New to me material lift - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Tool Time Tool questions and discussions
post #1 of 16 Unread 03-25-2019, 07:24 PM Thread Starter
Won this Genie GL-4 material lift in an ebay bid. Final cost was about $65. Rated at 500 lbs.
ID:	2368109 Click image for larger version
ID:	2368113 Click image for larger version
It's missing the two front support legs that exist under the forks but I thought I could make some myself.
How'd I do ?
Dee_Veloper is offline
post #2 of 16 Unread 03-25-2019, 07:44 PM
Collector of many tractors
Kbeitz's Avatar
Re: New to me material lift
Make fit the back of your tractor....
Kbeitz is offline
post #3 of 16 Unread 03-25-2019, 07:45 PM
MARK (LI)'s Avatar
How did you do?....Ya dun good
MARK (LI) is offline
post #4 of 16 Unread 03-25-2019, 07:49 PM
Send a message via MSN to Nickletwin Send a message via Yahoo to Nickletwin
I have one similar to that. I really like it.
I'm sure you'll like it also.
Good find!
Nickletwin is offline
post #5 of 16 Unread 03-25-2019, 08:35 PM Thread Starter
Spot on! I am going to figure out a way to add this to my tractor. I think it may be fairly simple to do. If I proceed in that direction, I'll post some pics.
thanks! I just about fell out of my chair when I found I had won considering how much these go for on Amazon.
Good find!
I'd been pondering getting a forklift of some kind for a long time. I even penciled out building one out of a hand truck. When I saw this one up for bid, I couldn't let it pass.
post #6 of 16 Unread 03-26-2019, 02:00 PM
close enuff works for me
deereboy55's Avatar
After you mount it on your tractor ,put a 12 volt winch in the place of the hand crank,with winch control near steering wheel.
deereboy55 is offline
post #7 of 16 Unread 03-26-2019, 06:09 PM Thread Starter
Good thought. Might be a bit more complicated because I will still want to be able to use it off the tractor.
I may be able to use a battery powered drill because the hand crank is already designed to be removable by simply pulling out a spring loaded retainer pin.
post #8 of 16 Unread 03-26-2019, 07:01 PM
Works great lifting window air conditioners up to set in windows, work benches, etc.
First thing you lift over 150 pounds, should pay for itself, IMO.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #9 of 16 Unread 03-29-2019, 07:43 PM Thread Starter
I got legs!
I finished making some legs for the forklift. This is what the factory legs look like:
This is what I was able to build:
The hard part was finding the caster mounting plates. They're not available separately from the factory.
Once those were found, it was just a matter of drilling all the holes; making some spacers to adjust the clearance of the casters; and welding the mounting plates to the square tubing.
I used 2x 2x 1/8 tubing and the caster mounting plates are also 1/8 thickness, so everything is very stout.
I haven't decided if I will paint the legs, but for now the unit is fully functional.
post #10 of 16 Unread 03-29-2019, 08:11 PM
badgerland01's Avatar
Originally Posted by Dee_Veloper View Post
I got legs!
Attachment 2368835
Attachment 2368837
Nice work. I use a couple of those at work for changing heavy motors. They make a plate to go across the forks and it is very handy. Very nice score on that!
X749 "H-3 EDITION"
GX345
badgerland01 is offline
post #11 of 16 Unread 03-30-2019, 02:20 AM Thread Starter
I did see that plate... but it isn't cheap. I will need something like that. I'll have to get creative and see what I can come up with a an alternative.
post #12 of 16 Unread 03-30-2019, 07:54 AM
Don
[QUOTE=Dee_Veloper;12231263]Good thought. Might be a bit more complicated because I will still want to be able to use it off the tractor.
If you do use it off the tractor can you lock the wheels?
Don
My craftsman 917.27308 is online now
post #13 of 16 Unread 03-30-2019, 06:29 PM Thread Starter
There are no wheel locks on the unit now. I would have to block the wheels if needed.
There is an optional wheel lock accessory that can be purchased, but...it's not cheap.
post #14 of 16 Unread 04-09-2019, 11:00 PM Thread Starter
I got brakes !
I couldn't afford the factory brake setup, so I had to find another solution. After many different ideas I settled on toggle clamps and after trying it, out I am very happy with the result.
This photo shows the brakes disengaged
This photo shows the brakes engaged
This photo shows a close up of one of the brakes engaged.
It's nice because I can set or release the clamps with my foot. They hold surprisingly well and the total cost for clamps and hardware was about $15.
Fortunately, the lift already had two holes on each side of the base next to the wheels for some other purpose but worked fine to mount brackets for the clamps.
post #15 of 16 Unread 04-09-2019, 11:24 PM
Don
Good job!!
Don
Electric Lift Mod on GT225 Bassguitarist1985 John Deere Forum 2 11-01-2018 06:10 PM
2017 X570 w/ pre 2016 47" Snowblower and electric lift. btrav1226 John Deere Forum 6 12-23-2017 06:56 AM
Old Landlord age, & Electric Lift Help ollieboy Simplicity/Allis Chalmers Forum 5 11-18-2017 11:21 PM
x500 electric implement lift for snow blower / blade nostaw John Deere Forum 24 02-15-2015 10:51 PM
Suburban scissor deck won't lift high enough hartkem Craftsman/Sears Forum 5 02-22-2013 09:28 AM
