Replacing igniton coil on BS engine - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 5 Old 07-13-2019, 12:31 PM Thread Starter
Hi everyone, i want to replace an old ignition coil with a new electric ignition coil (398811) on my Briggs & Stratton engine (220707-0133).
Here you can see the old ignition coil:
https://www.directupload.net/file/d/...evzxjv_jpg.htm
And here you can see the new ignition coil:
https://www.directupload.net/file/d/...unnsx4_jpg.htm
I think I don't need the condenser anymore when using an electric ignition.
Can I just cut the wire between condensor and coil, remove the old coil and replace it with the new coil? What about the condensor and other parts? If I don't need it anymore I can remove it too?
Thanks for your answers :-).
RedBaron1210 is offline
post #2 of 5 Old 07-13-2019, 12:49 PM
Re: Replacing igniton coil on BS engine
On my older Briggs engines with points, I just cut the wire and bolt on a modern coil....works everytime.....
Cranman is offline
post #3 of 5 Old 07-13-2019, 01:07 PM Thread Starter
Ah, good to know 😉. Thanks 👍
post #4 of 5 Old 07-13-2019, 07:53 PM
Leave the points and condenser in place, just cut the wire. If you remove the points you will need to plug the plunger hole
RoyM is offline
post #5 of 5 Old 07-14-2019, 08:43 AM Thread Starter
The new coil was delivered with a part I don't know the purpose:
https://www.directupload.net/file/d/...awlvvn_jpg.htm
Is that the plug you mean?
