JD or Husqvarna - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #31 of 102 Old 08-16-2019, 01:03 AM Thread Starter
still.try.decide's Avatar
Re: JD or Husqvarna
Originally Posted by Steve Urquell View Post
Thats a good small sized tractor that would probably make you very happy.
So which JD today is the equivalent to that JD855 of yesteryear ?
still.try.decide is offline
post #32 of 102 Old 08-16-2019, 08:08 AM
Steve Urquell's Avatar
Re: JD or Husqvarna
2025R TractorData.com John Deere 2025R tractor information
2001 Cub 3240 with fabbed hydraulic sleeve hitch and Swisher Hydraulic Front Bucket
Steve Urquell is online now
post #33 of 102 Old 08-17-2019, 12:45 PM
Re: JD or Husqvarna
Hi everybody
I will need to buy a garden tractor to cultivate a couple of acres, 2 at first, then maybe clear some land and work on more. I really like the specs of Husqvarna GT52XLSi, (dif lock, strong enough tuff torqe transaxle) but I don't like their frame twisting and buckling. I want to use my tractor with a moldboard plow, cultivator, harrow etc. and maybe even with the front plow/loader. So I am really leaning towards JD x570, it's more expensive but in the long run what good is Husqvarna if the frame buckles. Also my terrain is uneven and we got a little bit of a slope. What would you guys choose? Someone said not to discount Cub Cadet, but I also have to look at dealerships, and around Fredericton New Brunswick there are not that many choices, I need to look at the future service, parts etc. Would JD X570 be a good choice?
thanks
Hey,
You need a real tractor. The implements for garden tractors are not very good to work the ground. They are small also. The tiller and I suppose a plow are about the only things worth getting. I have had real farm equipment, when farming, and now a GT and an LT and now work 1.5 acres. It's almost impossible especially if you aren't going to use herbicide. You just can't get anything done in any reasonable time. Going over the ground a few times to get it in shape, etc. gets old real fast. The ground gets harder during the summer and the implements need lots of weight and get harder to pull and do very little. Lots of weight is needed for these little implements that are almost a joke. If rain is on the way and you want to get something done fast, you can't. GT's and LT's can be used for gardens and maybe a 1/4 to 1/2 acre but that is it farming wise. I don't do any of the other work you are talking about possibly doing but I can't image using a GT for very much of that kind of work either. Just get some kind of real tractor that has been dependable and can be worked on if ever needed by a mechanic. I would get something from the 1960's on up because they are much more modern than around 1960 on down. You can get several good implements, cheap, that will always work for a real tractor.
Rando58 is offline
post #34 of 102 Old 08-17-2019, 01:11 PM
Blank Space
Re: JD or Husqvarna
So you guys are telling me that a 20 or 30 yr. old tractor, will be trouble free, vs. a new John Deere x5** ? I thought that JDs, even small ones were tough? and old stuff is.... old stuff. it's like buying a car, I woudl always choose a new car over an old Ford. Tractors have the same components as cars; wheels, engines etc. so they are bound to break down if they are old. right? what am I missing?
Computerization. A small electronic glitch can render a new tractor (car or truck) useless and can be very expensive to repair, even if the brand will allow you to do so. JD is getting a name for NOT allowing owners to repair their own machines without having a Tech reset some code for a fee.
Older machines are still generally plentiful enough that third party parts makers are keeping parts available that most backyard wrench turners can replace easily.
LS MT125
post #35 of 102 Old 08-17-2019, 01:13 PM
Blank Space
Re: JD or Husqvarna
I really like the 4 yr. warranty from John Deere, on new tractors
LS is six years.
LS MT125
post #36 of 102 Old 08-17-2019, 01:19 PM
Blank Space
Re: JD or Husqvarna
I have 24 acres and really need ~a 25-30HP tractor.
In my opinion, with 24 acres, you need a LOT more than a 25HP tractor, maybe double that.
LS MT125
post #37 of 102 Old 08-17-2019, 02:39 PM
Re: JD or Husqvarna
Yes a real tractor is totally in a different world than a GT and even a GT on steroids. Consider this. For starters 2 acres for a real tractor is hardly any work for it. But boy will it do the job and your other work you want to do too. Look at the tractor you can get compared to the 500 series for the same money. 500 series is good but not for what you want. This is meant for the OP.
Rando58 is offline
post #38 of 102 Old 08-17-2019, 02:45 PM
Re: JD or Husqvarna
Hi everybody
thanks
I made a mistake and posted under Obscured by Clouds that is for you.
