Blown k321 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Unread 08-17-2019, 11:49 AM Thread Starter
Michael
snowplowdog1288's Avatar
Blown k321
Yesterday while I was digging some concrete out from the backyard with my Jacobsen. The engine suddenly sounded different and before I could shut it down it stopped running but the flywheel kept spinning for quite some time. This morning I confirmed my suspicions of s broken connecting rod when I pulled the engine.
It may be hard to pick out but in the last picture you can see where the bottom of the cylinder wall is broken, so I donít think itís a candidate for rebuilding. Iíve been looking for a donor motor and the only K321 Iíve found has no compression so I donít think Iím willing to take a chance on that one. Regardless of where the donor motor comes from I will have to use my original oil pan as it is welded to the frame rails. So, therein lies my question. Does the 12HP Kohler and 16HP Kohler use the same block? I have found a John Deere 316 reasonable as well as a Jacobsen GT12 that arenít too far from me. Otherwise, does anyone know what tractors may have come with the motor Iím looking for? If anyone has a lead on a good Kohler K321 close to southeast Wisconsin I would be excited to hear about it.
Why do they have braille buttons on Drive up ATM's?
John Deere 312, 46" deck, integral hitch, 33 tiller, powerflow bagger
Jacobsen GT14 with Johnson Workhorse 10TC loader
snowplowdog1288 is online now
post #2 of 17 Unread 08-17-2019, 02:29 PM
Still lovin' the 322!
PA318Guy's Avatar
Re: Blown k321
On the one with no compression is the piston moving? Could be a stuck valve causing the no compression issue.
Current Machine JD 322
PA318Guy is offline
post #3 of 17 Unread 08-17-2019, 02:48 PM Thread Starter
Michael
Re: Blown k321
I donít know. I havenít contacted the seller because I donít know for sure it will fit.
post #4 of 17 Unread 08-17-2019, 10:24 PM
Re: Blown k321
There are two diffent oil pans. The other style is not interchangeable with yours so won't work in your application. Have the seller send a picture.
RoyM is online now
post #5 of 17 Unread 08-17-2019, 10:28 PM Thread Starter
Michael
Re: Blown k321
I know there are 2 different style oil pans, mine is welded to the frame rails so I canít even remove it. The question is, will my oil pan fit on a 12HP or 16HP engine
post #6 of 17 Unread 08-17-2019, 10:52 PM Thread Starter
Michael
Re: Blown k321
The seller said he thinks itís a broken rod. I already have an engine with a broken rod
post #7 of 17 Unread 08-18-2019, 10:38 AM
Lance Skene's Avatar
Re: Blown k321
Any of the Jake built "GT" 10 thru 16 '72-'76 will have the same block but the JD316 wont.
Lance
__________________
Cockshutt 50
Ford 861 Powermaster
Deutz Allis Front Mower
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
'57 Bolens Super RaM
Lance Skene is online now
post #8 of 17 Unread 08-18-2019, 01:28 PM Thread Starter
Michael
Re: Blown k321
I have a lead on a K321 from a JD 214, Iím assuming that wonít work either?
post #9 of 17 Unread 08-18-2019, 02:20 PM
Re: Blown k321
No... an earlier JD 110/112/140 might work but anything '75 and later will have external flanges on the base of the block that the oil pan is attached to. I have a Jake built Ford with the same issue so Ive been looking for a block quite awhile myself... it has to be pre 1975 which is right about when the JD 200 series tractors began.
Lance
__________________
Cockshutt 50
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
post #10 of 17 Unread 08-18-2019, 03:01 PM Thread Starter
Michael
Re: Blown k321
Yeah, I was able to see a 214 block up close and I can definitely tell the difference.
If the original block wasnít broken at the bottom of the bore (you can see it just below the end of the broken crankshaft in the picture) I would just rebuild it but unfortunately I think that ship has sailed.
post #11 of 17 Unread 08-18-2019, 03:19 PM
MTF CSI
poncho62's Avatar
Re: Blown k321
If you can find an open sided (72-76) LGT Ford with a good engine, that would fit....They seem more common than the Jakes, around here anyways. I see some wanted to make yours a Ford (blue paint).....lol
Ford LGT100
Ford LGT125
Ford LGT165
John Deere STX38
poncho62 is online now
post #12 of 17 Unread 08-18-2019, 03:27 PM Thread Starter
Michael
Re: Blown k321
I know where there is a Jake GT12 but Iím having trouble connecting with the guy. I donít really think 2 less HP would make a difference
post #13 of 17 Unread 08-18-2019, 03:37 PM
MTF CSI
poncho62's Avatar
Re: Blown k321
Shouldn't...Even the 10 hp Kohler "K" seems to have a lot of grunt. I run a tiller with mine.
Name:	014 (Small).JPG
ID:	2391857   Click image for larger version
Name:	018 (Small).JPG
Ford LGT100
Ford LGT125
Ford LGT165
John Deere STX38
post #14 of 17 Unread 08-18-2019, 03:40 PM
Re: Blown k321
You could even use a 10 hp if it has the 301 block which most post '70 10hp do.. and you still wouldnt notice any differance. The 10/12 engines seem to be less likely to bust a rod than the 14/16s... possibly because the pistons are lighter. Ideally the 301 block is the best one to start with for a rebuild.
Lance
__________________
Cockshutt 50
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
post #15 of 17 Unread 08-18-2019, 04:05 PM Thread Starter
Michael
Re: Blown k321
The trick is finding one. The only one Iíve found is the 12HP. Everything else is ridiculously overpriced or too far away to make it worthwhile
