What is the best way to clean tractors? - Page 5 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #61 of 77 Old 04-19-2019, 08:43 PM Thread Starter
Re: What is the best way to clean tractors?
Originally Posted by Vmax540 View Post
As for electrical once a year after washing and drying disconnect all the electrical connections, soak both sides with WD40 (Water displacement), wipe off excess, let drip dry for a while then reconnect. I spray the entire engine, under the dash, the relays and even remove the ignition key and with a nozzle, spray WD into the key slot. WD will dry without collecting dirt and dust but, still leave a film that protects. To aid/speed up drying, start it up and allow to get engine warm (not hot) then shut it down. Electrical connections as a rule need to be clean, tight and dry. The beauty is no more bad electrical connections and all will come apart when needed !
Boy that is cleaning it to the last possible trace of dust!
Rando58 is online now
post #62 of 77 Old 04-19-2019, 09:45 PM
Nouveau Redneck's Avatar
These days I use dielectric grease on any electrical contacts that I ever disconnect when I reconnect them. The metals used in newer connectors seem to be made of materials that are prone to rapid oxide buildup and I have been bitten a few times chasing down electrical gremlins when the problem turned out to be oxidation on a connector that looked fine. Dielectric grease keeps oxygen from coming into contact with the electrical connections inside the quick disconnects.
The worst ones were on the electrical chute rotation and deflector connections for the snowblower on my Kubota. They starting working intermittently after the first year of use. I thought I was blowing fuses but the fuses were never blown and after unplugging and re-plugging all of the connectors and wiggling things they would work for a while again. Then, near the end of that second season I sprayed electrical contact cleaner into the connectors and then put some dielectric grease in them and I put more dielectric grease in at the end of the season and again at the beginning of the season every year since. I have just finished my 5th winter season with the snowblower and I haven't had a problem since that second year.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is online now
post #63 of 77 Old 04-21-2019, 06:24 PM
Bobdodge's Avatar
Originally Posted by Obscured_by_Clouds View Post
Tractors are made for workin' not cleanin'. They sit outside, not in a curio cabinet in the family room.
ahhh. thats why my girl keeps getting upset at me.
Bobdodge is offline
post #64 of 77 Old 04-22-2019, 08:46 AM Thread Starter
You're getting over my head here. I'm not the mechanically kind person as you. You really have it down and know what to do.
post #65 of 77 Old 04-22-2019, 08:49 AM
Steve Urquell's Avatar
Rando he's just talking about putting silcone/dielectric grease in the electrical plugs. It keeps water and corrosion from happening.
Steve Urquell is offline
post #66 of 77 Old 04-22-2019, 08:58 AM Thread Starter
Oh, Ok. Thanks for the interpretation. I'm a pretty simple person.
post #67 of 77 Old 04-22-2019, 12:12 PM
Go to an auto parts store and ask for a tube of dielectric grease. It comes in a squeeze tube, like a small tube of toothpaste. Just squeeze a little out and coat any bare metal parts of any electrical connection and it will prevent problems. You can squeeze it directly onto the connectors, but that usually uses more than neededor you can use your finger or a q-tip to apply it where you want.
Nouveau Redneck
Sean in PA
post #68 of 77 Old 04-22-2019, 12:47 PM Thread Starter
Ok, I'll check it out. Thanks!!
post #69 of 77 Old 04-22-2019, 04:22 PM
Blank Space
Dirty tractor + Swim Goggles + Swim Snorkle + pond = clean tractor.
OK, maybe new tractor. But they're delivered clean, right?
Obscured_by_Clouds is offline
post #70 of 77 Old 04-24-2019, 11:38 AM Thread Starter
[QUOTE=Steve Urquell;12246343]You're gonna be shocked at how hard that thing blows lol. Mine will blow a 20ft wall of wet leaves. It's Capt'n Insano power. Don't choke it down with a little extension cord. Check their recommendation on cord size as it draws a bunch of amps.[/QUOTE
It got here Mon. Have not tried it yet.
post #71 of 77 Old 04-24-2019, 06:51 PM Thread Starter
Wow, that thing is big! I may have to workout extra at the gym to be able to handle it. I might be able to blow the leaves out of the yard right into the field with this next fall. That would be one less thing to do with the little tractor.
post #72 of 77 Old 04-24-2019, 07:38 PM
Ha! Told ya man. That thing raises the bar for what a leaf blower can do.
post #73 of 77 Old 04-30-2019, 06:32 PM
Country1966?'s Avatar
Ok, all of you mr. Clean jeans have inspired me to hose off my mower; actually it was covered in grass I just mowed during the rain blowing rainstorm. Had to mow more rain on the way.
And I've got to pull it in my garage so I didn't want it to be a mess. That should hold it for another couple years. 😊I blow it of a few times a year.
Country1966? is online now
post #74 of 77 Old 04-30-2019, 07:19 PM
mowergene's Avatar
Super Clean applied with a brush for the grease & oil. Available @ Walmart.
In the past:
In use:
mowergene is offline
post #75 of 77 Old 04-30-2019, 07:30 PM
Yep. I like that it makes oil water soluable.
Found a clean LT2000 on Facebook marketplace. Ericjr16 Craftsman/Sears Forum 33 02-19-2018 12:02 PM
Noma/Sears 4ws Tractors Boyd Murray 0 12-12-2017 01:05 AM
Curtis cab with air conditioning for BX tractors JDFANATIC SCUT/CUT Tractor Reviews (All Brands) 0 12-04-2017 12:19 PM
Moving non-running tractors alone kklowell Backyard Round Table - L & G Tractor Related Topics 5 11-25-2017 08:30 AM
How do you clean out plastic gas tank?-clean gas goes in but comes out cloudy yellow. ericwest Craftsman/Sears Forum 8 11-27-2012 09:18 PM