Rando58 is offline
post #39 of 102 Old 08-20-2019, 10:25 PM
Tech Exchange Moderator
Sergeant's Avatar
Re: JD or Husqvarna
2025R will handle 2 acres of Garden and even More I own Both a 2025R and a X748(older version of a X758) and then a few More Garden tractor as well. I used a Garden tractor for Years On 3acre Gardens Used a JD 240 which would be close to a JDX570 as far as the 240 used sleeve Hitch Implements & a 30inch Belt driven PTO tiller. The 240 also used a Manual lift spring assist to raise & Lower Implements Only thing it doesn't Have is Diff/lock which the JD X570 has.
About 3 to 4 years after I bought the JD 240 I added a Ingersoll Garden tractor with a Hydraulic lift Cat 0 3 point Hitch to complement the JD 240 for Garden work Then about 7 to 8 years Later I added a White GT2055 Because I finally wanted a Loader Tractor. But it Lacked Power steering so I Bought a Used JD 425 so I could Have a Loader tractor That Had Power steering. I used that for about 2 Years On that 3 acre Northern NY Garden. When I retired from the Army In 2002 I used the 425 & White GT2055 to Handle a 3.5 acre Garden. Traded the 425 In 2003 for a JD X485 with a Loader & Hydraulic tiller to Handle that 3.5acre Garden Until 2014 when I traded the X485 for a used 2012 X748. we Moved to a New Place In 2016 where I have about a 1.7 acre Garden for which I Bought a JD 1025R in 2017 to Help with the Garden work. Finally Upgraded that to a 2025R In summer 2018. I have a Mowing deck for the 2025R But I don't use it. The deck just sits On a shelf collecting dust. I did Use the 2025R for Tilling work for Garden Prep this Past June. But all it's done since is Backhoe work
While the 2025R does Great with the Prep work I find Myself Using the X748 More In the Garden than the 2025R. Which really Only Bought the 1025R & 2025R to do Backhoe work anyways . For a 3 acre Garden really the Deere super Garden tractors ie X700 series Tractors are really suited for Garden work. If Your Just Growing row Crops the Compact tractors will Probably be fine Ie Beans & Corn But I grow Watermelons and Tomatoes and other things as well and a Garden tractor is Just More Nimble to work In the Garden. Actually this Year I have used my 2004 GX335 In the garden More than the X748. I am actually Looking at adding a 2 Wheel tractor for use In the Garden once the Corn Gets 6inchs Tall https://www.earthtools.com/tractors-bcs/bcs-852-853/ because there More suited for Cultivating duties with a Power Harrow .
But for Now In Your Case I would start off with the X570 and Go from there you Can always Upgrade if You need more tractor.
BTW I use a Johnny Products electric Lift sleeve Hitch On My JD GX335 and a Johnny Products electric Lift Kits On MY OEM sleeve Hitch On MY Cub Cadet XT3. The wife wants to get a 30inch Bercomac tiller 30" Rotary Tiller for Lawn and Garden Tractors - Bercomac for the XT3GSX so she Can tend to Her Garden Beds. Having a smaller PTO tiller is a real nice thing to have Once the Garden grows Up.
But In closing I would suggest the X570 as a Good Starter tractor for Your Intended needs right now of a 2 acre Garden
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
MSGT 11 & 18 Series Retired
Sergeant is offline
post #40 of 102 Old 08-21-2019, 12:24 PM
Re: JD or Husqvarna
It looks to me that what you need is much more than a garden tractor. Go for an old farm tractor. I bought a 1948 JD Model A in great condition for $500 plus hauling to my place. All it needed was a paint job. I also bought an 1948 Allis Chalmers WD. I work 15 acres, plow, till and mow. I sold the JD now use the AC. I needed to purchase a 3 point hitch kit was all. The WD's now sell for around 2-3 K$ in great shape, parts are available, and they are a great tractor. As long as upkeep is good on these old guys they will do anything you would want. Of course if you want heat and AC and a cab go modern. I personally would not buy any current new equipment for the work you want to do. Check Allischalmers.com, Yesterdaystractors.com all list great old farm equipment. I would always recommend JD with todays equipment.
alliswd1948 is offline
post #41 of 102 Old 08-21-2019, 01:02 PM
Re: JD or Husqvarna
My first farm tractor was a 1971 Ford 2000 I bought used in 73.....it has set outside since then, the plastic has fallen off the steering wheel from being in the sun, the paint is rough, and I don't use it now but every three years. Will start right up with a jump, and only have changed fluids since I got it.....Not many farmers anymore so medium size farm tractors used are cheap and so are the implements. They are super reliable and easy to work on...even if you need to hire it done. Homeowners are everywhere and the size tractor toy that Harry Homeowner will want is expensive and needs constant attention....buy what you think you will like....
