!!!!!
Dude11
Dude11 is offline
post #13 of 21 Old 05-17-2011, 02:14 AM
Boyd's Avatar
You need a wing on the front for more downforce.
My Horses: Toro 520xi, 522xi,, plus 520Lxi parts tractor. Two Sears (Noma) 4 wheel steer tractors. Dixie Chopper X2002 project. WTB: Bolens Villa rear steer riding mower. See my Facebook pages for Bolens Villa mowers & Toro 5xi & New Holland equivalent garden tractors.
Wanted to buy Toro 5xi series 79355 48” blade, 52” deck.
Boyd is offline
post #14 of 21 Old 05-17-2011, 02:48 AM
20,000 Posts & Climbing
That's understeer, not oversteer. Some weight on the front should help. My Husqvarna 20 hp is pretty light on the front as well, and does its own share of plowing the front tires at any speed.
Try 30 lb bolted to the front, but watch out for frame twisting when you mow the ditch. Loading the front tires might be a better idea.
TUDOR is online now
post #15 of 21 Old 05-17-2011, 08:12 AM
Nouveau Redneck's Avatar
thanks.
Ummm....... Don't turn the steering wheel as far??? Or are you saying that you only have 3 steering positions, straight, full left and full right?
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
