What is the best way to clean tractors? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 77 Old 04-10-2019, 07:35 AM Thread Starter
How do you get all the dirt and grime off without scratching them up or hurting electrical system and parts? What is the basic cleaning up method?
Thanks
Rando58 is online now
post #2 of 77 Old 04-10-2019, 07:41 AM
Blank Space
Re: What is the best way to clean tractors?
Tractors are made for workin' not cleanin'. They sit outside, not in a curio cabinet in the family room.
Obscured_by_Clouds is offline
post #3 of 77 Old 04-10-2019, 07:42 AM
Steve Urquell's Avatar
Thanks
I use purple degreaser mixed with hot water in a bucket and a brush.
Start by air blowing and brushing off the heavy crud before wetting. Wet with a low pressure water hose. Spray with purple degreaser and let sit a few minutes. Start scrubbing with the brush and hot degreaser mix then rinse with low pressure hose.
ID:	2371013   Click image for larger version
Steve Urquell is offline
post #4 of 77 Old 04-10-2019, 08:00 AM Thread Starter
I see lots of clean tractors on here, in the barns and outside.
post #5 of 77 Old 04-10-2019, 08:07 AM Thread Starter
That looks like some good dirt and grime. Wow! That's a good cleaning job!
post #6 of 77 Old 04-10-2019, 08:16 AM
Choke's stuck on!
robhay2's Avatar
I like to remove caked mud, especially from pockets in the frame, loader and bucket, since it holds moisture for longer than if the metal were clean. I use a gas pressure washer with a 10 or 25° tip on a dry, sunny day, keeping away from the dash/engine area. Then I blow the pockets out with compressed air. The cleaning only takes a few minutes, plus setting the washer up (usually this is done when the washer is already setup for something else, though).
robhay2 is offline
post #7 of 77 Old 04-10-2019, 08:36 AM Thread Starter
Good advice. It always worries me around the electrical stuff. Never thought about blow drying areas.
Thanks
post #8 of 77 Old 04-10-2019, 08:46 AM
rudedawg's Avatar
I raise the hood and cover engine & electrical components with a small tarp lower the hood and wash away with car wash/wax all in one liquid mixed with water, easy peasy. The hood, side panels and fender tub on mine are all metal so light scratches could probably be buffed out if I wanted to take the time to do it which I don't. Like other said it's a working tractor so it gets washed/waxed once a year at best, although I do blow it off with a leaf blower after each mowing. Good luck.
rudedawg is offline
post #9 of 77 Old 04-10-2019, 08:49 AM
I worked in heavt eqpt fleets for 20 yrs. We kept our eqpt clean. Nothing worse than wrenching on something with crud falling on you or into the engine.
post #10 of 77 Old 04-10-2019, 08:56 AM Thread Starter
Like the tarp idea. Thanks
post #11 of 77 Old 04-10-2019, 09:31 PM Thread Starter
What did you say the tractor is you have? I know you told me but forgot.
post #12 of 77 Old 04-10-2019, 09:44 PM
That Guy
oefveteran's Avatar
I just spray mine off using an air compressor after I mow.
The man fires a rifle for many years, and he goes to war, and afterwards he turns the rifle in at the armory and he believes he’s finished with the rifle. But no matter what else he might do with his hands — love a woman, build a house, change his son’s diaper — his hands remember the rifle and the power that rifle proffered.
Cub Cadet XT3 GSX
John Deere 10P Yard Cart
oefveteran is offline
post #13 of 77 Old 04-10-2019, 10:09 PM
Country1966?'s Avatar
I use a shop vac or air compressor. In my garage shop vac, outside air compressor. About twice a year. I don't think I've ever washed it. I keep it clean on the inside with oil, air filter, blades and hydro fluid.
I'm not one for a shiny mower.
Country1966? is online now
post #14 of 77 Old 04-10-2019, 10:22 PM Thread Starter
Mine stays fairly dirty pretty long but just been wondering how to get them cleaned up when the time comes without hurting things.
Do you have one of the old Massey GT's? Love the way they look. Just like the tractors of that time. So neat how they made them look just like the regular farm tractors.
post #15 of 77 Old 04-10-2019, 10:48 PM
mrbeef's Avatar
Here is a video I made last year on how I wash my machines.... I blow them off after every use/day. About 2-3 times a year I wash them. It is a good way and reason to look over the whole machine.
If you don't clean them you don't have the opportunity to identify things that might not otherwise be noticed. Mine get dirty... If I don't clean them you can see some maintenance items....
Exactly, I hate working on my stuff if I need to fix something when its dirty.
Air compressor or blower after every use works great.
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is online now
Found a clean LT2000 on Facebook marketplace. Ericjr16 Craftsman/Sears Forum 33 02-19-2018 12:02 PM
Noma/Sears 4ws Tractors Boyd Murray 0 12-12-2017 01:05 AM
Curtis cab with air conditioning for BX tractors JDFANATIC SCUT/CUT Tractor Reviews (All Brands) 0 12-04-2017 12:19 PM
Moving non-running tractors alone kklowell Backyard Round Table - L & G Tractor Related Topics 5 11-25-2017 08:30 AM
How do you clean out plastic gas tank?-clean gas goes in but comes out cloudy yellow. ericwest Craftsman/Sears Forum 8 11-27-2012 09:18 PM
