how to remove a stubborn pulley? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 23 Old 06-22-2012, 07:51 AM Thread Starter
I need to replace the pan gasket on a 24hp intek briggs twin, and cannot get the pulley off and out of the way. I tried everything I know, including a split puller, which simply mangled the pulley and never budged it. I have thought about a slide hammer, but would that hurt the engine, jarring it that violently on the crankshaft?
Does anyone have any suggestions? Is there anything I could have missed, holding the pulley on?
homefried1 is offline
post #2 of 23 Old 06-22-2012, 09:34 AM
My Orange Jane Deere
orange j d's Avatar
Re: how to remove a stubborn pulley?
Well now that it is junk, just cut it off.
Sent from my FREE MTF APP PROVIDED BY MY FRIENDS AT MTF*****
Remember: Marriage is the number one cause of divorce.
orange j d is offline
post #3 of 23 Old 06-22-2012, 10:24 AM
flash5153's Avatar
If you removed the 5/8" bolt up in the bottom of it,,,then rust and corrosion is the only thing holding it on.
There is a key way on the pulley,,but not removable. Just a raised area on the pulley that fits into the slot on crank.
Is the engine still mounted in tractor?? Heat may be the way to go.
flash5153 is offline
post #4 of 23 Old 06-22-2012, 10:38 AM
Senior MTF Poster
" I have thought about a slide hammer, but would that hurt the engine, jarring it that violently on the crankshaft?"
I use a blunt bit in an air chisel to get behind and drive them off IF there is enough room. Otherwise, I have a write up on how to remove them with out damage but I guess that is of no use to you now. As said above, may as well cut it off now.
Walt Conner
Walt 2002 is offline
post #5 of 23 Old 06-22-2012, 11:01 AM
Brockway
SARG's Avatar
I've had the same experience with a drive pulley on several garden tractors.
Ended up using a torch and porta-power.
These are the pulleys that the manufacturer states must be removed to change belts.
Now I just loosen the entire engine instead.
SARG is offline
post #6 of 23 Old 06-22-2012, 11:19 AM
I'd tack weld a nut in 3 places around its O.D. to the pulley,and use a long threaded bolt or threaded rod ,screw it in,to "push" it off the crankshaft...might still need some heat and penetrating oil(if you do it fast right after welding the nut on,it might be hot enough to come off without additional heating)......dont heat it so much the seal in the engine melts though...
I've used that method many times sucessfully,and if you are careful,you can get the pulley off without any damage,and grind the welds off and remove the nut,and re-use it...works well on stubborn rear rims that "welded" themselves to the axles on tractors that had keyed bore rims or ones with thru-bolts securing the rims to the axle shafts...
Tractor-Holic is offline
post #7 of 23 Old 06-28-2012, 07:03 AM Thread Starter
Got it off. Had to cut it, and even after cutting a slot down the length of the collar on the pulley, it still had to be knocked off with a hammer and punch.
post #8 of 23 Old 06-28-2012, 09:50 AM
flash5153's Avatar
I hope I don't ever find one like this. I hate it when things seem to fight you til the end.
post #9 of 23 Old 06-28-2012, 09:30 PM
ShelbyGT550's Avatar
Sounds like the one on my massey 10, I had to cut it in three parts to get it off in the end and even after tht I had to beat it -_-
1996 John Deere 425 Main Summer Machine - 20HP Liquid Cooled Kawasaki - Hydrostatic Twin Pedals - 48" Deck
197? John Deere 400 H3 Main Winter Machine Down - Fixing odds & ends - 19.9HP Kohler 532- Hydrostatic - 3PT Hitch - Back Blade - Snow Blower - Cab - Weights - Chains
1974 Massey 12G - Backup Machine - Tecumseh 12HP - 4 Speed Variator - 42" Mower Deck - Snow Blower - Tiller - Cab
1996 Sears GT6000 - Backup Machine - Kohler Command 22HP Twin - 6 Speed Hi/Low - 42" Mower Deck - 42" Dual Stage Blower - Brush Guard - ATV Tires - Chains & Weights
1974 John Deere 112
(Parts)
197? John Deere 112 Electric Lift - Storage - 12HP Kohler K301- 4 Speed Manual - Turf Tires
Past Machines & To-do's - 1974 Snapper LT16 - 1989 Murray GT18/46 - 1970 Massey Ferguson 10 - 2004 John Deere LA100- WIP
ShelbyGT550 is offline
post #10 of 23 Old 09-16-2019, 09:15 AM
Hi Walt,
Can you send me the link to how to remove a stuck drive pulley without damaging it?
Thanks,
Pete
Minnesota_Pete is offline
post #11 of 23 Old 09-16-2019, 09:33 AM
when I had that problem,I sprayed PB on top of the pully so it would run down between the crank shaft and pully,short time later slid right off
lorraine984 is offline
post #12 of 23 Old 09-16-2019, 10:02 AM
Thanks,
I tried spraying liquid wrench around it yesterday, I'll try another application next time I can get at it.
I'm trying to get a Kohler engine off of my lawn tractor, and this was (of course) the last step and only obstacle.
post #13 of 23 Old 09-16-2019, 10:13 AM
It never hurts to apply some never-seize or grease to the crank when you have a pulley or sprocket off ...saves you from future grief !...too bad the manufacturer's don't when they build things..
post #14 of 23 Old 09-16-2019, 10:34 PM
YouTube fellow named Taryl has walked them off with an impact wrench punching a substitute bolt.
38racing is offline
post #15 of 23 Old 09-17-2019, 06:23 AM
Collector of many tractors
Kbeitz's Avatar
This is what I use....
Name:	Bearing separator.jpg
Kbeitz is offline
