Time To Dump The Conquest 4x4 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 08-16-2019, 08:47 AM Thread Starter
Long Time Thread Stalker
AddictedToTractors's Avatar
Unhappy Time To Dump The Conquest 4x4
Well guys,
Time to get rid of it. Just not big or reliable enough for what we do, mowing 3+ very hilly acres on the farm. Just got the engine running on both cylinders again, and then the k664 died. Needed a new pump, motor, and Center case, for a healthy $800 . So my point is, what should I look for next? Budget is $4000 CAD. Preferably something with a heavy transmission and a machine that is easy to work on. Also, don’t want something too old either.
Thanks in advance,
Addicted
2009 Simplicity Conquest 4x4 - 23hp Vanguard
- 50” deck
- 46” Single Stage Thrower
2015 Kioti CK30
- Walco 66” Box Blade
- Art’s Way 66” Snow Blower
- Bush Hog 12” Post Hole Auger
- Woods 60” Rotary Cutter
- Homemade 800lb Ballast
- Stoll Loader
- 62” Bucket
- HLA 2,000lb Pallet Forks
- HLA 66” Snow Pusher
1999 Gehl Sl3825 Skid Loader
2006 Simplicity Prestige - Sold
AddictedToTractors is offline
post #2 of 12 Old 08-16-2019, 04:33 PM
Willscary's Avatar
Re: Time To Dump The Conquest 4x4
I hear you. My Conquest was a GREAT machine, but the K66 struggled on the steep hills by my ditch line. I am a bigger guy and although the K66 did always make it up the hills, it struggled a bit under load. Towing the trailer up to the brush pile would slow it down. The K72 in the Prestige has Zero issues at the ditch line and the only way that I have taxed it at all is when going to the brush pile (about 70 feet of rise in about 300 yards with some steeper inclines) when towing a 1600 pound 5X10 trailer with a load of wood in it (perhaps 3,000 pounds total).
A Prestige would be a better bet. Same great cut plus more power. If not, a Legacy would be next. Again, a quality cut and the power of a K92. My next upgrade will be to a SCUT, most likely a Massey Ferguson GC1725 with a backhoe, but the Prestige would still mow...the MF would take over all of the real tractor type duties.
Edit: I re-read your post and see that you have a Kioti and you are looking in the used price range. I would think that a Legacy with only a mower deck would be found in your price range. Otherwise, an older JD 4xx or 5xx would have the same K92 power, but the mower cut would not be as good.
I own a 2017 Simplicity Prestige 27/52 EFI, JB Jr, Johnny Plow Jr.
From 2015 to 2017 I owned a used 2013 Simplicity Conquest 27/50.
From 1996 until 2015 I owned a White LT-16 Vanguard V-twin and 2 stage blower.
In 1991 I purchased a used 1984 Gilson 16 HP opposed twin. It was a horse!
Willscary is offline
post #3 of 12 Old 08-16-2019, 06:58 PM Thread Starter
I actually had a 23hp prestige, found traction to be an issue. With wheel weights and ag’s I think it would be ok, just ad it to the budget...
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #4 of 12 Old 08-16-2019, 07:11 PM Thread Starter
https://i.ebayimg.com/00/s/NjAwWDgwM...dVClP/$_59.JPG
The conquest as she sits:
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #5 of 12 Old 08-16-2019, 07:13 PM Thread Starter
Also,
What is the best way to post pictures?
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #6 of 12 Old 08-16-2019, 08:03 PM
Willscary's Avatar
My Prestige is the new fuel injected 2wd. It has rears filled with about 75 pounds of Rimguard each plus cast iron wheel weights that add another 53 or so pounds each. I have pretty good traction. In the winter, I plow. I have an additional 134 pounds of weight that I put on the rear hitch, plus the weight of the snow cab. It also works well.
post #7 of 12 Old 08-16-2019, 08:52 PM
Don
Originally Posted by AddictedToTractors View Post
Also,
When you reply a window opens up for you to type. Scroll down to bottom left and see the " manage attachments" Hit that and a window opens up and says "choose a file". Hit that for every picture you want to upload to the thread. Then hit "submit"
Don
post #8 of 12 Old 08-16-2019, 08:58 PM Thread Starter
Thanks man
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #9 of 12 Old 08-16-2019, 09:05 PM Thread Starter
Here are more pictures:
If anyone’s interested, send me a PM, asking $6500 cad for tractor, turfs, ag’s, 46” thrower, 50” deck, custom work light, bumper, trailer hitch.
ID:	2391583   Click image for larger version
ID:	2391585   Click image for larger version
ID:	2391587   Click image for larger version
ID:	2391591   Click image for larger version
ID:	2391593   Click image for larger version
- 50” deck
2015 Kioti CK30
- Stoll Loader
- 62” Bucket
post #10 of 12 Old 08-16-2019, 09:35 PM
Don
Looks like a nice looking machine.
Don
post #11 of 12 Old 08-18-2019, 09:32 PM
Nouveau Redneck's Avatar
You don't need to go to a K92 just because you have a lot of hills. The K72 is more than capable on steep hills. My JD X500 and X530 both handle some very impressive hills on my property and have never been at a loss for power. In certain circumstances there can be a loss of traction, but that can be controlled by either more weight or using the differential lock pedal.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #12 of 12 Old 08-26-2019, 12:08 PM
Just buy an old Bolens HT sιries and you will be very happy...
Hrc630 is offline
