Sixth terminal on key switch - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 08-12-2019, 12:29 AM Thread Starter
What is the sixth terminal for? I need new switch. I have switches with five terminals only. See purple wire. Not common with other terminals. Engine is a 23hp EFI.
Hydronerd is offline
post #2 of 7 Old 08-12-2019, 06:50 AM
4Get GTO's Avatar
Re: Sixth terminal on key switch
I found this but may not help if your switch doesn't have any markings..
The letters on the back of an ignition switch stand for the following:
M = Magneto
S = Starter Solenoid
L = Lights
A = Accessory
B = Battery
G = Ground
I = Ignition
R = Regulator/Rectifier
The designated terminal connects in some manner to that component. For example, the B terminal connects in some manner to the positive battery cable.
4Get GTO is offline
post #3 of 7 Old 08-18-2019, 09:18 PM
Nouveau Redneck's Avatar
It would help us in helping you if you mentioned what make and model of tractor it is.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #4 of 7 Old 08-18-2019, 09:39 PM
Lance Skene's Avatar
fuel solenoid maybe??
Lance
__________________
Cockshutt 50
Ford 861 Powermaster
Deutz Allis Front Mower
Columbia(MTD) 960
Ford Lgt 100
JD 110 (sf)
AC 718H
AC 712S
AC B-10
___________________
'57 Bolens Super RaM
Lance Skene is offline
post #5 of 7 Old 08-18-2019, 09:54 PM Thread Starter
How does that matter. I googled the above title and got some images, but no description of that terminal. It’s just a standard indak key for a magneto type B&S. I’ve got a dozen in my spares box, but none with sixth terminal. Alright, it’s from a Walker T-something (only one with 26hp EFI engine). I looked at the parts and operator manual but neither show the wiring circuit, just wire harness connection. It appears to be a ground as it’s daisy-chained to other devices (and it’s not for illumination); which also means the key has two ground terminals. I know (at least on other magneto tractors) the ground is used for safety circuit. If safety goes to ground they won’t run. Most of my tractors are 30-40 years old and don’t have too much safety stuff.
post #6 of 7 Old 08-18-2019, 10:37 PM
Originally Posted by Hydronerd View Post
How does that matter. I googled the above title and got some images, but no description of that terminal. Itís just a standard indak key for a magneto type B&S. Iíve got a dozen in my spares box, but none with sixth terminal. Alright, itís from a Walker T-something (only one with 26hp EFI engine). I looked at the parts and operator manual but neither show the wiring circuit, just wire harness connection. It appears to be a ground as itís daisy-chained to other devices (and itís not for illumination); which also means the key has two ground terminals. I know (at least on other magneto tractors) the ground is used for safety circuit. If safety goes to ground they wonít run. Most of my tractors are 30-40 years old and donít have too much safety stuff.
My local auto parts stores carry 2 mower ignition switches- a 5 term and a 6 term.
They are pretty common.
TobyU is offline
post #7 of 7 Old 08-19-2019, 06:06 AM
The reason that I asked is that the same key switch could be used in different applications with the various terminals connected in different ways, and there may be many different key switches with that number of terminals.
We didn't even know if it is for a diesel or gasoline engine, so that extra terminal could be for the fuel shutoff solenoid or the glow plug circuit if it is for a diesel engine, or just an extra terminal that's hot with the key in the run position for any of a number of possible accessories. Someone with knowledge of the particular tractor that you are working on could probably get you a more precise answer in a shorter amount of time if you provide the details of the machine.
Nouveau Redneck
Sean in PA
