K241 governor cross shaft broken - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
post #1 of 6 Old 12-28-2016, 07:19 PM Thread Starter
Motor is off, flipped upside down. I got the piece of the broken cross shaft tab out of the oil pan. How can I get the broken tab off the shaft and replace without tearing out everything else?
Thanks,
Josh
3rdGenGravelyOwner is offline
post #2 of 6 Old 12-28-2016, 08:29 PM
Hangin with the cool kids
poncho62's Avatar
Re: K241 governor cross shaft broken
Dont think you can, governor assembly is the 1st thing to go into bare block.
Ford LGT100
Ford LGT125
Ford LGT165
John Deere STX38
poncho62 is online now
post #3 of 6 Old 12-28-2016, 09:20 PM Thread Starter
Shoot, well, does anyone have any instructions on taking everything apart? Will I need any special tools to pull any parts?
post #4 of 6 Old 01-01-2017, 01:43 PM
Hi,
I think you can still get the service manuals from Kohler.
Try this site http://www.kohlerengines.com/index.jsp
Dave
DLF_IN is offline
post #5 of 6 Old 01-02-2017, 03:50 PM
Governor gears are one of the first things in and last things out doing a rebuild. So if engine really old and low compression maybe you want to do the rebuild. People run them w/o a working governor it is not safe as governor controls max engine speed the choice is yours I do this on several older kohler k gravely I am not suggesting you follow my example just passing along information there are work arounds to set max engine w/o a working gov again I am not telling you or anybody else to do this. You have found a weak point in this engine's design it is apparently fairly common in k series including k gravely maybe mostly high hour engines not a technical expert on k kohler but I've known about it a long time. I can tell you absolutely for sure that nobody that knows what they are doing will ever do a complete k series rebuild w/o using new governor parts and much more new parts. With gravely walk behinds you could consider a used gravely k engine or possibly a repower see the yahoo gravely club. Stens and other sources for kits/parts if you do your own work a kohler k rebuild is maybe affordable send out to shop its going to cost so price out your options. If both engine/trans axle finished I'd buy another gravely price out cost for all parts then decide.
edwardgoodridge is offline
post #6 of 6 Old 05-03-2019, 01:22 AM
lewfoer's Avatar
I have a PDF copy in my Google Drive. You're welcome to it. https://drive.google.com/file/d/1NBy...w?usp=drivesdk
I had a conversation with the mechanic at my local shop since I'm working on a K341 engine. Some parts aren't available anymore. Do some checking before you get too far into it.
lewfoer is offline