Cranman is offline
post #42 of 102 Old 08-21-2019, 01:25 PM
I bought a 52xlsi. I was so unhappy I returned it to the dealer. It would not run. They gave me a ts348d. I would buy anything else but a Husky. They are garbage. Worst purchase of my life.
Chadbyrum is offline
post #43 of 102 Old 08-21-2019, 02:31 PM
murph55's Avatar
Re: JD or Husqvarna
Now your talking! The 855 is the best one the OP has said he's willing to consider that will not disappoint him, and be able to keep up with any of his planned or anticipated tasks. The condition will determine the price. It will also sell again for what you paid for it years down the road.
Opinions on what I've read so far in this thread...
3-point hitch is far superior to sleeve, there are plenty of used implements out there for the same cost or cheaper than lightweight sleeve-hitch tools. Remember, it's the power and the weight that gets the job done...you need both! Any used 3-point implement can be sold for probably what you pay for it...more if you clean it up and paint it.
There's a reason that 60-yr old tractors are 60 years old...it's because they last and are relatively bulletproof compared to the newer and lighter machines. I can buy a recently restored/freshly repainted Ford 8N with 12-volt updated charging system and new ag tires in my neighborhood for $3500, and it will work all day long and do anything listed in this thread. Don't discount older stuff just because it's old!
If you are sold on new machines, JD & Kubota are the top of the pile, just get one that will do the work. Buy once, Cry once.
JD 4720, 400X FEL, JD MX6 Brush Cutter, 72" JD 7-Iron MM mower, 7ft Farm King disk, 6ft LandPride scraper/pulverizer, 7ft King Kutter II rotary tiller, 7ft King Kutter landscape rake, 6ft Buhler box scraper, 2-row Yetter planter, 3pt quick hitch, 3pt trailer hitch lift, 3pt carryall, Hydraulic top link, Wallenstein BX62 chipper
JD X720, 60" 7-Iron mower, 47" front-mount snowblower. JD Soft Cab 15cu. ft. dump cart
murph55 is offline
post #44 of 102 Old 08-21-2019, 02:55 PM
Professional Homeowner
steddy's Avatar
VERY subjective here. Depends on what youíre trying to do, how much time you want to spend doing it, budget, among other things.
Between my dad and I, we have close to 25 acres. A 25 horse CUT would be sufficient, once we finish building our house (basically a big landscaping project. Other than hauling a bunch of dirt with bigger loader that comes in that class machine, the 20 extra horse just isnít a major must have benefit). That said, it is nice to have 20 more horsepower now and then. Bigger jobs donít tax the bigger machine as much. I did run around on my 23 horse SCUT for awhile. Biggest problem I had was tire size. Rough ride. The backhoe available for that machine would have worked just as well as the one on my 46 horse tractor to remove all but maybe 2 of the stumps I took out. Those 2 were too much for my 46 horse machine, and a LOT bigger than the other 70 or so I dug out with ease.
If we had 1 acre and 30 oak stumps to remove that were each 4í across, my 46 horse tractor wonít cut the mustard, even though itís only one acre.
The point is that Acreage size is definitely not the only most important factor.
steddy is online now
post #45 of 102 Old 08-21-2019, 04:36 PM
Re: JD or Husqvarna
I see this all the time a person on a limited budget wants to buy the cheapest unit he can afford but wants to do the work of a much more expensive unit. Would you buy a half ton truck for price and use it to haul what a one ton truck would haul? To use ground engaging implements takes a good solid tractor not some light duty want to be a tractor, and to add a Loader----well that really would test the frame. I have a 14 Massey Ferguson that I use a full size planter unit on I would not consider using it on on of the new wanna be tractors. Also have a 400 JD well tested and tried it is equipped with a loader and hoe, does a lot of work but even that I can feel the frame give especially when the bucket is loaded to one side. The new tractors whether JD Husqvarna CC or whom ever can put their label on it have gotten bloated with "niceties" and thinner metal, quality small tractors are a thing of the past. As much as I hate the imported compacts with all you want to do I would suggest you chose of those. It will last you many years of service if taken care of and uses a standard cat 1 hitch, and are made for loaders and heavy ground engaging tools. They usually always come with diff lock and are available wit 4 wd. Even an older well cared for farm tractor (MF 135, JD 1020 or a similar sized tractor) will out work and outlast any of todays lawn and garden tractors. A compact or a used farm tractor will still be working while you are replacing that LGT. My thoughts-- Thanks for listening
Busted Tractor is offline
