Lousy Traction with older Craftsman Tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 07-14-2019, 05:07 PM Thread Starter
Strahbale's Avatar
This is a 1990 model year Craftsman with 20hp Kohler. I bought it used a couple of seasons ago and it works well
except on any bit of slope. The back wheels spin and I can generally rock it by shifting my weight.
The tires are in seemingly good condition and don't warrant replacements.
I've been wondering about installing studs like we used on snow tires.
Thanks for such a wonderful forum that help keep tractors working.
Strahbale is offline
post #2 of 16 Old 07-14-2019, 05:20 PM
Re: Lousy Traction with older Craftsman Tractor
Doubt that studs will do any good. Only one tire is actually pulling and the one that gets light is why it loses traction.
Wheels weights might help, I've heard of making such using concrete or place weight on the uphill fender and test.
Forest Gump is online now
post #3 of 16 Old 07-14-2019, 05:23 PM
MTF CSI
poncho62's Avatar
I am thinking it has turf tires on it. I had the same problem with my Ford LGT. Was advised to find some ATV tires. Made a world of difference.
ID:	2386563   Click image for larger version
Ford LGT100
Ford LGT125
Ford LGT165
John Deere STX38
poncho62 is online now
post #4 of 16 Old 07-14-2019, 05:46 PM
Right about ATV lug tire, I have a set on a lawn tractor, but both rear tires have to be on the ground. Turf tires will spin and not damage the turf and grass and have weak traction. 5 lug rims like in this picture are common, I've seen MTD, Craftsman and John Deere lawn tractor rims have the same 5 lug bolt pattern if you do not want to have some tires re-mounted onto your rims. (breaking down some of them types (looks like 12 inch dia) will create quite a sweat during hot weather sometimes)
The ATV lug tire won't do any good unless it's touching the ground. The traction will depend on the weight of the uphill tire on the ground. The lighter loaded tire is one that will spin and the front axle swiveling also helps create the uphill rear tire loosing traction. I've seen some small strap type chains that are easily installed and removed that fit through the slots in these type rims also.
post #5 of 16 Old 07-15-2019, 02:19 AM
All I can add is keep the pressure low. They only go to 10 psi rear, 14 front. Many people over-inflate them and that lowers traction.
TobyU is offline
post #6 of 16 Old 07-15-2019, 03:15 AM
TahoeJoe's Avatar
I had the same problem, I put chains on and they work very well. No slipping. The downside is that chains are aggressive and mine have spokes poking out. They hit and scrape the deck up, and you cant drive on a driveway, the spokes will ruin whatever you drive on, except for a dirt or snowy field. So if you stay in the fields, you're good.
Here's a pic of my jd helping out my craftsman get over a bump, but you can kinda see the chains
TahoeJoe is offline
post #7 of 16 Old 07-15-2019, 05:39 AM
Kubota Ronin's Avatar
Strahbale, is there a date code on your tires?
Even though they might seem to have plenty of rubber left, if they're original to the machine @nearly 30 years old they will have hardened with age and have significantly less grip than fresh rubber.
Also agreed to check your tire pressures... I find best results with mine running about half the maximum pressure. Drive through a puddle and then onto something that shows the tread pattern and see if the whole tire is making contact.
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #8 of 16 Old 07-15-2019, 02:23 PM
20,000 Posts & Climbing
Load the tires with liquid ballast. That will improve traction and stability on the slopes.
TUDOR is offline
post #9 of 16 Old 07-15-2019, 04:32 PM Thread Starter
Strahbale's Avatar
Great advice from all of you. Thanks ever so much. I like the idea of using ATV tires and perhaps wheel weights.
The tractor is at our cabin, so it'll take a couple of weeks to report results of the suggestions
post #10 of 16 Old 07-15-2019, 07:08 PM
Steve Urquell's Avatar
Try the ATV tires before anything else. I haven't needed any weight with mine and I play hard.
Steve Urquell is online now
post #11 of 16 Old 07-15-2019, 07:16 PM
Collector of many tractors
Kbeitz's Avatar
Replace the front wheel bushings with bearings....
Kbeitz is online now
post #12 of 16 Old 07-15-2019, 07:18 PM
mowergene's Avatar
Simply put your weight over the spinning wheel. "Ride the Fender"
In the past:
In use:
mowergene is online now
post #13 of 16 Old 07-16-2019, 06:15 AM
What does that do?
RedOctobyr is online now
post #14 of 16 Old 07-16-2019, 09:22 AM
Bob E's Avatar
Less rolling resistance.
Bob E is offline
post #15 of 16 Old 07-16-2019, 12:48 PM
Sure sounds like rock hard tires. Someone mentioned 10 LBS pressure in rears. That's what my JD x500 has and if I need more traction, they get set back to 7 or 8 LBS.
Are you in gumbo muck soil or on top of dry sun polished straw? Can't imagine how these are spinning.
X 500 48" Deck 48" blade
Cyclone Rake
Stihl BR 600
Sears Suburban Super 12 1968
Alien5044 is offline
