Maintenance vs Warranty - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 05-30-2019, 11:50 PM Thread Starter
I have a Cub Cadet XT1 46 with the K46. It is about a year old now and coming up on 50hrs on it. Part of me really wants to drop the K46 and do a drain a fill, as I do work it a little, but the other part of me says that I shouldn't touch it, as I still have 2 yrs unlimited hours of warranty coverage, and I'm afraid that doing maintenance on a "sealed unit" may void my warranty.
From what I understand the first fluid change is usually the most important, and something that I would want to do early on. I could wait until my warranty is up, but at that point I feel like it may have taken a lot of extra wear while still "'surviving."
FWIW, I usually try to mow the steepest part of my yard first, then move on to the flat section to give it some time to cool before finishing with the lesser sloped area. I also use it to maintain my gravel drive which is also quite steep. This usually requires my leaning and working to manage wheel spin (open diff) when pulling the loaded drag up the hill, but not sure how hard this is on it. I try not to "beat on it, and if it starts to get too hot to the touch while working on the drive I give it a rest or park over a sprinkler for a few before continuing.
I know I am probably pushing it a little beyond what it was designed for, but I really like the tractor and want it to last as long as possible. What would you do?
INeedATractor is offline
post #2 of 22 Old 05-31-2019, 12:23 AM
TriumphMan's Avatar
Re: Maintenance vs Warranty
I've seen the XT1 at the local CC dealer/farm center I frequent for other items, but I'm unfamiliar with its capabilities and build.
If this model does have a sealed unit, don't touch it as for sure it could very well void the warranty, depending on how the warranty is written. It might void the mower as a whole, or just the part that you worked on that wasn't designed to be a maintained item.
If it is sealed, how by dropping the transaxle would you be replacing the fluid? Is there a plug on the top, or go through some cover you've been told about? Is the fluid something you can even get at your local dealer? I'd start there first, because if its' not available and you put in something that the bearings/seals aren't designed for, or a different viscosity than found at a local automotive store, it could spell even bigger problems later on.
OTOH, If it did have a fill/drain plug for doing what you want, that'd be a different story as then the factory would be saying that this unit needs maintenance to do the job over time and has a certain schedule to maintain. Then you could get the proper fluid, or a fluid that's comparable to the factory fluid specs, and do the drain/fill routine, but keeping the receipt and make a log as to the maintenance/date and you'd be covered according to the Magnason-Moss Act.
Del
1967 Cub Cadet 102-Kohler K241(10hp) Kept as original as possible.
1990 Kut Kwick CL20-60-Onan P220(20hp) Front deck/rear steer industrial/commercial mower
2003 Craftsman GT5000-B&S engine(24hp) Manual transaxle
TriumphMan is offline
post #3 of 22 Old 05-31-2019, 06:15 AM
20,000 Posts & Climbing
Pose the question to the dealer. How he answers may drop the ball back into your court and you'll have a decision to make at that time. Especially so with the work that you're doing with the K46.
TUDOR is offline
post #4 of 22 Old 05-31-2019, 06:34 AM
rudedawg's Avatar
This one for sure....
rudedawg is offline
post #5 of 22 Old 06-03-2019, 06:06 PM Thread Starter
Del
This unit does not have a drain plug, but from what I have read I can drop/remove the trans axle and drain/fill through the fill hole which should be accessible from the top once removed. I also read to refill with 5w50 synthetic motor oil. This is going based on what I have read on this forum and is hopefully correct.
This is a good idea. I did not even think of calling a dealer for their input, as I had purchased from a "Box Store," but if I had a problem they would be the ones to see it anyways.
Thanks to all for the replies.
post #6 of 22 Old 06-11-2019, 11:02 AM
Tech Exchange Moderator
Sergeant's Avatar
If the transmissions fails Under the warranty Period MTD will replace it . There Not Like Husqvarna They will actually handle the warranty In House . I have a friend with a XT2 GX54D He hasn't Touch the transmission but as soon as the warranty is over He will start doing Maintenance On it. The dealer was fine with Him changing out the fluid if He wanted to do it before the 3 year Unlimited Hr warranty was Up
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
MSGT 11 & 18 Series Retired
Sergeant is offline
post #7 of 22 Old 06-17-2019, 07:06 PM
FLHusqGT's Avatar
You have some great advice already, I just want to weigh in on the oil if you choose this route and make sure the wrong oil advice isn't followed
The 5w50 is right but it is crucial that it meet JASO MA2 standards according to Tuff Torq.
It should say on the bottle that it is formulated for "Wet Clutch" applications, such as ATV/UTV oil. The K46 has a wet brake.
