Good Knife Sharpener - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Tool Time Tool questions and discussions
post #1 of 18 Old 11-07-2019, 03:19 PM Thread Starter
hotajax's Avatar
Please Tell Me About a Good ( and cheap ) Knife Sharpener
I'm no good with a sharpening stone. And those cheesy little sharpeners they sell at Wally World with the v-shaped stones don't last too long.
And even worse, I don't care.
hotajax is offline
post #2 of 18 Old 11-07-2019, 03:22 PM Thread Starter
hotajax's Avatar
I'm lousy with a sharpening stone. And Ideas for a good sharpener I can just drag over the blade a few strokes? Thanks.
hotajax is offline
post #3 of 18 Old 11-07-2019, 03:39 PM
MARK (LI)'s Avatar
Re: Please Tell Me About a Good ( and cheap ) Knife Sharpener
See if you can find where Boy Scout uniforms and accessories are sold....I still have my stone from the 1960s in its leather sheath...probably some other fabric now...Amazon has some ...but about 12 to 30 dollars
MARK (LI) is online now
post #4 of 18 Old 11-07-2019, 05:15 PM
Have Dog - Will Travel
Jere39's Avatar
Re: Good Knife Sharpener
I like this combination tool from Benchmade:
https://www.amazon.com/f-Benchmade-G...sr=1-1-catcorr
There is one that appears to be a duplicate in different color, and with different brand that might be just as good:
https://www.amazon.com/Work-Sharp-Gu...6N7RGPHTYK4KEJ
I don't ever use a powered wheel on any knife
Jere39 is offline
post #5 of 18 Old 11-07-2019, 05:52 PM
This one will sharpen most anything:
https://www.garrettwade.com/solid-ca...nisher-gp.html
Flaken is offline
post #6 of 18 Old 11-08-2019, 10:22 AM
Retired & lovin it!
Newsman's Avatar
I have been using this Lansky set for the past 40 some years.
Runs about $25,(Cabela's) bit less on Amazon. They also make ones with 4 and 5 stones but never had the need. Will do anything from small jack knife to larger chef knives. And yes they certainly come out sharp as the hairless test spots on my arm can attest. ( shave them as test, could cut paper but where's the fun in that?)
MikeC
Newsman is online now
post #7 of 18 Old 11-08-2019, 10:37 AM
Senior Moment
Greybeard09's Avatar
I just use a stone.
Late 50's Bready... aka, "The WoodRat"
1969 John Deere 110 w/front blade
1998-99 MTD/AYP "Black Thing" 18hp Briggs MUTT-Mower
2002 Cub Cadet 2166 (in process)
2006 Cub Cadet GT2544
2011 Cub Cadet Z-Force S 48
Greybeard09 is offline
post #8 of 18 Old 11-08-2019, 11:02 AM
My sharpening stone is a scythe sharpening stone.
Work it like a knife steel.
My name is Tom and I'm a Plantaholic.
ThomasB is offline
post #9 of 18 Old 11-08-2019, 11:16 AM
I rescued a old electric can opener from the trash that had a built in knife sharpener--it wouldn't open cans well (they would drop off after it cut the lid off!)--but it sharpened my pocket knives to perfection...
Now I'm wondering if I still have it-or if its lost in the clutter in my garage,or if I tossed it out..hmmmm!..haven't used it in a long time..
Tractor-Holic is offline
post #10 of 18 Old 11-08-2019, 11:58 AM
Dave in MD's Avatar
MikeC
I agree this is the best for the edge that you can get but it does take some time to get that edge.
For a good balance between edge and time, I like the Smiths 52564
Dave in MD is online now
post #11 of 18 Old 11-08-2019, 02:09 PM
The Smiths DIAMOND sharpening system is also a good one similiar to this one.
https://ads.midwayusa.com/product/10...=1101100736048
What I've done to get by cheap (and doing so for several years) once the just regular cheaper Smith set is bought (you can do the same with lanskys) is I buy the diamond sharpening stones like this from HF or flea bay and get some aluminum sign material and cut it too about the width of the stone including the 90 degree bend and glue the stones to the aluminum guide bars and then use the rest of the angle guides. The HF diamond stones last a very long time and come in fine, med, course. The diamond sharpening stones cut and sharpen more agressively and do not wear out very fast. Even Ronnie Milsap can sharpen a knife using the Smith or Lansky Diamond sharpening system.
