aftermarket Kohler carb and fuel pump - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 37 Old 04-12-2019, 01:52 PM Thread Starter
rudedawg's Avatar
Has anyone used an aftermarket non Kohler branded carburetor or fuel pump from ebay or Amazon on their Kohler engines and if so how did they work out for you? Thanks in advance, Rudy.
rudedawg is offline
post #2 of 37 Old 04-12-2019, 02:18 PM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
Re: aftermarket Kohler carb and fuel pump
Not yet, but considering it. Pricing really varies for ads that appear to use the same pics. Also have to watch if its free shipping or not. In some cases the price is cheaper but the shipping doubles it. Some can also be 4 weeks or more for delivery.
You really need to compare the ads and the extras. Some include gaskets / linkage / filter / cleaning brushes, some not.
I did buy a carb a few months back from China for an 8hp 1976 Briggs. Was very pleased with the product finish quality and the packaging. Engine fired right up and ran with no leaks so I would do it again.
Larry ( in Southern Ontario )
Larry LGT 165 is online now
post #3 of 37 Old 04-12-2019, 03:43 PM Thread Starter
rudedawg's Avatar
Thanks Larry
rudedawg is offline
post #4 of 37 Old 04-12-2019, 03:47 PM
mikgran's Avatar
Have bought a few Chinese knock off carbs with good results. Put an aftermarket fuel pump on my K241. Worked as advertised with no problems. All came with necessary gaskets.
2004 X485- 54 deck, 47 blower
1977 210
1970 110H
1991 Ariens YT12H w/bagger
1986 Kubota B7200HST
mikgran is online now
post #5 of 37 Old 04-12-2019, 03:50 PM
Cannon51's Avatar
I bought a Stens aftermarket pump for the 16hp Kohler engine in my LT160. https://www.stens.com/520-572-fuel-pump
It worked for a year or so and stopped pumping to the extent that it would not prime the carb at cranking speed. I robbed a factory pump off an extra engine and it is starting much better. I have assumed that all the pumps with the snap in plastic fittings come from the same place but I've seen prices from $10 to $50.
Cannon
Cannon51 is online now
post #6 of 37 Old 04-12-2019, 05:21 PM Thread Starter
rudedawg's Avatar
Thanks mikgran
Cannon
Thanks Cannon, that's the same cross reference pump my 16 h.p. takes.
For no more $ involved it's worth a try.
rudedawg is offline
post #7 of 37 Old 04-12-2019, 05:49 PM Thread Starter
rudedawg's Avatar
The issue is it cranks and runs fine for about 30-45 min. then starts spitting and sputtering like it's running out of gas. I can pull the choke and it will keep running but will go dead when choke is pushed back in. It starts right back up when choke is pulled out and will continue to spit and sputter but eventually smooths out and when the choke is pushed back in runs great again for another 30-45 min. then repeats the issue. I am thinking this is more likely a fuel issue than spark issue because it cranks right back up after going dead. It did this some last year and I replaced the fuel line from the tank to pump, removed and cleaned tank, replaced fuel filter, cleaned out carb bowl, verified carb solenoid clicks and cleaned tank cap. A couple of weeks ago I serviced the engine: plug, filters, oil, etc. and mowed for a little over an hour with no issues but the other day tried to mow everything which takes about 2.5-3 hrs. and it did it several times before I could finish. I figured with no more $ than a knock off carb & pump costs I would try that; the mower is over 16 yrs. old and just not worth putting a lot of $ into it although the rest of the tractor is solid and in really good condition.
Thanks again everyone.
rudedawg is offline
post #8 of 37 Old 04-12-2019, 06:23 PM
Hangin with the cool kids
poncho62's Avatar
I got a carb from iSaveTractors. I imagine it's Chinese. It was about $60. Has been working well for 2 years on a K301
I also ordered a Chinese knockoff for about $20, free shipping. It took 3 months to get here and had a broken plastic float. The packaging was also damaged. They refunded my Paypal.
Ford LGT100
Ford LGT125
Ford LGT165
MTD 990 Wizard
MTD 960
John Deere STX38
poncho62 is online now
post #9 of 37 Old 04-12-2019, 10:04 PM
You don't say you checked the gas cap for venting.
38racing is offline
Old 04-12-2019, 11:33 PM
rudedawg
This message has been deleted by rudedawg.
post #10 of 37 Old 04-12-2019, 11:37 PM Thread Starter
rudedawg's Avatar
thanks poncho, I'll check them out.
Thanks for responding 38racing. I keep the cap cleaned really well and make sure the underside vents are clear of crud/debris; when the issue happens even loosen/remove the cap but it does not have any effect.
rudedawg is offline
post #11 of 37 Old 04-13-2019, 05:02 AM
Cannon51's Avatar
I agree that it sounds more like fuel than spark but I have had to replace 3 coils in my Commands. They never failed completely but would give intermittent or weak spark. I replaced them with aftermarket coils for less than $20. My $5 Harbor Freight inline spark tester is some of the best money I ever spent.
Cannon
post #12 of 37 Old 04-13-2019, 08:57 AM
The OP should set up a temporary gravity feed fuel tank and see if the problem goes away.
rayjay is offline
post #13 of 37 Old 04-13-2019, 09:07 AM Thread Starter
rudedawg's Avatar
rayjay that's an idea; does it matter if the carb itself is fuel pump supplied if the pump is bypassed?
rudedawg is offline
post #14 of 37 Old 04-13-2019, 09:23 AM
if your gas tank isn't venting properly, you may be creating a vacuum in the tank that stops fuel flow. Check your gas cap.
dirtscratcher5 is offline
post #15 of 37 Old 04-13-2019, 10:26 AM Thread Starter
rudedawg's Avatar
Thanks for responding, I remove the cap and it does not have any effect.
rudedawg is offline
Durfman
77 ST18/6 fuel pump vacuum issues chuckm51 Craftsman/Sears Forum 19 06-05-2018 12:13 PM
Kohler M8 - Idles for 45 seconds, then dies danritz Small Engines and Repair 11 05-05-2018 02:31 PM
Another "I need a fuel pump rebuild kit" thread? Blunatic Bolens Forum 9 05-01-2018 01:03 AM
Kohler Courage Mechanical Fuel Pump Block-Off DaddyJohn Small Engines and Repair 8 01-25-2018 05:35 AM
kohler k301 carb and fuel pump rebuild? raley Small Engines and Repair 1 11-01-2012 08:52 AM
