Premium gas - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 75 Old 09-14-2019, 09:41 AM Thread Starter
zapcan59's Avatar
Premium gas
I've always used regular gas in lawnmowers & I know people who use only premium gas . Most pumps don't have a dedicated nozzle for premium gas, you have to choose the grade. So if you are only getting a couple of gallons, how much would be premium taking into account the regular fuel still in the pump line?
Nothing runs like a Deere, or smells like a John
zapcan59 is offline
post #2 of 75 Old 09-14-2019, 09:48 AM
Steve Urquell's Avatar
Re: Premium gas
Hard to say but you could always pump a gallon in the car before filling the can.
Steve Urquell is online now
post #3 of 75 Old 09-14-2019, 09:57 AM Thread Starter
zapcan59's Avatar
Re: Premium gas
I did exactly that, I got a gallon to try in my weed trimmer.
zapcan59 is offline
post #4 of 75 Old 09-14-2019, 10:07 AM
Re: Premium gas
The premium isn't worth it unless it's ethanol free.
Dixon Driver is online now
post #5 of 75 Old 09-14-2019, 10:33 AM
PeterE's Avatar
Re: Premium gas
Riding snowmobile and motorcycles I've known guys who would circle the pumps looking for one that pumped premium on the last sale.
PeterE is offline
post #6 of 75 Old 09-14-2019, 10:51 AM
spokes100's Avatar
Re: Premium gas
Exactly! We just don't need it with these low compression engines.
spokes100 is online now
post #7 of 75 Old 09-14-2019, 01:20 PM Thread Starter
zapcan59's Avatar
Re: Premium gas
I've been told that Ethanol may ruin the needle tip in the carb.
zapcan59 is offline
post #8 of 75 Old 09-14-2019, 02:22 PM
Re: Premium gas
Ethanol gasoline in outdoor power equipment just makes more problems over the long term. From it going stale quickly to gelling problems in carbs, eating some gaskets and a bunch of other.
I use the ethanol free in both my 2008 F150 4X4 and any outdoor power equipment. Luckily, there is a station just across the state line in the Great State of Alabama that sells it. Not all premium grades don't contain ethanol, it has to specifically state on the pump that it doesn't. In both the US & Canada, one can use the following website to find the ethanol free gasoline.
https://www.pure-gas.org/
Flaken is offline
post #9 of 75 Old 09-14-2019, 06:51 PM
Nouveau Redneck's Avatar
Re: Premium gas
Only if the carb was designed before they started adding ethanol to gasoline. Once the gasoline companies started adding ethanol to the fuel the vehicle and equipment manufacturers changed the materials in the fuel systems they designed so that they would be compatible with gasoline with 10% ethanol in it.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #10 of 75 Old 09-14-2019, 08:08 PM
Collector of many tractors
Kbeitz's Avatar
Re: Premium gas
The new stuff can use Ethanol gasoline. Older engines don't like Ethanol...
Kbeitz is offline
post #11 of 75 Old 09-14-2019, 08:55 PM
Senior MTF Pollster
Austen's Avatar
Re: Premium gas
I normally use regular. I have experimented with using straight premium before in a familiar machine and my results were slightly longer starts and *maybe* less fuel consumption.
1985 Bolens HDT 1000 #11
1977 Economy Powerking Tractor
"So I say to you, ask, and it will be given to you; seek, and you will find; knock, and it will be opened to you." - Luke 11:9
Austen is online now
post #12 of 75 Old 09-15-2019, 08:02 AM
Re: Premium gas
Higher octane is not needed in most engines. All that it does is allow higher compressions and hotter temperatures before predetonation (engine knock) occurs. It basically makes it harder to get it to explode so it could, in some cases as Austen points out, cause longer starting times in an older engine that might have lower than optimal compression and/or a weaker than optimal spark.
Nouveau Redneck
Sean in PA
post #13 of 75 Old 09-15-2019, 09:17 AM
I think most of us are just buying it b/c it's the only option available w/o alcohol.
post #14 of 75 Old 09-15-2019, 10:29 AM
TriumphMan's Avatar
Re: Premium gas
I now use mid-grade ethanol 89 octane in my mowers.
I have before used some straight 87 fuel without any other added additives and the engines seemed to run hotter and noisier in my summer, high heat index weather. So now, I also put in the 5gal cans I use to fill mowers, some cheap Walmart 1/2 bottle fuel additive/stabilizer and a 1/4 oz of Marvel Mystery Oil per 5 gallons.
This way the fuel keeps longer without going stale and robbing me of octane rating.
I do shop at a local grocery store that gives discounts on fuel for one local gas station to help ease the pump prices.
Del
1967 Cub Cadet 102-Kohler K241(10hp) Kept as original as possible.
1990 Kut Kwick CL20-60-Onan P220(20hp) Front deck/rear steer commercial mower
2003 Craftsman GT5000-B&S engine(24hp) Manual transaxle
TriumphMan is online now
post #15 of 75 Old 09-15-2019, 11:08 AM Thread Starter
zapcan59's Avatar
Re: Premium gas
I think it's time to start using a stabilizer also. Not sure if it's the hot temperatures but gas doesn't seem to keep very long. Years ago things seemed like they would start after sitting around a couple of years
zapcan59 is offline
