Test Frame for Engine? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 31 Old 05-09-2019, 07:42 PM Thread Starter
Blank Space
I've got a 13.5 HP Briggs engine I scavenged from a rider. Last I recall, it ran OK, but that was a couple of years back. Right now it's just sitting on a bucket to keep it upright.
What can I mount it on to be able to try to start and run it? Frame made of 4x4s? Or does it need to be more substantial?
Obscured_by_Clouds is offline
post #2 of 31 Old 05-09-2019, 08:02 PM
B440's Avatar
Re: Test Frame for Engine?
Frame of 4x4's would work. It may want to walk around a little. I met a person that was using a gas pressure washer frame as a test unit for engines. He had a battery and keyed ignition on it.
B440 is online now
post #3 of 31 Old 05-09-2019, 08:39 PM
MARK (LI)'s Avatar
If you have a piece of plywood...just dill holes and bolt the engine down...the bigger the piece of plywood the more stability it will have
MARK (LI) is online now
post #4 of 31 Old 05-09-2019, 09:20 PM
I like the pressure washer idea. I was going to suggest finding a free/dead tractor and using the frame.
Mike
TRACTORS:
OTHER (NOTABLE) EQUIPMENT:
Echo PB751T backpack blower
Husqvarna 350 chainsaw
RETIRED TRACTORS:
mikeinri is online now
post #5 of 31 Old 05-09-2019, 09:40 PM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
For what it's worth, I've started and run 10hp snow blower engines with them just sitting as is on the work bench, no bolts or hold down brackets.
110v electric starter of course so no yanking on the starter rope. Just held one hand on top of the tin shroud while the engine danced / vibrated a bit but nothing wild to be concerned about, even reving the engine up..
Yours sounds like a vertical shaft so you may need to sit it over a hole in something. The piece of plywood sounds good.
Heck, the guys in the scrapyard just fire up V8s with them sitting on the ground when you want a running demo.
Not suggesting anything unsafe, just my personal experience.
Larry ( in Southern Ontario )
Larry LGT 165 is offline
post #6 of 31 Old 05-09-2019, 09:50 PM
Just remembered, there's an old thread somewhere on this site showing a test setup, complete with a battery and ignition switches.
Mike
TRACTORS:
RETIRED TRACTORS:
post #7 of 31 Old 05-09-2019, 11:27 PM
The Admin from... Nowhere
littletractorguy's Avatar
Mike
Yeah, I think that might have been Larrybl's test setup... Yeah, here it is...
https://www.mytractorforum.com/44-sm...est-stand.html
post #8 of 31 Old 05-10-2019, 05:12 AM Thread Starter
Blank Space
It is, with electric start. I kept the wiring harness with the key switch, solenoid and safety switches. Not sure how much of that I need for a test run. There are two wires that run up underneath the tins, but I'm not sure where they go or what they do.
post #9 of 31 Old 05-10-2019, 07:48 AM
You know you are a REDNECK if:
Kitchen table.
For small engines I use a old riding lawn mower frame. (have tires on the frame so as it can be rolled in and out of the garage or kitchen) Tools can then be left on the kitchen table while testing the engine. Has several different holes drilled in the engine mounting plate for different make of engines.
Forest Gump is online now
post #10 of 31 Old 05-10-2019, 09:51 AM
I have an old frame on saw horses but it's currently occupied so for testing a 13.5 briggs I just bolted it to a 2x2 piece of plywoood and clamped it with two big c clamps to my small motorcycle hoist which has hole in middle of platform for shaft to protrude. Lower hoist to lift engine on and then raise to working level for battery solenoid hookup. Nice also is I can wheel it doorway of shop for actual running. I use the hoist for working on them too.
38racing is offline
post #11 of 31 Old 05-10-2019, 10:10 AM
Senior MTF Poster
Old power washer chassis is a great idea and a friend uses it. I made a semi box with hole in middle which sits inside the bed of a "little red wagon". This and power washer both allow easy moving from one place to another. Just drop in a couple of bolts loose to hold engine.
Walt Conner
Walt 2002 is online now
post #12 of 31 Old 05-10-2019, 10:39 AM
I've used a 5 gallon bucket turned upside down with a hole in the bottom for the crankshaft to stick thru ,for vertical shaft engines..you can bolt the engine to it with a few bolts to hold it secure..a metal bucket is sturdier,but you will have to place it on dirt or put a rug or something under the bucket so it wont vibrate all over the place..
That idea wont work for engines off push mowers that need the blade on to act as a flywheel though..a work bench with a hole made in the center is another way to make a test stand ,you can put the blade on under the bench--just stand clear once it fires up!..
Usually I have at least one junk tractor carcass I could put a vertical shaft engine on to test it out hanging around..
With horizontal shaft engines I usually just start on the ground,bolt them to a plank of wood long enough to stand on while you yank the rope..
Tractor-Holic is offline
post #13 of 31 Old 05-10-2019, 11:09 AM
Yes, I thought it might have been Larry's. I think I've seen variations of this on YouTube as well.
Mike
TRACTORS:
RETIRED TRACTORS:
post #14 of 31 Old 05-10-2019, 06:16 PM
Rich
X300owner's Avatar
Just driving home from a restaurant - this street has tons of apartment buildings and a guy was dragging out a Coffee table to trash - bet something like that could work. Go garbage picking.
2010 Deere X300, Deere 40" shovel, Brinly plug aerator, Brinly 125 lb spreader, Homemade Dethatcher on shovel, Craftsman 38" lawn sweeper.
X300owner is online now
post #15 of 31 Old 05-11-2019, 10:14 PM
I went to a swap meet today,and saw many small engines for sale..
One guy had a metal 55 gallon drum with a vertical shaft engine bolted to the top of it,so he could demonstrate it...he made two holes in the side near the top that his hands fit thru so he could get at the mounting bolts...
I though that was a pretty clever "engine stand"--just the right height to work on one without bending over or kneeling..
Currently Active Users Viewing This Thread: 5 (3 members and 2 guests)
X300owner, smiley458, northbama
XT3GSX Frame Flex Mudyapster Cub Cadet Forum 41 04-22-2019 09:18 PM
Enlarging train room jdcrawler Off Topic 31 01-10-2019 09:12 PM
JD318: Power steering bracket broken from frame thombert John Deere Forum 5 08-27-2018 04:25 PM
Anyone know if a closed frame 300 series dash will fit on a open frame tractor? Deere 332 John Deere Forum 0 04-19-2018 02:33 PM
Trade tube frame pro coupling for large frame coupling? mak90_1 Bolens Forum 3 11-17-2012 12:28 PM
