What GT Should I Buy? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 08-18-2019, 08:19 AM Thread Starter
Long Time Thread Stalker
AddictedToTractors's Avatar
To mow 3+ acres around the farm, possible blower / snow blade, reliable, easy to get parts, budget of $4,000 Canadian.
What it will be replacing, the k664 just wasn’t holding up!
2009 Simplicity Conquest 4x4 - 23hp Vanguard
- 50” deck
- 46” Single Stage Thrower
2015 Kioti CK30
- Walco 66” Box Blade
- Art’s Way 66” Snow Blower
- Bush Hog 12” Post Hole Auger
- Woods 60” Rotary Cutter
- Homemade 800lb Ballast
- Stoll Loader
- 62” Bucket
- HLA 2,000lb Pallet Forks
- HLA 66” Snow Pusher
1999 Gehl Sl3825 Skid Loader
2006 Simplicity Prestige - Sold
AddictedToTractors is offline
post #2 of 12 Old 08-18-2019, 09:55 AM
Blank Space
Re: What GT Should I Buy?
Get a mower (mid or trailing) for the CK30 to handle the larger, more open areas. Then get a sub $2K riding mower for the areas closer to the house and wherever more detail work is called for.
LS MT125
Obscured_by_Clouds is offline
post #3 of 12 Old 08-18-2019, 10:39 AM Thread Starter
I thought about doing that, but wasn’t sure if the ck30 would handle the hill with its high Center of gravity. Max angle of hills is 10 to 15*, and when on said hills using the tractor it does get sort of sketchy...
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #4 of 12 Old 08-18-2019, 10:44 AM
Blank Space
Hills beyond a safe grade are done straight up and down. Never across the hill (sidehilling). I keep the FEL on and carry it as low as possible, just enough not to touch ground. That helps to balance the weight and keep the COG lower. But I have to be careful to know where the edge is. I've dinged a couple of things already.
LS MT125
post #5 of 12 Old 08-18-2019, 10:49 AM Thread Starter
True, that is how I use the ck30 now, but with the conquest I found with the wheel spaced out it was quite comfortable on the hills sideways.
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #6 of 12 Old 08-18-2019, 03:38 PM
Willscary's Avatar
My ditch along the rod is at least 20 degrees and maybe more at its steepest. I did not mow it until I got the Conquest because it was just too steep. the Conquest would slip and slide down the hill as I was driving, it could not hold its course.
I then filled the rear tires with Rimguard and that helped a lot, but it was still quite nerve wracking.
When I purchased the Prestige, the tires held a bit more Rimguard and by then I had purchased cast iron wheel weights. Each rear wheel now sports an additional 128 pounds (roughly) of weight that is low and wide. The only issue I have now is my big butt's desire to slide out of the seat!
I own a 2017 Simplicity Prestige 27/52 EFI, JB Jr, Johnny Plow Jr.
From 2015 to 2017 I owned a used 2013 Simplicity Conquest 27/50.
From 1996 until 2015 I owned a White LT-16 Vanguard V-twin and 2 stage blower.
In 1991 I purchased a used 1984 Gilson 16 HP opposed twin. It was a horse!
Willscary is online now
post #7 of 12 Old 08-18-2019, 05:20 PM Thread Starter
I will definitely agree with you on the simplicity’s ability to operate on hills, no doubt about it. The conquest now has a set of Carlisle super lugs, s well as wheel weights and 4wd. My issue is that the transmission is just not holding up to the slopes, lugging the 900lb tractor + deck without operator. Have already rebuild the transmission once, run 10w50 oil, and don’t tow anything.
I might pick up a prestige like we used to have, with the k72, and put the super lugs and wheel weights on it. Thanks for the help
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #8 of 12 Old 08-18-2019, 05:28 PM Thread Starter
What do you guys think of this? $600 Canadian, 20hp Vanguard, 1750 hours, 50” deck with hydraulic lift. Everything works as it should, the owner is who I sold the prestige too. Do you guys happen to have any idea what transmission these use? It is a hydro. Here’s a picture:
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #9 of 12 Old 08-18-2019, 06:11 PM
Willscary's Avatar
I am NOT an expert on this, but Agco Allis was built by Simplicity. that looks to me a lot like a 1999-2001 Landlord 20 DLX. That would be the earlier model of the Prestige. Should have a K71, but I am not sure. Should also have hydraulic lift.
post #10 of 12 Old 08-18-2019, 08:32 PM Thread Starter
Okay,
Do you think it would be worth buying at that price?
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #11 of 12 Old 08-19-2019, 08:24 AM
Willscary's Avatar
I have no idea what it is worth...
post #12 of 12 Old 08-19-2019, 09:55 AM
Professional Homeowner
steddy's Avatar
A bit off topic here, but when sidehilling, removal of the FEL will be safer. A full bucket may lower the C of G, but it will also make the machine more likely to teeter on the front axle center pivot point, which will make the machine less stable. The loader probably won’t save you at that point.
If going up/down the hill, use 4wd (especially going downhill!) and the loader may be beneficial as ballast going uphill, and will stop the tractor from tipping forward when going downhill, if carried low enough.
steddy is online now
