Mice infestation in the shed, building nests in the tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 138 Old 08-31-2019, 01:13 PM Thread Starter
WrongDoug's Avatar
I store my Cub Cadet in my shed in the backyard, and there's always been a few mice in there, but they've mostly left the tractor alone. But the past couple months there have been mouse nests inside the tractor engine and I have to thoroughly check it over for mouse nests every time I use it. I'm getting fed up with them, and I want them dead. I've tried a couple repellents with no success. Short of getting an angry cat, what is the best way to get rid of them? Traps would work but I would need about 100 of them. Any other suggestions?
Joe in PA
"What you talking about Willis, that him!" -Mr. Chow
WrongDoug is offline
post #2 of 138 Old 08-31-2019, 01:35 PM
Father Deerest
Re: Mice infestation in the shed, building nests in the tractor
Dryer sheets. Place them where you don't want the mice, works well for mosquitoes.
Father Deerest is offline
post #3 of 138 Old 08-31-2019, 01:49 PM
Long Time Thread Stalker
AddictedToTractors's Avatar
Available on Amazon, works for chipmunks, mice, rats, crickets, anything small enough to fit in it!
I use mine for chipmunks and mice. Works great, uses 4 AA batteries.
2009 Simplicity Conquest 4x4 - 23hp Vanguard
- 50 deck
- 46 Single Stage Thrower
197? Ebro 460 - 3.3 PERKINS
- Walco 66 Box Blade
- Bush Hog 12 Post Hole Auger
- Woods 60 Rotary Cutter
- Homemade 800lb Ballast
- HLA 2,000lb Pallet Forks
- HLA 66 Snow Pusher
1999 Gehl Sl3825 Skid Loader
AddictedToTractors is offline
post #4 of 138 Old 08-31-2019, 01:59 PM
Blank Space
People have claimed that leaving the hood up on the tractor will help deter them. Since you keep it inside the shed where rain isn't an issue, it would be worth a try.
LS MT125
post #5 of 138 Old 08-31-2019, 03:09 PM
Don
My shed is sealed tight. The doors overlap the bottom and top by 2 inches. The roof is sealed tight. Can you seal up around the bottom of the door. I bet that's how they are coming in. Walk around the outside and see if there's any little holes at the bottom. Get a pet to hang around the shed like a dog or cat.
Don
My craftsman 917.27308 is online now
post #6 of 138 Old 08-31-2019, 03:13 PM
Got some good unwanted guest food and the local feed store. A little goes a long ways and they sure like it.
Ariens93GT20 is online now
post #7 of 138 Old 08-31-2019, 03:19 PM
Still lovin' the 322!
PA318Guy's Avatar
I just ordered a Rat Zapper, have a few vermin in my shed lately too!
Current Machine JD 322
PA318Guy is offline
post #8 of 138 Old 08-31-2019, 03:49 PM
I made a mouse bucket trap that works really good and easy to use and can catch ( drown ) quiet a few before having to rebait it again. Just Google mouse bucket trap and you'll find alot of ways to make them.
9297oldram is offline
post #9 of 138 Old 08-31-2019, 04:22 PM
Blank Space
All of the people on Earth combined could never make, let alone sell or use enough traps, zappers or bait to eliminate them all. The best we can do is co-exist and deter.
Stop throwing your money away on gimmicks and learn preventative measures which are probably different for everyone.
LS MT125
post #10 of 138 Old 08-31-2019, 06:38 PM
A neighbor swears by his use of dryer sheets (I think he says Bounce is the best) in his motor home.
From my limited experience you are right to be concerned with the mice.
I've heard too many tales of mice chewing through wires on vehicles, and I needed to vacuum out a nest from the intake manifold of a seldom driven pick-up garage kept. Looks like they didn't mess with any of my wires.
A friend donated a small tractor and I found the urine-laden mouse nest had eaten away some of the aluminum head on the engine. The tractor was too small and mostly junk so I didn't try too hard to get it running. The mice won the battle but lost the war -- i.e. a place to nest -- since I took it to the scrap yard.
You may want to consider what happens to them if your house animals get hold of a poisoned mouse, and the possible lingering odor if the mice die somewhere inside your structures in an obscure place.
I think I'd try the bucket and water method if I needed to try getting control of them.
Polish Wizard is offline
post #11 of 138 Old 08-31-2019, 06:50 PM Thread Starter
WrongDoug's Avatar
I'd be better off to knock my shed down and build a new one than to try to seal the one I have. The sheathing is rotted at the bottom and the doors never closed tight to begin with.
I'm curious if anyone has ever had any experience smoking them out. A friend of mine swears it worked for him. He says he parked his tractor in the shed and started it up and let it run at half choke with the doors closed for a couple hours. Obviously you can't do this anywhere that is occupied by people, but for a shed it seems like it makes sense. It won't deter them from coming back, but it should at least get any living ones out.
Joe in PA
post #12 of 138 Old 08-31-2019, 07:37 PM
We're all friends here
APinNY's Avatar
Our camp is in the mountains, so lots of critters in the area. Over the years, mice have occasionally gotten into the house and run amok. This past winter only one apparently got in, but one is too many. They have also gotten into our pontoon while in storage and chewed on the folded up Bimini. We put Bounce dryer sheets everywhere, and they do work, to a degree. Unfortunately, they are not foolproof so we need to try something else. In the past we have used poison. That makes them go into the walls and die, creating a stink for up to a week. I recently ordered some "walk the plank" kits to try. They got excellent reviews on Amazon, and for the price they are much easier to order than to build. It is a little early to set them up here but I am looking forward to trying them soon. I also plan to get an electronic zapper big enough to hold a few if necessary, but hoping the planks will stop them before they get inside the house.
Al
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #13 of 138 Old 08-31-2019, 11:13 PM
Buy the victor traps with a steel trip lever. . They come in a 72 pack. Buy a bag of almonds, some elmers glue and a box of disposable gloves. Spread the bait pocket and glue in an almond. do 20 at a time. Set four and keep the rest in the house. Then keep working them. The almond will allow you to reset without rebaiting- the mouse usually only gets a bite or two. Chuck them after they get too scroady. Gloves to keep the vermin off your hands. I wash the places they accumulate on the machine with natures miracle enzyme deodorant.
Leaving the hood open is a good idea- helps deny cover- also if possible, get rid of food sources- like a bird feeder, maple trees, etc. Keep the machine and floor as clean as you can- they like cover.
This is not a do once and forget- it takes constant relentless trapping to keep them down.
stoneaxe is offline
post #14 of 138 Old 08-31-2019, 11:33 PM Thread Starter
WrongDoug's Avatar
I love the nature's miracle products, they are a must for pet owners. I keep the machine really clean, but I do have to go through the shed and throw some stuff out. There are no food sources in there, so I don't know what they are eating, but I keep all my bird seed and chicken feed inside the house. The only thing that is in the shed other than tractor is some garden tools, a couple tires, some old lumber and some shingles, a couple bags of concrete and my gasoline cans. Nothing that would make good/easy food. I guess I'll have to get started on traps. I may store the tractor elsewhere until I've got them at bay.
Joe in PA
post #15 of 138 Old 08-31-2019, 11:53 PM
Steve Urquell's Avatar
I keep them out of the engines bays of my cars with cayenne pepper. Sprinkle it where you don't want them and you're done. Below is what my wife's car was getting overnight. After the cayenne it hasn't had a single nut in there.
2001 Cub 3240 with fabbed hydraulic sleeve hitch and Swisher Hydraulic Front Bucket
Steve Urquell is online now
ejbpesca