The key to getting a very sharp edge is both edges of a knife have to be sharpened at the same angle and the Lansky and Smiths allow you to do such.
I've seen more accidential wounds caused from a dull knife than a sharp knife.
Forest Gump is online now
post #12 of 18 Old 11-09-2019, 10:52 AM
ZTT42's Avatar
Most if not all of the sharpeners listed by folks will do a good job, but the key to this is in your first question. It takes care and work to make a good sharpening job and "just dragging over the blade a few strokes" doesn't cut it (pun intended). Most of the tools, or set of stones, start rough for a shaping step, then smoother for a smoothing step, then stropping or honing for the final step. The "extras" are mostly intended to help keep a proper angle on the bevel and can help, but it takes close attention and time to do it right.
My test for dullness is to look at the edge under a good light. You can easily see any flat, un-sharp edges as a bright line. If it's sharp, the edge can't be seen - and you can shave with it.
If you get it right at first, then maybe you can touch up with a few strokes.
most can-opener-type sharpening attachments and drag-through sharpeners will seem sharp but leave a wire edge that quickly dulls.
tractors: 1976 AC 710, 197? Simplicity Sovereign 7016 Six-speed, 2008 Cub Cadet Zero Turn Tractor - ZTT 42 mower
Attachments: Simplicity 46" snowplow, 36" gannon earthcavator, AC 36" rototiller, aerator, spring rake, Agri-fab front scoop (highly modified with winch), lawn sweeper, garden cart
Other stuff: Stihl 035 saw with bad seals, Honda 3000 generator, string trimmer/edger/blower/tiller
ZTT42 is offline
post #13 of 18 Old 11-10-2019, 03:21 PM
mytmouz's Avatar
I use my neighbor...
https://geekologie.com/2019/01/man-s...bottles-in.php
mytmouz is offline
post #14 of 18 Old Today, 12:33 PM
Bottom line is sharpening a knife or chisel (or any edged tool, for that matter) takes skill or equipment. The former is developed over time, the jigs range in price from cheap to expensive. I've used the Lansky that Newsman suggested (descended from LouRay's virtually identical sharpener). This is relatively inexpensive and will do a nearly perfect job of sharpening your knife - but it is NOT going to be a few swipes on a stone. It is slow and will take time if you do it properly - and will give you a knife that you can shave with when you are finished.
I've tried oil stones, Japanese water stones, self stick abrasive film applied to glass, an off brand and Makita power wet stone set-up, the Stone Pond, and more than a few plane iron/chisel jigs along with even a 2 x 72" belt grinder (using a 9 micron belt for final polish). All do a good job. The key is holding the knife at a constant angle as it is drawn across the abrasive medium. Those quick kitchen knife sharpeners use hardened steel cutters arranged in a "V' to take a shaving off the knife, and I've never been happy w/ them. Kitchen 'steels' do not sharpen a knife - they simply reshape the edge. For a really sharp knife you need to use a variety of grits from coarse to very fine, as said, holding the angle constant. Any 'knife sharpener' that uses a single stage - one grit - wheel or stone will give you a knife edge that is, perhaps, sharp enough. But not, imo, a good sharp edge.
To answer your request: Any set of oil stones or water stones will do the job. You need to supply the skill. Absent the last, rely on a jig - get a good one, you get what you pay for.
Go to youtube and look for a video showing the Japanese masters sharpening a samurai sword. They sit cross legged in front of the stone and draw the sword across the stone from right to left (or the other way), pause and then repeat. The mastery is these guys have been doing this for years and can hold the angle constant over the entire length of the blade for every stroke.
TrakFan is offline
post #15 of 18 Old Today, 12:59 PM
Send a message via AIM to Dadstractors Send a message via MSN to Dadstractors Send a message via Yahoo to Dadstractors
I've had good success with https://www.worksharptools.com/produ...pening-system/
Dadstractors is offline
Currently Active Users Viewing This Thread: 13 (1 members and 12 guests)
DonsFriend