Most oil for our cars have friction modifiers for enhanced fuel economy and such, this would or could cause harm in the K46. I have left you with all the official documentation I have on checking the oil/ kind/ and maintenance of the K46 from Tuff Torq. I hope this helps.
By the way, the lawn tractor chassis in your XT1 is a very tough/ durable chassis and is also in the Cub Cadet Yard Tractors (XT2). A good tractor.
I left a picture of what I use in my K66 on the Tuff Torq Maintenance schedule. I'll leave a copy of that too.
Name:	Cub Cadet XT1 Chassis.jpg
ID:	2382301   Click image for larger version
Name:	K46 Air Purge Proceedure.jpg
ID:	2382309   Click image for larger version
FLHusqGT is offline
post #8 of 22 Old 07-16-2019, 05:17 PM Thread Starter
Just wanted to take minute to update this thread with the input I received from my local Cub dealer.
Basically, I was told that a "sealed" trans axle is not meant to be serviced, and for that reason, any work done, even it was maintenance, would void my warranty on the unit.
I could hear the person I spoke with asking some of the other employees, and to be honest, I was not impressed with the dialog I overheard. They could not understand/comprehend the logic behind servicing the unit, and kept asking why I would want to do maintenance on a maintenance free unit. I tried to explain that just because it is not a simple task to perform without a drain plug, it doesn't mean that the unit would not benefit from some fresh fluid, kind of like the Briggs no oil change system. This kept going in a circle back to the "It's a sealed unit that's not meant to be serviced, so why would you want to do that." The conversation pretty much ended with them saying when they die they die, and that's all there is to it
That said, I am not sure how I am going to proceed with this. The options I am seeing are...
1. Take my chances, drop the unit and change the fluid and hope I don't have any warranty issues
2. Use it as I have been, allowing time to cool in between working it hard and change the fluid as soon as my warranty coverage is up
3. Use it as I would a larger machine without taking breaks, get stuff done faster, just use the warranty if needed and sell/replace the tractor with something beefier after the warranty expires
post #9 of 22 Old 07-16-2019, 05:21 PM Thread Starter
Thanks FLH for the wealth of great information! The bit about the JASO MA2 standard makes a lot of sense and was not something I was aware of or had considered.
I have bookmarked for reference.
post #10 of 22 Old 07-16-2019, 06:18 PM
You may want to bring up TuffTorq's own website in conversation with the dealer, as much good as that may do.
On this page of Oil Maintenance for the K46:
https://www.tufftorq.com/tuff-torq-k46-oil-maintenance/
There are also numerous videos on Youtube regarding oil changes for the supposedly unserviceable K46.
Flaken is online now
post #11 of 22 Old 07-18-2019, 12:21 PM
People have been using Mobil 1 5w-50 or 15w-50 for a LONG time with great results. The wet clutch in a motorcycle motor is a completely different animal than the wet brake in the K46. The motorcycle clutch has fiber faces plates bearing against metal plates. It's the fiber plates that need the "protection" of special oils. The K46 brake is a metal disc and metal pucks. No type of oil is going to give this brake progressive action. It's mostly a parking brake.
BTW, I used Mobil 1 car oil in my last 4 stroke road racing bike. It's use was almost universal.
rayjay is offline
post #12 of 22 Old 07-18-2019, 12:22 PM
I also have a question. If you did change the oil how will the dealer know it ???
rayjay is offline
post #13 of 22 Old 07-18-2019, 08:16 PM
Simple solution; 2 year warranty at 50 hours per year equals 100 hours at the end of warranty. After the warranty is up, change the fluid.
When you drain the fluid, evaluate it's condition and make your decision on whether to buy a new tractor with a better hydro or keep that one.
The hardest task for the hydro that you mentioned is mowing the steepest slope, but you're doing it while the hydro is relatively cool. Pulling the drag is not quite as hard unless you are applying ballast for improved traction.
TUDOR is offline
post #14 of 22 Old 07-20-2019, 10:09 AM
Jim16's Avatar
"if it starts to get too hot to the touch while working on the drive I give it a rest or park over a sprinkler for a few before continuing."
Not sure applying cold water to a hot transmission is a very good idea.
Jim16 is online now
post #15 of 22 Old 07-20-2019, 11:04 PM
Sell it ans buy one with a filter and drain plug.
Or do what you want( I would not bother) If it does fail under warranty..(which it wont)
MTD will have you take it to a service center. They will never know you touched it if you don't tell them.
How many people do this????? Less than 1% so there is no reason to suspect you have messed with it.
Now....quit buying anything with a K46 in it and the world will be a better place.
TobyU is offline
